Old Feb 23, 2012, 02:19 PM
playaviation is offline
Find More Posts by playaviation
playaviation's Avatar
Scunthorpe, United kingdom
Build Log
45" Hawker Hurricane
Well having built the P-51 mustang and Spitfire
http://www.rcgroups.com/forums/showthread.php?t=1591426
while the wind is trying to blow us all into another county i'm gona tackle the ugly sister the Hurricane
This one i'll do step by step for those who wanted more pic's on the other build so here goes
the starting point is a plan i have of the balsa craft hurri which i've traced and cut the main pieces side profile wing profile fin and tailplane these i've cut from card which i use to cut the depron
playaviation is offline Find More Posts by playaviation
Old Feb 23, 2012, 03:28 PM
pjdog is offline
Find More Posts by pjdog
Jack
pjdog's Avatar
United States, FL, Hudson
Joined Feb 2010
Hurrican is not ugly.
She's a good looker.
Jack
pjdog is offline Find More Posts by pjdog
Old Feb 28, 2012, 02:47 PM
to laminate the fuzelage i use latex carpet adhesive (Morleys JM600)
The canopy i'm using for the build
http://www.ebay.co.uk/itm/3103757264...84.m1439.l2649
Any how started sanding the fuz and she's a lot slimer
Old Feb 29, 2012, 02:47 PM
John.E is offline
Find More Posts by John.E
West Wales
Joined Jun 2009
Looking great. Any plans in the offing (or have I missed them somewhere)?
Just finished reading 'Gun Button To Fire', what a plane
Subbed.
John.E is offline Find More Posts by John.E
Old Feb 29, 2012, 04:48 PM
http://www.ebay.co.uk/itm/Balsacraft...item35b9e95893
This is the plan i based the model on and my own imagination
Old Feb 29, 2012, 04:57 PM
Back to the build started on the wings this evening
i cut the 6mm bottom sht then marked on the rib positions twice(got them wrong 1st time!) sorted a piece of 3mm hard balsa and cut the spars i beveled the leading and trailing edge then cut the ribs and started gluing up
the next step once the other wing is done is cut the styrofoam centre stiffener
Old Mar 01, 2012, 03:10 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
you work quick!
Keenan smith is offline Find More Posts by Keenan smith
Old Mar 01, 2012, 03:28 PM
Originally Posted by k.smith459 View Post
you work quick!
Once i get an idea i go with it should be ready to paint monday next week had to work long shifts this week so behind a bit as the spit was 6 evening this has been a week already
Old Mar 01, 2012, 03:32 PM
Joined Dec 2010
Ohh ok
Old Mar 01, 2012, 05:06 PM
sat the fuz on the wings to see what we have upto now
Old Mar 03, 2012, 12:45 PM
Sheeting the wings
had an hour today to fine sand the wings and got the top sheet on one of the panels
Old Mar 03, 2012, 02:09 PM
Both wings sheeted now and she's nearly there
(wish i'd bought the paint today !)
Only got ailerons to cut out hinge and conect to the servo
instal elevator servo and conect then final glue up and paint
Old Mar 03, 2012, 04:20 PM
The collour scheme
Decided on this scheme
dark earth and green upper surface
1/2&1/2 black & white under surface
Old Mar 04, 2012, 09:49 AM
now with elevator servo installed the fuz halfs can be glued together then the final sanding can be done to blend them together
For Sale ESM Hawker Hurricane flycatch Aircraft - Fuel - Airplanes (FS/W) 1 Mar 11, 2012 05:49 PM
For Sale ESM Hawker Hurricane flycatch Aircraft - Electric - Airplanes (FS/W) 2 Dec 27, 2011 09:01 AM
Sold UNITRACTS Brian Taylor Hawker Hurricane Retracts $80.00 FREE SHIPPING!! stevster Aircraft - Fuel - Airplanes (FS/W) 3 Dec 14, 2011 07:25 PM
