Feb 23, 2012, 08:17 AM
USA, AZ, Mesa
Joined Aug 2009
I don't understand. Your post states that you've been using a set of cross (Phillips) screwdrivers.
Do you not have a set of Hex drivers? If not, you DEFINITELY need to add a set to your tool box. Just get a good set.......bad tools are as bad as soft screws.
Im not familiar with the screws on a CopterX head/swash but if its not a 00 Philips than its probably a 1.5mm hex.
As far as the screw kit I believe that the CopterX 450 is the same as a Trex450SE V2. Get a screw kit for that model. Oh BTW Ive not heard good reviews on the RCScrews screw kit....seems as though some of their screws are soft also, and the kit doesn't have everything you need for your Heli.
Most people just buy the Align screws....they are cheap enough.
