Great that you have a plane coming together geostomp. Looks good.
What I have in mind to build for CNC is a rotary positional lathe with a toolpost dremel mill. Approximate size is going to be 12" x 24" capacity. It's going to be tricky driving it with the small steppers I have. But if I keep friction low and carriage light, they may work. The bed won't be light, though. I bought two pieces of 3" steel channel iron 12" long for the front and back horizontal pieces. I think I'll use 1-1/4" OD steel tubing stock for the lengthwise frame stiffeners. Haven't decided on the ways and linear bearings yet, though. Maybe DIY with 3/4" black iron pipe set floating in adjusters at the head and tail of the lathe. I might even slightly mill raceways on the pipe for skate bearings. Don't know how fancy I want to get. Anyway the idea is to mill fuselages via rotary positioning. Different topic: I notice your mill looks like it makes a LOT of foam dust. I've recently seen a video of a foam cutter that produces bigger foam shavings, with much less dust. That was on the Foam Casualty website. I wonder what cutter he is using and what feed and speed he's running it at? Seems like it would be very helpful to cut down on the amount of dust created in milling foam. Keep up the great work! |
The dust is because my proverbial chip load is so miniscule causing tiny particles to accumulate. The 20,000 rpm of the cheapy router is too fast for my feed and wouldnt have the torque to keep up if I up'ed the feed rate. Its cheap, it works, I have a computer designed jet. I have been containing and vacuuming and I work out doors. |
I've also been looking at one of these machines: http://www.automationtechnologiesinc...ith-controller |
I decided to go ahead and build my CNC Milling Machine:
http://www.rcgroups.com/forums/showthread.php?t=1685778 |
Really geo? I was thinking single or double flute would give bigger chips, but will go by your experience if that cutter seems to work better with foam. Any idea what RPM you're running now?
btw, That speed controller is also great for powering a hot wire via a low voltage transformer or old style automotive battery charger, too. People often use dimmer switches for that purpose, but they don't have a built in fuse, three way switch, cord or outlet or box. If you were to buy all of that it would cost more than the speed controller. I've used that HF speed controller for many different things -- invaluable piece of equipment here -- frequently on sale at HF, too. |
Yeah that speed controller is sweet. 15 amp capable; the possibilities are endless. |
| Thread Tools | |
| Build Log "done by ourself" cnc router and hotwire cutter.now with video. | clausxpf | CAD/CAM | 23 | Jan 05, 2013 05:58 PM |
| Question CNC router Kit ? | marcel76 | The Builders Workshop | 6 | Feb 21, 2009 04:50 PM |
| Found Allegro UCN5804b stepper controller chips for cnc router or foam cutting | stealthy | Aircraft - General - Miscellaneous (FS/W) | 0 | Feb 05, 2006 08:46 PM |
| CNC router kit choice? | Coder | The Builders Workshop | 3 | Oct 15, 2002 08:45 PM |
