Old Feb 22, 2012, 08:38 PM
bobdaeronort is offline
Find More Posts by bobdaeronort
"Five Easy Pieces"
United States, IN, Terre Haute
Joined Sep 2011
Five easy piece f-14 tomcat
With the weather outside delivering one windy rainy day after another, here is my latest build Project, the F-14 Tomcat in the MACH configuration designed in my "Five Easy Piece" methodology.
The Five Easy Piece MACH TomCat is 42" long with a 30" KFm2 wingspan the same size as my RCP Mig-29.
The Five Easy Piece protocol makes for a pretty light weight plane.
To reduce the prop-wash drag I created a leading edge hinge out of a 3mm carbon rod and plastic soda straws for the tailerons which like the F-18 Hornet are set below the main wing.
I'm using a two servo set-up three channel for the tailerons.
I'm going to use a Grayson Hobby Micro-jet v3 2200kv motor on the maiden (same motor as my RCP Mig-29). Then I will upgrade to the SMJv2 with a 7x5 prop to see if I can pick-up some speed.
Had to do a quick indoor glide test before the BABE came home but didn't get a video. It glides just like the MACH TALON.
bobdaeronort is offline Find More Posts by bobdaeronort
Old Feb 23, 2012, 03:51 PM
"Five Easy Pieces"
Joined Sep 2011
Cut her out yesterday and tossed her into the wind this morning when the rain cleared.
F-14 TOMCAT maiden .mov (6 min 8 sec)
Old Feb 23, 2012, 07:35 PM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
oh oh oh i want one....plans please. i'm all for low parts count and an f-14 to boot.....do you happen to have the open wing version?
TIA
Carl
smkn951 is offline Find More Posts by smkn951
Old Feb 23, 2012, 09:34 PM
"Five Easy Pieces"
Joined Sep 2011
TIA
Carl
I need to tweak a couple things then I'll post a link to my plan.
I wasn't planning on Building one but I could depict the wing at both extremes on the plans so you could do either. Also I could do a short video on how to assemble the Tailerons on the carbon rod.
This technique would come in handy on the F-15 ,F-18, and a few other fighter jets where the elevators are below the level of the main wing.
Old Feb 24, 2012, 07:32 AM
MK is offline
MK
Find More Posts by MK
MK
NJ
Joined Feb 2001
Nice! And those things hanging in the back wall there...
MK is offline Find More Posts by MK
Old Feb 25, 2012, 07:42 AM
"Five Easy Pieces"
Joined Sep 2011
Oh those?
'They're what I fly when I don't care what I fly'.
Here is the link to my Five Easy Piece F-14 MACH TOMCAT PDF Pattern.
http://www.mediafire.com/download.php?abn3ja7avpx3689
It plots out on 30"x40" paper to a 42" long bird with a 30" wing span.
Old Feb 26, 2012, 10:10 PM
kwelna is offline
Find More Posts by kwelna
kwelna
Joined Jan 2006
OK dumb question
What kind of foam are you using? It looks light blue? I am looking fora project using ready board or 1/4" foam from home depot\lowes
kwelna is offline Find More Posts by kwelna
Old Feb 26, 2012, 11:39 PM
bsfixit is offline
Find More Posts by bsfixit
bsfixit's Avatar
Sarasota, FL
Joined May 2009
Anyone feel up to converting that pdf to letter sized tiled? I need something like this with wind in the forecast for a while... airbrush it grey,, some decals or sharpies... It would look great!
bsfixit is offline Find More Posts by bsfixit
Old Feb 27, 2012, 06:08 AM
"Five Easy Pieces"
Joined Sep 2011
I have access to DOW Blue Core and Owens Corning Formular 1/4" x 24" x 48" fan-fold foam.
Most of the time I don't paint my planes till the second or even third build. It takes the testors craft paint very well.
The foam LOWES has around here is light green or gray and more flexible than the Blue-Core.
It will work if you use a bit more carbon reinforcement.
I make my pattern templates from foam core.
Old Feb 27, 2012, 06:10 AM
"Five Easy Pieces"
Joined Sep 2011
I have the "Scale and Tile" program but I haven't got it sorted out how to use it yet.
So if any one can do it and forward it to me I'd post it for everyone.
Old Feb 27, 2012, 07:47 AM
segraves is offline
Find More Posts by segraves
Joined Jan 2007
Send an email to the author of ScaleAndTile3. He will be glad to help you. Please include a complete description of your problem.
Cheers,
Bill Segraves
P.S. I downloaded your PDF, shortening the file name to "f14tomcat.pdf". In the GUI, I entered "f14tomcat.pdf" as Input, "f14tomcat" as Output, and checked the box that turns off the grids. The program works fine with your PDF, producing a 4 x 4 array of 16 tiles.
segraves is offline Find More Posts by segraves
Old Feb 27, 2012, 02:12 PM
"Five Easy Pieces"
Joined Sep 2011
Once again many thanks to Bill for his "scale and tile" software.
Here is the link to my F-14 MACH TOMCAT which Bill has graciously rendered in his "scale and tile" software.
http://www.mediafire.com/?la8o943bz01bs9o
Old Feb 27, 2012, 02:58 PM
"Five Easy Pieces"
Joined Sep 2011
Today's Sortie in the gusty winds.
F-14 Mach TOMCAT's Windy Sortie.mov (6 min 6 sec)
Old Feb 27, 2012, 03:48 PM
"Five Easy Pieces"
Joined Sep 2011
Cheers,
Bill Segraves
Bill, i did not mean to imply that I was having problems with your software I just have not had time to open and read the instructions and give it a whirl.
Thanks again for the help.
Bob
Old Feb 27, 2012, 03:50 PM
"Five Easy Pieces"
Joined Sep 2011
Oh Boy,
I wanna see pictures and videos when you do.
if you have any questions about the taileron connections just give a shout. tell me if you think I need to do a build video.
Bob
Build Log GIANT 210% Jetset44 F-14 Tomcat wilmracer Pusher Prop Jet Models 296 Mar 22, 2016 08:21 PM
For Sale F 14 tomcat turbonut Aircraft - Electric - Jets (FS/W) 4 Jul 18, 2011 12:32 PM
Discussion Which F-14 Tomcat would you recommend? NeilDahl51 Electric Warbirds 3 Apr 22, 2011 12:15 PM
Discussion F-14 Tomcat scrappus Electric Ducted Fan Jet Talk 1 Mar 14, 2011 02:57 PM
