Australia, VIC, Glen Iris
Joined Jan 2012
Can anyone please explain the functions of this paris v4 r3 board more clearly.
http://www.multiwiicopter.com/products/sku-24 I know it has 2 gyros, alt hold, gimbal outputs ect, but im sure it goes further than that. any one got experience with this type of board please enlighten me. |
Some fpv multi rotor flying shot out near the Dandenongs. RCExplorer Tricopter with the MultiWiiCopter Scarab Quadcopter. |
Owen, sorbothane sheet for vibration reduction:
http://www.ebay.com.au/itm/SORBOTHAN...ht_1476wt_1270 |
Joined Jan 2012
we have to do it again soon
Ok. There are basically two types of Tricopters - Gyro only based (this is where you have 4 gyros on board only) and then there are controller boards (like the Multiwiicopter boards) Boards like the above have all the gyros and sensors onboard to control basically everything. Some of them even go the extra mile with Altitude and GPS hold etc. The good thing about these boards is you can generally get away with using any standard radio. Unlike the Gyro only copters where the radio must do 120Degree SWASH. The boards make it easier to fly these types of copters because the are constantly compensating for what the copter is doing, in order to keep it stable in a hover. Then when you give it a direction to head, the board takes those commands and instructs the copter to do its thing. So in short - the board is all you need. Besides motors and ESCs and the normal electrics. They are more advanced than the gyro only copters, and are far more stable. We still get a lot of customers that go for a gyro only copter (our Trilogy for example) as they are a bit cheaper. Lastly... the can be programed to run in many different configurations. So if say you get sick of a Tri, you could take that same board and put it in a Quad - reprogram, and fly! The program is free - so no need to buy special software. I hope that helps a bit mate, but if you want to know more, ask away. ![]() Cheers Mongrel |
Joined Jan 2012
'Some of them even go the extra mile with Altitude and GPS hold etc'
This is the part i was asking about, the multiwii 600+ sirus has these abilities i was after someone with hands on experience to shed some light. Cheers mongrel good wright up there |
No prob! I watched a demo of a copter that was amazing. You didn't fly it like a normal copter where you fly it in relation to the direction it is pointing. This board didn't care where it was pointing.
Hard to explain, but basically if you leaned left on the stick, the copter would move left in relation to where you are. It didn't matter what way it was facing, it would move to your left! So it didn't matter if you got disoriented. Because if you leaned back on the stick, it was always come back to you, no matter what way it was facing!! CRAZY!! |
Joined Jan 2012
Build updates
So progress has been slow due to getting stuffed around by a ebay seller and having no motor mounts for the quad. However i found this kit avaliable on goodluckbuy.com for 30 bucks delivered..... yes 30.
![]() Considering making this fpv capable but might keep it light and nimble for some acrobatic los flights. |
My 2 current multis. Well technically the Octo is works, but I'm the only one into RC so I'm the only one that gets to play with it. The Quad should be running by Saturday as my 60 plush speedies came in. Australia Post was holding them at the post office since the 2nd of March
![]() Details in my blog
Joined Jan 2012
I still cant decide which frame to build my y6 on, i have the fpvmanuals pro delrin kit, theres one on goodluckbuy for 95 delivered which looks pretty good. then theres the multiwiicopter scarab y6 which is pricey but looks amazing. My y6 fpv ap project will run ntm 750kv 28-30s 18amp plush escs and use the latest multiwii paris v4 600+ sirus controller. |
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Sold Multi Rotor Flight Controllers - FY90Q & Multi Wii | Tahoe Ed | Aircraft - Electric - Multirotor (FS/W) | 3 | Sep 28, 2011 05:29 PM |
| Discussion Dreaming about Multi Rotor setup : Multi+GoPro+eagle tree everything? | crashtested | Aerial Photography | 6 | Sep 11, 2011 11:36 PM |
| Alert New Multi Rotor For Sale/Wanted Thread In Classifieds | Katabatic | Multirotor Talk | 0 | Apr 11, 2011 01:40 AM |
| Suggestion Sticky thread in Multi-rotor-helis thread has nothing to do with multi-rotors | timecop | Site Suggestions / Complaints | 2 | Apr 03, 2011 08:56 AM |
