Old Feb 23, 2012, 12:46 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Glass/Kevlar/CF D-Tube
I have a very nice flying RES Glider design with super strong wing spars... Only problem is flutter. I need to stiffen the wood D-Tube to prevent flutter at high speeds. I am considering using .5 oz. Kevlar on a bias wrapped around the D-Tube back ro the spar. I would most likely use surfacing resin as the adhesive. Anyone have experience with this? Will it work?
Jack
schrederman is offline Find More Posts by schrederman
Old Feb 23, 2012, 01:10 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
What is surfacing resin?
Carbon will do a better job at stiffening the structure than kevlar
wyowindworks is offline Find More Posts by wyowindworks
Old Feb 23, 2012, 03:23 PM
Joined Nov 2002
Surfacing resin is epoxy that is used for applying light glass to fuselages, etc... I know cf would be best for stiffening but can I buy it in that weight? I have never seen cf cloth at 1/2 oz.
Old Feb 23, 2012, 03:37 PM
Just fly it!
Cody, WY
Joined Nov 2007
That kind of resin is typically called a laminating resin. I wanted to clarify your intent because there are epoxy systems that specifically designed for surfacing table tops. These type of resins are often called surfacing resins and perform poorly as a laminating resin.
Where are you getting .5 ounce woven kevlar?
Old Feb 24, 2012, 08:08 AM
Joined Nov 2002
After looking last night, about the lightest available right now is .7 oz. That's not enough difference to sneeze at... I believe that was on the CST website.
So, do you think it would be worth the effort in torsional stiffening? I'm also considering a bagged D-Tube with balsa ribs aft.
Old Feb 24, 2012, 08:12 AM
Just fly it!
Cody, WY
Joined Nov 2007
Most 9 ounce discus launch gliders are done with a 2 ounce carbon D-box or 1.7 ounce kevlar.
Old Feb 24, 2012, 04:30 PM
jfrickmann is offline
Find More Posts by jfrickmann
Jesper Frickmann
jfrickmann's Avatar
Raleigh, North Carolina, USA
Joined Aug 2005
The lightest aramid weave I know is 1 oz. Do not use felt or matte, it will soak too much resin. The same is true for fabric woven from spun thread - there is some 0.8 oz stuff from spun thread. Consider 0.75 oz fiberglass.
jfrickmann is offline Find More Posts by jfrickmann
Old Feb 27, 2012, 02:51 PM
Joined Nov 2002
Will .75 oz. glass make it torsionally rigid enough?
Old Feb 27, 2012, 04:36 PM
Mr B.... is offline
Find More Posts by Mr B....
Mfg of the Marauder & Oculus!
Mr B....'s Avatar
Downey, CA
Joined Aug 2002
Jack 3/4 is to light go with 2.1 glass over the center and 1.4 glass over the LE top and bottom. If you use a white trash bag you can get must of the resin out with. If you need some give me a call.
PS What are you doing speed runs for with a woodie?
Merrill
Mr B.... is offline Find More Posts by Mr B....
Old Feb 27, 2012, 07:33 PM
Joined Nov 2002
I had a Homer Simpson moment, and thought I could do a full J launch with it... DOH!!!
PM me your number, if you don't mind, along with the best time to call so I won't be a bother to your family...
Jack
Wanted Trex 250 kevlar belts and cf tail push rods HeliCow2 Aircraft - Electric - Helis (FS/W) 0 May 01, 2011 07:09 PM
Discussion CF Tube and Rod Question? Quick61 Foamies (Scratchbuilt) 0 May 01, 2011 10:16 AM
Discussion Reinforce fiberglass fuse: glass, kevlar, or CF? cloud-9 The Builders Workshop 17 Aug 05, 2008 02:15 PM
Fiberglass/ S-Glass / Kevlar/ CF/CF Mix Gunny Aircraft - Sailplanes (FS/W) 2 Mar 22, 2004 08:43 AM
