Old Feb 23, 2012, 04:54 AM
mahbouni is online now
Find More Posts by mahbouni
Heli Hooligan
London
Joined Dec 2006
JST XH to CellPro 6s Adapter?
I have some 6s CellPro packs and I want to be able to check the battery voltage but my battery checker only has the JST XH pins. Is there an adapter I can buy?
mahbouni is online now Find More Posts by mahbouni
Old Feb 24, 2012, 09:34 AM
Howard Matos is offline
Find More Posts by Howard Matos
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Hi,
I'm sorry but we do not make an adatper to convert our JST-PA connector to JST-XH. Thanks.
Howard Matos is offline Find More Posts by Howard Matos
Old Feb 24, 2012, 11:18 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
This will work I believe
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
The JST-HX male end will match the cell reader nad I believe the other end will match the FMA LiPolys.
They are on back order but worth putting on an alert list ,perhaps.
Problem is that not that many LiPoly brands ever used the JST-PA connectors.
The spacing for the JST-PA is the same as used by Thunder Power but the housing ,keys and latches are different. I have modified TP balancing leads to work with FMA chargers / balancers and it is not reall difficult for a DIY type / model builder.
You could also purchase a 6S 7 lead JST -XH male pigtail (connector with leads) from most anywhere and purchase a JST-PA female pigtail from FMA and roll your own if you can solder and have heat shrink .
I have made so many adapters ( gender / brand ) changers over the years that I sometimes forget not everyone can solder or knows how to locate supplies.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Feb 24, 2012, 07:50 PM
Heli Hooligan
London
Joined Dec 2006
Charles
Thanks for the info Charles. I don't think that HK adapter is going to work because my 6s packs have two balance connectors. They look similar to ThunderPower but different housings. I might try your idea of modifying a ThunderPower adapter.
Wanted Cellpro 10S / JST-XH adapter rc4j Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 19, 2011 11:26 AM
Found Balance Adapter - Female JST-XH <-> Male Thunderpower 6S Wynn1427 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 02, 2010 08:17 PM
Found 6S jst-XH to TP balance tap adapter cables.... GunnyGlow Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 03, 2010 08:47 PM
Wanted looking for Cellpro Multi 4 charger adapter for JST-XH 2s and 3s balance plugs gbass01 Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 26, 2010 12:30 PM
Sold Female JST-XH <-> Male TP 6S adapter Steph280 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Dec 02, 2009 09:03 AM
