Old Feb 22, 2012, 04:46 PM
flyboy320 is offline
Find More Posts by flyboy320
flyboy320's Avatar
Canada, ON, Burlington
Joined Sep 2004
Alternative to Xtreme Power System lipos?
I was about to order one of their 3S1P 2200mah lipos, but I see they are out of stock. After reading the thread describing their new 65c batteries, it seems they are not going to be stocking 3S any more. I was planning on using one of these lipos in my new glider and so I planned the balance of it based on using it (200g and able to produce at least 60amps). Anyone know of an alternative lipo weighing about the same at 200g, 2200mah capacity, and at least 30c rating?
flyboy320 is offline Find More Posts by flyboy320
Old Feb 22, 2012, 05:01 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
HobbyKing is probably your best bet.
JimDrew is offline Find More Posts by JimDrew
Old Feb 22, 2012, 05:04 PM
flyboy320's Avatar
Joined Sep 2004
I tried them, but all their lipos for the equivalent of what Xtreame was selling are quite a bit heavier.
After looking around some, it seems Thunder Power have very similar spec batteries (albeit at a steeper price), so I'll probably go with them.
Old Feb 22, 2012, 05:11 PM
Graeme Marion is offline
Find More Posts by Graeme Marion
Australia, QLD, Middle Ridge
Joined Mar 2003
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Turnigy® Lipoly packs $7:89
Spec.
Minimum Capacity: 2200mAh (True 100% Capacity)
Configuration: 3S1P / 11.1v / 3Cell
Constant Discharge: 20C
Peak Discharge (10sec): 30C
Pack Weight: 185g
Pack Size: 103 x 33 x 24mm
Charge Plug: JST-XH
Discharge Plug: XT60
Graeme Marion is offline Find More Posts by Graeme Marion
Old Feb 22, 2012, 05:14 PM
flyboy320's Avatar
Joined Sep 2004
Thanks Graeme, that's getting close
Although I need at least 60amps discharge for about 30 seconds or more.
Old Feb 22, 2012, 05:20 PM
Joined Mar 2003
TURNIGY nano-tech $18:28
Spec.
Capacity: 2200mAh
Voltage: 3S1P / 3 Cell / 11.1V
Discharge: 45C Constant / 90C Burst
Weight: 201g (including wire, plug & case)
Dimensions: 112x36x26mm
Balance Plug: JST-XH
Old Feb 22, 2012, 05:22 PM
flyboy320's Avatar
Joined Sep 2004
Now we're talking, thanks Graeme
Old Feb 22, 2012, 07:47 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The nano-tech, Thunderpower, Align, and others all use the exact same components and chemistry that our factory does, which comes from Japan.
Old Feb 22, 2012, 07:48 PM
flyboy320's Avatar
Joined Sep 2004
Thanks Jim....
Old Feb 23, 2012, 05:30 AM
JuanRodriguez is offline
Find More Posts by JuanRodriguez
The Villages, Florida
Joined May 2003
You should check out what HobbyPartz has to offer..... similar pricing to HobbyKing but they have free shipping for orders over $50 (USA only) and you don't have to wait 3 + weeks to get your parts....I know you're in Canada but the pricing is still great.
JuanRodriguez is offline Find More Posts by JuanRodriguez
Old Mar 31, 2012, 11:34 PM
Chrisg81983 is offline
Find More Posts by Chrisg81983
Joined Dec 2011
I would not use turnig packs if you gave me them for free I had a plane lite up in mid air the turnigy's were not up to the task like my hyperions, xps, and thunder power cells can not be beaten I have tried sky lipos and gens ace as well they are ok for planes and cars but can not handle my boating applications as they hit lvc under acceleration due to a very large voltage drop
Chrisg81983 is offline Find More Posts by Chrisg81983
Old Apr 01, 2012, 05:45 AM
flyboy320's Avatar
Joined Sep 2004
I did end up going with Thunderpower for my sailplane and have been very happy. Very low voltage drop under full power, you usually get what you pay for, they aren't cheap, but they work great.
Sold Xtreme Power Dynamax 127mm EDF System BILLYDSRC Aircraft - Electric - Jets (FS/W) 2 Nov 07, 2011 11:27 AM
For Sale Xtreme Power System 2.4Ghz Module Futaba 9z/Hitec TechZ Aircraft - General - Radio Equipment (FS/W) 1 Jul 16, 2011 07:10 AM
Discussion Twin Power system and Lipos skydve76 Power Systems 3 Jun 12, 2011 04:00 AM
Discussion What do people think of Xtreme Power lipos? LaurenceGough Batteries and Chargers 1 Jan 12, 2008 09:36 AM
Any cheap alternative for a power system for the Hyperion Mini-Cap? (36.5") gotime242 Power Systems 2 Aug 30, 2005 10:15 AM
