This thread is privately moderated by twinkle, who may elect to delete unwanted replies.
Old Feb 23, 2012, 04:37 PM
twinkle is offline
Find More Posts by twinkle
It can't rain all the time
twinkle's Avatar
United Kingdom, Peacehaven
Joined Mar 2009
lightweight Jeckel
The New Jeckel has flown and has been finished in camouflage. After the test flight we modified it by fitting an undercarraige as the cost of cr props would make it an expensive model to land . It is lighter and still retains the same motors as the earlier versions . We fitted this model with differential throttles as we did not fit rudders to this one after several flights and problems we have fitted conventional rudders and removed the differential throttles the rudder servo has been fitted to the taiplane and an extension cable routed to the receiver .
This model also had a KFM 2 wing instead of my usual clarke Y section . The disadvantage was the transfers , these were difficult to make as they cover the step. The wires to the booms fitted in the front section of the section.
This version has a shorter tail moment than the earlier pair and a 5 inch longer wingspan. More photos are posted in the Jackal thread.
This version weighed 750 gms now with the bigger battery pack to balance the servo at the tail it weighs about 900gms .
twinkle is offline Find More Posts by twinkle
Old Jan 17, 2013, 12:52 AM
sweakyboot is offline
Find More Posts by sweakyboot
plane wrecker
sweakyboot's Avatar
United States, NH, Nashua
Joined Jan 2012
plans
Do you have plans for this plane? Where can I find them?
sweakyboot is offline Find More Posts by sweakyboot
Build Log Super Cub DIY lightweight Tundra Tires - v0.5 Phaeton Scale Kit/Scratch Built 90 Oct 09, 2015 12:05 PM
Discussion very lightweight glider around 1-1.5 meters? KillerCut Sailplane Talk 15 Apr 13, 2011 06:57 AM
Discussion Has anyone built a Lightweight Easy Star Version? tomcor Foamies (Kits) 24 Apr 08, 2011 12:45 PM
Discussion Most Opaque of Lightweight Iron-On Coverings E-Challenged Scale Kit/Scratch Built 17 Apr 06, 2011 08:31 PM
Wanted Lightweight video Tx/Rx, for use with GoPro Hero NathanC Aircraft - Electric - Helis (FS/W) 1 Mar 28, 2011 01:39 AM
