This thread is privately moderated by Ribble, who may elect to delete unwanted replies.
Old Feb 23, 2012, 01:25 AM
Ribble is offline
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
Mini-HowTo
Calculate Motor Amps from flying time
Motor Amps using battery MAH rating and flying time
Calculate motor amps from flying time
Motor amps ?
If you start with a full battery and get an accurate time how long the battery lasts, you can figure out the average current that the motor drew during those minutes.
Amps = (mah) x (1amp/1000ma) x (60minutes/1Hour) / (RunMinutes)
Amps = (mah) x (60/1000) / RunMinutes
Amps = 0.06 x mah/minutes
Example: Amps = 0.06 x mah / Minutes
Amps = 0.06 x 1000 / 6 = 10 amps average current
Amps = 0.06 x 1000 / 3 = 20 amps average current = 1000mah battery that lasts 3 minutes
Amps = 0.06 x 1300 / 3 = 26 amps average current
Amps = 0.06 x 1300 / 4 = 19.5 amps average current
Amps = 0.06 x 1300 / 5 = 15.6 amps average current
Amps = 0.06 x 1300 / 6 = 13 amps average current
Amps = 0.06 x 2000 / 6 = 20 amps average current = 2000mah battery that lasts 6 minutes
Amps = 0.06 x 2000 / 3 = 40 amps average current
Amps = 0.06 x 680 / 6 = 6.8 amps average current
Amps = 0.06 x 680 / 3 = 13.6amps average current
Amps = 0.06 x 900 / 6 = 9 amps average current
Amps = 0.06 x 900 / 3 = 18 amps average current
Well, more or less. Pick a ratio of MAIN/TAIL and apportion the total amps
A good ratio may be 3/1 where main = 75% and tail gets 25%
Ribble is offline Find More Posts by Ribble
Question motor spins backwards at start up from time to time 7oneWo1f Power Systems 9 Feb 06, 2012 12:45 AM
Discussion How much time would .5 amps knock of my charging time. skarface Batteries and Chargers 3 Dec 30, 2011 03:40 PM
Question How to calculate run time at max amps? Bugman Jeff Batteries and Chargers 4 Dec 17, 2011 11:59 AM
Discussion How to calculate flying time ? SpookiePower Batteries and Chargers 8 May 20, 2010 10:10 PM
