Old Mar 01, 2012, 03:11 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Chochmah my email is e9rudebouy@hotmail.co.uk
Keenan smith is offline Find More Posts by Keenan smith
Old Mar 01, 2012, 03:12 PM
Joined Dec 2010
awsome plane!
Old Mar 01, 2012, 03:15 PM
chochmah is offline
Find More Posts by chochmah
HappyGoLucky
chochmah's Avatar
Germany, BW, Ibach
Joined Dec 2009
Send.
And, btw, you can use the Impeller Component in the File for the plans of the A225. The shroud and the tabs have the exact messurements of the ChangeSun 90mm 12 Blade.
Edit:
And if you got Realflight I could also send you the virtual model I made to help me figure out the CG / size of the control surfaces, wingtwist etc.
chochmah is offline Find More Posts by chochmah
Old Mar 01, 2012, 03:16 PM
Joined Dec 2010
ok
Old Mar 01, 2012, 03:28 PM
Joined Dec 2010
i saved the side withall formers then i mirrored and dissected it to get a complete structure and and all formers too! im a little worried about your amount of upthrust
BTW could you teach me to use sketch up properly as i only have the basics just about down
sent you an E-mail
Also thanks for drawing up the changesun fan i save it
i may use sketchup to design my Ant-225 but i need to learn how to use it properley!
Old Mar 01, 2012, 03:30 PM
Joined Dec 2010
i have the 2nd to latest realflight and im getting the latest realflght in a week so send me the file as it would be real useful
Keenan
Old Mar 01, 2012, 03:36 PM
chochmah is offline
HappyGoLucky
chochmah's Avatar
Germany, BW, Ibach
Joined Dec 2009
sent you an E-mail
The hull structure in the file is a complete plane, it's just partially hidden, unhide groupwise and you'll get the whole thing. Well, you have a point with the upthrust, it's 5 degrees and it is needed (I believe) at high speeds to compensate for the short fulcrum of the elevator. At low speeds it really is a problem, especially since the thrustline is far below the cg and the wings. Makes the plane do backflips if you're not carefull.
I don't know much more than the basics of sketchup myself. I use it to get bulkheads from the 3D model because it was easy to learn but it has it's limitations. Use Blender for 3D modeling.
I'll send you the model. Report back how you cope with the challenging characteristics. I can land it a below 30km/h.
p.S.: This is not made with the latest RF Version, I bought 4.5 used. Should import into your newer version without problems.
Old Mar 01, 2012, 03:44 PM
Joined Dec 2010
Chochmah my suggestion would be to add a thrust vector nozzle or paddle on the pitch to help with stability! man its pitchy when slow!
Old Mar 01, 2012, 03:48 PM
chochmah is offline
HappyGoLucky
chochmah's Avatar
Germany, BW, Ibach
Joined Dec 2009
Well, it's got 0% Expo. A Thrust Nozzle it to complicated, this is just a little quick & easy project build around two servos and an EDF. Besides, the real thing did not have one either.
Old Mar 01, 2012, 04:00 PM
Joined Dec 2010
how about a small see through plastic paddle coupled up to pitch (1 servo quick and easy) and it would greatly improve the flight characteristics
Old Mar 01, 2012, 04:03 PM
chochmah is offline
HappyGoLucky
chochmah's Avatar
Germany, BW, Ibach
Joined Dec 2009
Well, add one on the model and see if it works. If it does please send the modified model back to me, thanks.
Old Mar 01, 2012, 04:07 PM
Joined Dec 2010
ill see what i can do with my basic skills
Old Mar 02, 2012, 06:06 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
I think your WAY beyond basic skills K!
demondriver is offline Find More Posts by demondriver
Latest blog entry: RC Red Dwarf Starbug!
Old Mar 02, 2012, 06:08 PM
Joined Dec 2010
Lols
Old Mar 02, 2012, 06:11 PM
Joined Dec 2010
hey DD lets talk on chat
http://www.rcgroups.com/forums/chat.php
Discussion Antonov An-225 Ottomite Scratchbuilt EDFs 1 Apr 24, 2011 12:05 AM
Help! Antonov AN-225 plans needed Chaparro1973 Scratchbuilt EDFs 13 Apr 17, 2011 12:48 PM
Cool Aero Ace Scale Antonov An-225 catman529 Micro Ready-to-Fly 3 Mar 16, 2008 03:16 PM
Antonov AN-225 aids Electric Ducted Fan Jet Talk 12 Jan 17, 2005 06:03 PM
Antonov 225 anyone? microflyer77 Electric Ducted Fan Jet Talk 4 Jan 29, 2002 11:03 AM
