Espritmodel.com Heli Air
Old Feb 22, 2012, 11:40 AM
United States, CA, Berkeley
Joined Apr 2005
What Generator are you guys using?
I know this subject might have been beaten to death, but I can't find any good threads about it, so I ask the question: What generator are you guys using?
I need something to charge my Electra 12s 6600mah batteries. I have a cellpro8 and a maxamps 24 volts 1100 watts powersupply
I like the size and weight of the honda eu1000, but it is just enought for this, with no extra capacity to charge anything else
On the other hand, the 2000 is like 20 pounds heavier, but it will allow charging other stuff at the same time
I do load up my car for each trip, so weight is a consideration
Also, have you guys tried the Generac units? they are less expensive, but I wonder if they are reliable, easy to start, quiet etc...
Lastly, If anyone has a used one that wants to sell, let me know
Jack
Jack G Diaz is offline Find More Posts by Jack G Diaz
Old Feb 22, 2012, 01:04 PM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Jack
Jack.
I do sell Yamaha 2000 or 2400.
The 2000 is working great. It put out 1600 watts continues.
This new btw with factory warranty.
Tamjets is offline Find More Posts by Tamjets
Old Feb 22, 2012, 02:30 PM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Hi Jack:
I use the Honda 1000. The 2000 is better suited to our needs though.
The generics tend to be much louder then the Honda/Yamaha's.
The extra twenty pounds gives you a good workout!
gregg f is offline Find More Posts by gregg f
Latest blog entry: Electra
Old Feb 22, 2012, 02:46 PM
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
I currently use the Honda 1000. I've had it for years, beautifully quiet and reliable. It's now too small for my charging requirements though. Looking at upgrading to the 2000 watt model
You can't go past Honda or Yamaha, they are both awesome in my books. You get what you pay for. The cheap units are noisier and i've seen them upset club members when charging at the field. My little Honda, well you don't even know it's there.
Chris
icicles is offline Find More Posts by icicles
Old Feb 22, 2012, 02:56 PM
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
EU2000.... flawless
hoser is offline Find More Posts by hoser
Old Feb 22, 2012, 03:22 PM
Joined Apr 2005
Guys, thank for the advice. I'll stick to yamaha or honda, noise is a big deal for me. My club is in a very quiet and peaceful place, so i don't think an anoying generator will be welcomed. I thought the Generac brand was good (I guess is honeywell), but i don't want to experiment
Greg, with your 1000 unit, can you charge your 12s packs at 40 amps? that is about 675 watts. The 1000's are rated at 900, and you have efficiency losses at the power supply and the charger... what is your experience? I have never tried it.
Thanks again... sorry to ask so much, but is not a cheap purchase . I love the size and weight of the 1000, but don't want to find out that it is not enough for my needs
thanks a lot
jack
Old Feb 22, 2012, 03:42 PM
United States, NC, Monroe
Joined Nov 2007
Originally Posted by hoser View Post
eu2000.... Flawless
ditto
jtlittle is offline Find More Posts by jtlittle
Old Feb 22, 2012, 04:19 PM
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
jack
Err, 12 s at 40 amps is ~2000 watts
tom bacsanyi is offline Find More Posts by tom bacsanyi
Old Feb 22, 2012, 04:23 PM
Joined Apr 2005
You are right.... I forgot to mention that is a set of 3 4s packs, charged in parallel. (typical electra set up)...
So I'm actually charging a 4s, 20Amp pack at 40 amps charge rate (2 C's)
sorry for the confusion
Old Feb 22, 2012, 04:41 PM
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Jack for what it's worth I've been running the honeywell 2000 watt all last summer and it has worked great!!
it's quiet, I've heard the honda and the yamaha they are just a touch quieter then mine. The yamaha is the quietest
With that said as well as mine has worked at $569 bucks with shipping to my door I would never spend the $1300 for the yamaha
here is what I have:
http://www.electricgeneratorsdirect....tor/p6693.html
Ron101 is offline Find More Posts by Ron101
Old Feb 22, 2012, 05:46 PM
Joined Mar 2005
Jack,
I have a Honda 1000 running a 1150 watt power supply and 2 TP820's we charged 3 6s-5000, in about 20 min. running the 1000 to the max.
Tony
T-spin is offline Find More Posts by T-spin
Old Feb 22, 2012, 05:55 PM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
thanks a lot
jack
Jack:
I charge at 20 amps and the generator is putting out the max it will do.
Around 20 min to charge
powerlab 8
1400w 24v power supply
Old Feb 22, 2012, 06:12 PM
Joined Nov 2005
I've used this guy with success on charger a LOT of batteries
20 KW Generator
Item # 192
(1)
Only:$4,999.99
Unfortunately you'll get kicked out of clubs cause the semi that tows the thing takes up too much parking space and other people don't like the noise and stuff.
On a less serious note has anyone taking those Harbor Freight generators and put some sound proofing around them to make them more quiet?
86 shipped is kinda hard to ignore
erh7771 is offline Find More Posts by erh7771
Old Feb 22, 2012, 06:54 PM
Joined Dec 2011
I just bring my solar panles and charge all day 2 1600 power supplies for my 12s packs and the panels don't take up that much room. Cost me 400 bucks for the panels. Then when it rains I don't fly
Super Matt is offline Find More Posts by Super Matt
Reply With Quote  (Disabled)
Old Feb 22, 2012, 07:03 PM
USA, CA, Marina del Rey
Joined Jul 2010
WOW where di you get those from?
lightningmcnul is offline Find More Posts by lightningmcnul
Discussion Which air tubing quick disconnects are you guys using? TheTick Electric Ducted Fan Jet Talk 21 Dec 29, 2011 06:54 PM
Question What are Futaba RC FM receivers' are you guys using? LexusFPV Video Piloting (FPV/RPV) 20 Oct 30, 2011 04:23 AM
Discussion Flight boxes.....what are you guys using? big_poppa4904 Electric Plane Talk 22 Sep 10, 2011 10:30 PM
