Old Feb 23, 2012, 08:00 AM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
Question
Parallel Connectors? where to buy them??
Hello
Anyone know where I can get a "parallel" servo type connector?
Something like this, but the connectors would be a servo type(ie...Futaba J)connector.
http://www.readymaderc.com/store/ind...roducts_id=771
http://www.rcdude.com/servlet/the-74...Harness/Detail
I'm trying to use 2x- 3s 2500mah Lipo to power my Futaba 9c.
rclab1 is offline Find More Posts by rclab1
Old Feb 23, 2012, 08:40 AM
Mike Freas is online now
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Originally Posted by rclab1 View Post
Hello
http://www.rcdude.com/servlet/the-17...Battery/Detail
Your links don't work but this is simple enough to make. If you have a soldering iron and some heat shrink it would take about 5 min.
Mike Freas is online now Find More Posts by Mike Freas
Old Feb 23, 2012, 08:45 AM
Johnnysplits is offline
Find More Posts by Johnnysplits
Tampa, FL.
Joined Jul 2010
Hello
www.cheapbatterypacks.com makes custom wires. Very easy and inexpensive.
Johnnysplits is offline Find More Posts by Johnnysplits
Old Feb 23, 2012, 10:51 PM
g725s is offline
Find More Posts by g725s
United States, CA, Laguna Niguel
Joined Jan 2012
good selection and pricing and service here: http://epbuddy.com/index.php?main_page=index&cPath=26
g725s is offline Find More Posts by g725s
Old Feb 24, 2012, 02:15 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Most radio manufacturers have them, so most model shops will sell them. Here's a selection http://www3.towerhobbies.com/cgi-bin...%2Fb%3Eharness
abenn is online now Find More Posts by abenn
Old Feb 24, 2012, 08:07 AM
rclab1 is offline
USA
Joined May 2010
abenn,
that "Y" harness will have a 'series' effect (increase in voltage),?
Im looking for a 'parallel' version of what you posted :-)
thanks for the Link bud:-)
Old Feb 24, 2012, 11:30 AM
abenn is online now
Joined Jul 2004
abenn,
No, all the harnesses in my link are parallel. There is no such thing as a series servo harness because normal servos won't work in series. Plug two servos into these, and the other end (small plug) into your receiver, and both servos will react exactly the same when you give some stick input.
Old Feb 24, 2012, 12:40 PM
rclab1 is offline
USA
Joined May 2010
abenn,
thanks, that makes sense, so I guess a 'regular' Y servo harness will work for me.
Wow, I learn something new everyday.
Thanks much abenn:-) :-)
Old Feb 24, 2012, 02:12 PM
abenn is online now
Joined Jul 2004
I've just re-read your original post and realised you'll be using the harness to parallel two batteries in your transmitter. No problem, regular Y-servo harnesses are correct for what you want to do
Question Where to buy Deans 4 pin connectors Mr. Wiz Hand Launch 14 Jan 05, 2012 05:44 PM
Discussion Where to buy antennae connectors? shadow102 FPV Talk 3 Nov 19, 2011 11:14 AM
Discussion Connectors, where can I buy them? WBFlyer FPV Talk 8 Aug 15, 2011 03:16 AM
Discussion Where can I buy single wire connectors. aerorotor Multirotor Talk 4 Jun 07, 2011 11:44 AM
Discussion where to find 'parallel' battery connectors? Nethole Power Systems 4 Oct 04, 2007 05:41 PM
