Old Jul 15, 2012, 08:58 PM
geostomp is offline
Find More Posts by geostomp
ReVolt- Proprietary Insanity
geostomp's Avatar
United States, MI, Wixom
Joined Sep 2007
BTW, I was cutting composite filler that was spread over foam.
geostomp is offline Find More Posts by geostomp
Old Jul 15, 2012, 09:44 PM
vtdiy is offline
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
I wonder if I could make a bit for foam.
vtdiy is offline Find More Posts by vtdiy
Old Jul 16, 2012, 10:45 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I made a tap by grinding reliefs into an acme screw. I thought about making an endmill or router bit. Go the whole nine and heat treat it!
Old Jul 16, 2012, 11:48 AM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
I've made hand reamers before from drill rod by cutting an angled flat at one end tapering to about 1/3 the diameter of the rod at the end, and stoning that.
Also forged hardened and tempered boring bars out of drill rod.
I've even made a crude single flute mill from an old drill bit by grinding back one of the flutes for use on aluminum when I didn't have anything else -- It worked. Might be okay for foam at a slow speed. The main caution I'd have is the the high speed a router runs at and possibility of shattering a homemade bit of his type. But maybe it would cut when run at slow speed in a variable speed rig.
Old Jul 16, 2012, 02:53 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
You can cut foam cleanly with very low RPM settings. My lowest setting is about 6000RPM.
tom43004 is offline Find More Posts by tom43004
Old Jul 16, 2012, 07:33 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Good info Tom, what diameter bit for that?
Old Jul 17, 2012, 06:58 AM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Most of my cutting is done with 1/4" diameter, radiused end mills, usually four flute but I have cut a lot of foam with two flute mills as well even at 6000rpm.
Old Oct 14, 2012, 06:25 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Upgraded to the CW 250 drivers, 48V power supply, 3A steppers, Angle iron all around.
Geomax CNC Router (1 min 3 sec)
Old Oct 15, 2012, 07:29 AM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Cool! I like the paper skirt, too. What material are you cutting?
Old Oct 15, 2012, 10:52 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Yeah that skirt is nice huh. It's MDF. I put epoxy and filler over top and cut again. I lost steps with the old bluumax motors and drives, so I rebuilt the router and am filling back and cutting again. The table is nice with one side cutting within 2-3 thou' of the other. Rapids in the 200 ipm range and reliable.
I just had to upgrade the y axis rails to get my trailing edge to come out.
Old Oct 18, 2012, 10:23 PM
crazyhorse21 is offline
Find More Posts by crazyhorse21
Joined Mar 2011
nice work ....
i have got the same kit a month ago .. still waiting to make time to put it together ... am a complete noob to cnc ...
hope to have it assembled and then figure out the the software part of it
(MACH, masterCAM, etc etc ... all new to me) ... but i've been working in 3ds Max for very long time now....
do you have any good build logs or refs you can recommend to help setup this machine ?
CH
crazyhorse21 is offline Find More Posts by crazyhorse21
Old Oct 20, 2012, 12:59 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Originally Posted by crazyhorse21 View Post
nice work ....
CH
I just used the Bluumax website for assembly and setup. Join the Bluumax yahoo group and there is a ton of info there too. Post here if you want and I'll answer any questions I know the answer too.
Old Oct 20, 2012, 09:12 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
you must not be sleeping much with your progress, nice work-
Doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Oct 20, 2012, 10:42 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Doug
Thanks. Past my bed time now actually.
ReVolt R/C Jet Development (0 min 45 sec)
Old Oct 30, 2012, 07:50 PM
Taget is offline
Find More Posts by Taget
Taget's Avatar
United States, MI, Marquette
Joined Dec 2010
This looks great. I really want to get into CNC but most of the prices have been cost prohibitive. what are your thoughts on this for a newcomer ?
Taget is offline Find More Posts by Taget
Build Log "done by ourself" cnc router and hotwire cutter.now with video. clausxpf CAD/CAM 23 Jan 05, 2013 05:58 PM
Question CNC router Kit ? marcel76 The Builders Workshop 6 Feb 21, 2009 04:50 PM
Found Allegro UCN5804b stepper controller chips for cnc router or foam cutting stealthy Aircraft - General - Miscellaneous (FS/W) 0 Feb 05, 2006 08:46 PM
CNC router kit choice? Coder The Builders Workshop 3 Oct 15, 2002 08:45 PM
