Old Nov 21, 2012, 12:48 PM
ccpdx is offline
Find More Posts by ccpdx
United States, OR, Hillsboro
Joined Jun 2010
You're welcome. Glad it was useful! Good luck on the weather. It looks like it may be dry just for the one day (turkey-day) here too.
Charles
ccpdx is offline Find More Posts by ccpdx
Old Nov 22, 2012, 05:05 PM
JayDoc is offline
Find More Posts by JayDoc
United States, PA, Pittsburgh
Joined Jul 2012
Well - I can certainly say that it is a blast to fly, and all of the time that I spent visually/mechanically trimming before I left worked pretty much perfectly. One click right aileron, one click down elevator and it was like an arrow hands-off. BUT...
Holy cow was this thing tail heavy from hell with a Nano 2650 all the way forward It flew really well at WOT, but had a bit of coupling in knife edge so I knew it was at least a BIT tail heavy - but it was worse than I thought. When coming in on final, I rolled the throttle down to just below 50% and it started an immediate climb. After a go-around, I tried to bring it in hot but I would have had to hold the nose down steeply and land it hauling-@$$. This wasn't going to work even on the manicured grass strip. I managed to coax it down after much sweating, only to have one of the wheelpants catch (after rolling 15-20 feet already, mind you) and whipped the plane around, threw the wheel out (axle/screw now MIA) and cracked both wheelpants
Wow is this 'plastic wheelpants clamshell tension necessary to hold axle in place' setup crappy. I ended up taking the whole thing off, bending the gear back in place, pushing the blind nuts out of the wheelpants and just using a couple extra screws with those nuts and a dab of Loctite CA to affix the wheels back on to the bracket by themselves.
The CG measured out somewhere over 110-115mm I guess I'm going to have to pick up a 3300mAh battery just to try - the 2650s don't seem to work well at all. Oh, and I would like to smack the design team responsible for the metal-thread tailwheel assembly - good grief.
JayDoc is offline Find More Posts by JayDoc
Old Nov 22, 2012, 05:21 PM
krexken is online now
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
Carve some foam and shove that battery forward! Lighten up that tailwheel assembly! Foamies were meant to mod! I love the size and looks of.this plane but have wondered how it would stand up to hard spins, tumbles and other high energy stuff. Perhaps someone can say?
krexken is online now Find More Posts by krexken
Old Nov 27, 2012, 12:13 PM
Donnyd21 is offline
Find More Posts by Donnyd21
United States, OK, Oklahoma City
Joined May 2012
This is what I would like to know, I am getting one of these planes next month (along with 2 others)
Donnyd21 is offline Find More Posts by Donnyd21
Old Dec 04, 2012, 08:52 AM
truevine77 is offline
Find More Posts by truevine77
United States, FL, Fort Pierce
Joined Jan 2007
Does anyone know what type of connector is on the esc? Where can I find a adapter for my batteries that already have deans connectors?
truevine77 is offline Find More Posts by truevine77
Old Dec 04, 2012, 08:57 AM
Donnyd21 is offline
Joined May 2012
^I got my adapter on fleabay
Old Dec 04, 2012, 09:05 AM
Joined Jan 2007
What type of adapter was it?
Old Dec 04, 2012, 12:28 PM
Longview, Tx
Joined May 2008
http://www.headsuprc.com/servlet/the...ers/Categories
Look like these? This place has fantastic prices and service. You can always solder a Dean connector to you ESC.
Old Dec 04, 2012, 01:16 PM
Joined Jan 2007
Yeah - thanks for the heads up. I do like shopping there. I was thinking of simply getting an adapter so I don't have to do that.
Old Dec 04, 2012, 10:52 PM
DriverRX8 is online now
Find More Posts by DriverRX8
Brain/Thumb Interlock Off
DriverRX8's Avatar
Joined Mar 2011
Wow, JayDoc! I'm so sorry to hear about your flight and damage. I fly my version 1 with a 311g 2650mah battery, and the plane balances just a few mm aft of recommended. I had originally put ballast on the firewall to get it to balance, but the ballast worked loose so I just took it off. I've flown with a 2650 battery and a 3000 battery with and without the ballast. The airplane flies great whatever the configuration. Maybe the version 2 starts out naturally tail heavy due to the single elevator servo at the back of the fuselage. The v1 has two smaller servos under the cockpit.
I'm with you on the wheel pants and axles. I wound up taking the wheel pants off for a while, and installing some dubro axles and larger wheels until I got to where I could land the plane smoothly. I later ordered a replacement gear set and installed it, and have since flown more times than I can count without damaging the pants or the axles. One thing I did learn, though: Put blue locktite on the axle nuts. The left gear (or was it the right?) always came loose because the rotation of the wheel was in the direction of unscrewing the nut. Also, I had to carve the foam off the gear where the pants attach in order to get a solid installation. Oh, and they taped a bag to the outside of the box that had longer replacement wheel pants bolts. They probably included them inside the box on the v2.
DriverRX8 is online now Find More Posts by DriverRX8
Old Dec 05, 2012, 11:32 AM
JayDoc is offline
Joined Jul 2012
Good point on the servo weight - there are 2 (rudder & elevator) decent-sized servos mounted on the tail of the v2, that could very well be what is causing the CG issue. I flew it with a 3300 pushed all the way forward last weekend (CG was reading just a few mm aft now), with better flight characteristics but still overly floaty on landing (just need to change my own landing input on the sticks).
The included screws that I used to mount the wheels sans-pants (heh) are really bendy, and I haven't found 4mm steel screws to replace them. Right now, I just have a washer and locknuts securing the wheels to the stock screws. How are you mounting the Dubro axles? Looking at the catalog pics, it seems like the threaded end is much larger than 4mm (to fit the stock gear bracket) - I did see the separate collars to secure the wheels on the 'axle', but how are you securing them to the bracket? Also - are you using the 3/16" or 5/32" Dubro axles?
Thanks!
Jay
Old Dec 05, 2012, 09:48 PM
DriverRX8's Avatar
Joined Mar 2011
Thanks!
Jay
Actually, I used 1/8th-inch axles. It requires enlarging the hole that the bolt-axle goes through by drilling it out with a 1/4-inch bit. Once you've done that, of course, you can't go back to the original bolt axles, or use the wheel pants. That's why I ordered another landing gear set from Nitroplanes once I had learned to reliably grease my landings. As you already know, the axles/wheelpants/gear doesn't do too well with bouncy landings. It's also a really good configuration if you are flying off of grass. It doesn't look as good as the wheel pants...
Old Dec 17, 2012, 09:50 PM
OKJeepin is offline
Find More Posts by OKJeepin
Controlled Chaos
OKJeepin's Avatar
United States, OK, Poteau
Joined Jul 2012
Looking forward to getting my Sbach, should be here today!
OKJeepin is offline Find More Posts by OKJeepin
Old Dec 18, 2012, 10:22 PM
OKJeepin is offline
Controlled Chaos
OKJeepin's Avatar
Joined Jul 2012
Got a present from UPS today!
The pilot was helmetless....
Had a warped aileron...
A few little nicks and scrapes like this...
But she is ready to go now after about 3 hours. Had to heat up and straighten the aileron. Remove the pilot and add a little weight to the front to meet the 95mm CG.
Still need to set the throws for the maiden. Any suggestions on where to start? The instructions are poor to say the least, but not really needed anyway as it is a pretty straight forward assembly.
It's my first "sport" plane and am thinking about low rates around 50% of max throws and 30% expo for the maiden, sound okay? I need all the help I can get!
Old Dec 20, 2012, 09:48 AM
Fired Up is offline
Find More Posts by Fired Up
Joined Apr 2012
Travel
Hight rate,max travel on aileron,elevator,rudder.Expo 60.On low rate half the travel on aileron elevator, expo 45.Thats where i start from. Freddy I have the sane size from hobby king.
Fired Up is offline Find More Posts by Fired Up
New Product Dynam Sbach 342 available now at Nitroplanes.com xplaneguy 3D Foamies 1959 Feb 08, 2016 08:14 AM
New Product Nitroplanes.com 55'' extra 330sc sneak peek flight! Nitro_Nancy Product Announcements 2 Oct 23, 2012 05:05 PM
Sold PRICE REDUCED SBach 50cc no RX or TX w/DLE 55 edge_pilot Aircraft - Fuel - Airplanes (FS/W) 1 Jun 22, 2011 08:47 AM
For Sale 3DHS 55"Extra , 47" Extra SR, 55" katana GoldCraft Aircraft - Electric - Airplanes (FS/W) 6 Oct 22, 2009 02:45 PM
