United States, NY, Cortland
Joined Sep 2010
A key question is what size prop can you swing, and what prop would you like to swing?
If you can swing a big prop you can go with a lower KV motor, 12 inches and you'll probably want 700-800 KV (at a guess). I have a 770 KV on my 5lbs trainer, similar specs, I think I can just fit a 13, but have stuck to 12 so far, 12x10 currently. I has a nice crisp sound to it on the static test. On 12x6 it was pulling about 55A on 4s (static test), haven't checked the 12x10. http://www.rcgroups.com/forums/showthread.php?t=1481669 Dave |
The high desert of Southern California
Joined Jul 2002
Using http://www.s4a.ch/eflight/motorcalc_e.htm online calc program. A Monster Power, Easy match from HK, Power 32 from Leaders, Gforce 32, Tacon 32 you should have around 5 plus pounds of thrust on a 12X6 APC "E" prop.
https://www.leaderhobby.com/product....=9394001223655 http://www.hobbyking.com/hobbyking/s...er_770kv_.html http://www.valuehobby.com/power-syst...g32-800kv.html http://www.hobbypartz.com/96m604-big...520-770kv.html http://www.hobbypartz.com/monsterpow...ess-motor.html They use a 60 amp ESC. They should fly the plane really well. Buzz. |
Joined Sep 2010
Well I've finished most of the hard stuff, still have a bit of touch ups I'm doing to the fuse but for the most part I'm ready to monokote the wings at the very least. Need to figure out if I'm modifying the landing gear or not.
![]() ![]() ![]() ![]() Well there's the wings all finished out and ready for monokote. I've gotten the ailerons refitted and rehinged. I've also gotten the ailerons recovered. Tomorrow I'll start the wings themselves. |
Joined Sep 2010
My motor specs may be off (it's an OK Hobby infinite 3025-770KV) so I will first say it may be my motor, but mine won't pull 5lbs thrust on a 4S 12x6.
It's pretty good, but not 5lbs good. It also runs out of thrust at a relatively low speed, climbout is much better with a 12x8, even better with a 12x10, but it will still spin the prop at about the same speed in a static test. Dave |
Joined Aug 2010
I just completed this kit a couple weeks ago. It has a Rimfire 32 and a 60amp ESC. I intended on using a 4S 3300 mah but the prop I had was too big. I had a 3S 2200 with me and it was able to fly with that. Got 5 minutes on the 3S. I have since adjusted the prop but haven't been able to get out due to weather. I didn't takeoff or land it but did fly it. The guy that did those other duties said the 32 and 4S should give me over 10 minutes and takeoff with half throttle. The kit was given to me by a friend. That was given to him by his brother. The kit was started then stored in his attic for years. The plans had to be re-scanned and I scanned the manual. It's a pdf document so if it would help I can send it to you. I got pics but I think it's on my comp at work.
Good luck with the conversion. |
Joined Aug 2010
I had looked on the GP site and didn't find the manual. Must have missed it. Anyway, the place I got the plans scanned and printed, I'll check and see if they have a way to put them on a disk. If so, I'll send a copy to you. If they don't I can have a set printed and send them to you.
| Thread Tools | |
| Discussion Need help with electric conversion of 40" PT boat | kgfly | Dock Talk | 45 | Aug 28, 2012 03:44 AM |
| Discussion PT 40 Original Version landing gear? | bgordon10 | Fuel Plane Talk | 3 | Feb 15, 2012 03:46 PM |
| Discussion PT-40 Conversion - Nose Wheel Question | mt_100 | Glow to Electric Conversions | 5 | Aug 03, 2009 02:05 AM |
| GP PT 40 Conversion to Electric ? | pjm21b | Electric Plane Talk | 2 | Oct 17, 2004 12:35 PM |
| GP PT 40 Conversion to Electric ? | pjm21b | Sport Planes | 2 | Oct 17, 2004 12:33 PM |
