Old Feb 23, 2012, 09:40 PM
geostomp is offline
Find More Posts by geostomp
ReVolt- Proprietary Insanity
geostomp's Avatar
United States, MI, Wixom
Joined Sep 2007
Build Log
Bluumax CNC router kit $415.00 with motors and controller
My cnc router kit arrives tomorrow from bluumax.com. This is basically a diy kit that takes the engineering out of the equation and allows a person to concentrate on the other aspects of setting up a cnc. I'll post.
geostomp is offline Find More Posts by geostomp
Old Feb 24, 2012, 06:44 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Router arrived. Yea this is my first router. I'm in school learning g code and setup. I have no affiliation with bluumax.
Old Feb 28, 2012, 02:09 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I have everything assembled that came with the kit and added wood, threaded rod, a power supply, and some wire. I have a smoothstepper board in route via overnight to address the mach 3/Windows 7x64 issue.
Old Mar 01, 2012, 09:19 AM
Hangman15 is offline
Find More Posts by Hangman15
Metal Master
United States, MD, Frederick
Joined Feb 2012
Let us know how it runs when you have it all together. I would like to build one for home since i have 4 large CNC machines for work that i use everyday.
Hangman15 is offline Find More Posts by Hangman15
Old Mar 01, 2012, 03:35 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I have the smoothstepper now but had to make another order for its special cord that adapts the parallel to a 26 pin low profile, and I went priority on the shipping this time so it will be a few days. I have been learning the basics on various Haas equipment and I'm sure the bluumax won't compare, but I'll let you know how this works out for the money. The build was crisp with everything being tapped with perfect placement.
I will eventually use it to cut parts to upgrade it. It would be cool to see one with acrylic b and c axis milling a compressor wheel in foam or plastic.
Old Mar 01, 2012, 03:44 PM
Metal Master
Joined Feb 2012
Originally Posted by geostomp View Post
I have been learning the basics on various Haas equipment and I'm sure it won't compare
I love to machine
Old Mar 06, 2012, 04:57 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Bluumax CNC Router Kit (low cost) (5 min 36 sec)
Old Mar 07, 2012, 07:40 AM
Metal Master
Joined Feb 2012
Geo, Looks great. awesome job of gettting it up and running. Do you think the plexy side supports will be enough for the router running and the side loads that will be put onto the cutter? Can not wait until we see wood chips.
Mikey
Keep on building
Old Mar 07, 2012, 08:04 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Mikey
Keep on building
I saw where a person added a piece of plexy parallel to the x axis and attached them to the side supports of the gantry to box it up and add strength. I found myself buying a 1/4 trim router to mount to the bluumax, which has also been done, and I think letting the tool do the work is going to be the name of the game. The Bluumax website does suggest that mods are a likely occurance once the basics are covered, but I just want to cut battery trays out of ply and shape foam for composite plugs so the Max is a shoe-in for cost effectiveness. I'll post once I get the spindle mounted and ripping!
George
Old Mar 08, 2012, 09:53 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Bluumax tuned for speed. (1 min 27 sec)
Old Mar 09, 2012, 10:19 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
So I cut a piece of melamine a few times because it was the only material I had on hand. It cut really nice at 60ipm but I lost steps and slowed it to 5ipm. The cuts tend to heat the tool at that rate of feed. I was also having trouble keeping my work peice down and it would jump up into the tool at times. Without calculation it seems I may need to find a middle ground for my feed rate and maybe continue tuning my motors.
There was talk of changing the steps of the motors to increase torque. They are at half step now and I am not sure which setting would give more torque,1/4 or full step. The 1/4" tool is alot for this machine and it results in very high cutting speed and alot of side forces to contend with. I believe the 1/8" tool it was designed for will cut down on cutting speed and take less torque from the steppers to move accurately.
I think the cutting speed was way high in the video and that is why the tool never got sufficient bite and instead created heat.
The bluumax Y linear motion is held in place by gravity. I may begin a mod in this area by simply adding some wieght to it at a low CG.
Bluumax cutting masonite (10 min 16 sec)
Old Mar 11, 2012, 06:37 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
With the proper feeds and speeds, tooling, and depth of cut, the bluumax performs! It says on the web site that the bluumax is no race car or tank, but when used within a nominal level of load it is very useful. It seemed to jump to life after I lubed the lead screws with silicone grease. I also added 15lbs of pennys to the gantry below the cut table.
Bluumax CNC router doing a quick engrave. (2 min 39 sec)
Old Apr 12, 2012, 03:15 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I have been learning MasterCam. Bluumax is good for learning. Everything cut with .125 straight flute carbide from Home Depot. 50% stepover on the facing.
Old Apr 15, 2012, 09:46 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Looking good. Once you start with any type of machine, whether it's big dollars or not... you learn how incredibly simple these things really are. They look scary and intimidating at first but the fears go away quickly.
Small and inexpensive machines can be extremely useful, just not usually extremely fast. Enjoy your first machine, and use it to make your second machine... like I did.
tom43004 is offline Find More Posts by tom43004
Old Apr 15, 2012, 09:25 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Yeah, the first one has got to be the first one, and I am starting to get a grip on Cam software as well. Making a new router in the future is inevitable once I am proficient in 3d modeling. I am going to make some foamies and test out some designs. When I get one I really like I will scale up the Cad File and the router and use the part as a plug to make molds from!
Build Log "done by ourself" cnc router and hotwire cutter.now with video. clausxpf CAD/CAM 23 Jan 05, 2013 06:58 PM
Question CNC router Kit ? marcel76 The Builders Workshop 6 Feb 21, 2009 05:50 PM
Found Allegro UCN5804b stepper controller chips for cnc router or foam cutting stealthy Aircraft - General - Miscellaneous (FS/W) 0 Feb 05, 2006 09:46 PM
CNC router kit choice? Coder The Builders Workshop 3 Oct 15, 2002 09:45 PM
