Joined Jun 2011
Hitec Eclipse 7 Pro (2.4Ghz) now in stock!
BRAND NEW!!! Hitec Eclipse 7 Pro 2.4Ghz System - starting at only $179.99
The fan favorite Eclipse 7 got a facelift and numerous upgraded features to create the highly anticipated Eclipse 7 Pro. Offering a high intensity white backlit LCD screen, ergonomically positioned, back mounted slider knob and ultra-smooth quad ball bearing gimbals, this advanced AFHSS 2.4GHz system is your next feature-packed radio! It possesses 16-model maximum storage, intuitive control switches and an array of telemetric functions including sensor monitoring and on-board receiver low battery warning. And it doesn’t stop there. The Eclipse 7 Pro provides specific programming for fixed wing, glow, gas or electric planes, helicopters and sailplanes! Let it make you a Pro! ![]() Basic Features: 7-Channel 2.4GHz Telemetric System 3-Model Type (ACRO/GLID/HELI) Programming 16-Model Memory Highly Sensitive 8 Ball-Bearing Gimbals Easy-to-Read Backlit LCD Screen Back Mounted Sliders for Easy Access Range Check Mode Auto-Assignable Control Switch Sensor Monitoring and RX Low Battery Warning Stick Mode Change Digital Trims 7-Character Model Naming Three Conditional Mixes per Model Memory Model Copy Sub Trims Two Flight Timers EPA 5 Programmable Mixes All Channel Servo Reverse Dual Rates on Channel 1, 2 and 4 Exponential Rates on Channels 1, 2 and 4 Data Reset to Defaults Throttle Cut Switch Auto Engine Cut Switch Engine Hold Trainer More details at: http://www.servocity.com/html/eclips...hz_system.html System can be purchased 3 different ways... 1) Transmitter & Wall Charger - $179.99 2) Transmitter, Wall Charger, Optima 6 Rx - $213.99 3) Transmitter, Wall Charger, Optima 7 Rx - $238.98 Click here to visit ServoCity.com and learn more about the new Eclipse 7 Pro! |
| Thread Tools | |
| Sold HiTec Eclipse 7 TX spectra module & 2.4GHz | huauqui | Aircraft - General - Radio Equipment (FS/W) | 4 | Sep 23, 2011 10:29 PM |
| New Product R6208SB 2.4GHz Rx from Futaba - in stock now! | ServoCity | ServoCity.com | 0 | Sep 20, 2011 08:46 AM |
| New Product Hitec Optic 6 Sport (2.4GHz) in stock now! $139.99 | ServoCity | ServoCity.com | 0 | Aug 19, 2011 09:06 AM |
| New Product Hitec Optic 5 (2.4GHz) Tx - In stock now at ServoCity! | ServoCity | ServoCity.com | 0 | Aug 05, 2011 03:49 PM |
| Discussion Hitec 2.4ghz Module in Eclipse 7 Transmitter | E-Challenged | Radios | 2 | Jan 19, 2010 08:31 PM |
