Old Feb 22, 2012, 11:51 PM
schnitzelwagen is offline
Find More Posts by schnitzelwagen
Cleveland Ohio
Joined Oct 2009
exceed monster 32 prop mount
i have 2 exceed monster 32 motors on my deuces wild and one came with a bent prop mount that causes a nasty vibration making the plane a basement decoration. does anyone know where i can find the mount or even a whole motor with one, no one has any instock and it doesnt look like they will soon.
schnitzelwagen is offline Find More Posts by schnitzelwagen
Old Feb 23, 2012, 04:26 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Exceed Monster 32 has a 5mm shaft.
Would a 5mm prop shaft adapter be what you need?
http://www.rcdude.com/servlet/the-Pr...ers/Categories
http://www.headsuprc.com/servlet/the...for-5mm/Detail
http://www.graysonhobby.com/catalog/...ter-p-345.html
http://www3.towerhobbies.com/cgi-bin...?&I=LXUA39&P=7
rick.benjamin is offline Find More Posts by rick.benjamin
Old Feb 23, 2012, 12:09 PM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
As long as the shaft isstraightm you have tow options - both involve collet or set screw prop adapters:
1) If you can, turn the motors around and mount them on the other side of the fire wall. Then put a prop adapter on the sharft sticking out the new fron of the motor. If the plane is already built, this is probably not an option, but you might be able to use a motor mount that will let you accomplish the same thing, but leave the motor in the same place.
2) Push the motor shaft out the front of the motor. Pull the wheel collar off the back and any snap rings. Then pull the whole bell and shaft out the front of the motor. Loosen the set screws attaching the bell to the shaft and remount the bell with the shaft sticking out the front. IIRC, the bell is a tight fit on the shaft and you'll need to use a press to get it out.
Another way of doing this would be to leave the motor assembled, but pull collar and retaining rings off the back of the shaft. IIRC, there's a groove at the back end of the shaft - install the snap ring into this groove, loosen the bell's set screws and press the shaft out until the snap ring is flush with the rear bearing.
Either way you get it there, you put a prop adapter on the shaft sticking of of the fron of the motor. You may need to adjust the spacers to get the right placement relative to the front of the plane.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Feb 23, 2012, 06:11 PM
Cleveland Ohio
Joined Oct 2009
i just need the screw on style mount
Old Feb 23, 2012, 06:25 PM
kwj48 is offline
Find More Posts by kwj48
probro 2567
kwj48's Avatar
Midlothian,VA
Joined Jan 2006
This should work.
http://www.valuehobby.com/accessorie...46-motors.html
kwj48 is offline Find More Posts by kwj48
Old Feb 23, 2012, 08:27 PM
Cleveland Ohio
Joined Oct 2009
epic win
Wanted WTB prop mount for exceed monster 32 schnitzelwagen Aircraft - Electric - Power Systems (FS/W) 2 Feb 19, 2012 07:29 AM
Discussion Help need a prop adapter for an Exceed Monster Power 15 luigirox Electric Motor Design and Construction 6 Oct 14, 2011 07:09 PM
Wanted prop adapter for exceed rc monster 32 schnitzelwagen Aircraft - Electric - Power Systems (FS/W) 0 May 17, 2011 11:01 PM
Sold Exceed RC Monster Power 32 NIB snoshoe62 Aircraft - Electric - Power Systems (FS/W) 5 Jun 28, 2010 05:23 AM
Wanted eflite power 32/ Exceed monster power 32 turbored21 Aircraft - Electric - Power Systems (FS/W) 6 May 28, 2010 11:37 PM
