Old Jul 26, 2012, 08:46 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
So "vaseline" seems a better option. That won't harm the paint and it's even good for your skin. At least when you take the version that has no acid.
SoloProFan is online now Find More Posts by SoloProFan
Old Aug 03, 2012, 01:34 PM
WSEN is offline
Find More Posts by WSEN
McCarthy, Alaska
Joined Jun 2004
My Westward 18 arrived yesterday. Looks real nice except there is a loose bulkhead laying in the open part of the hull. I assume it should be under the winch? Anybody with one of these care to take a look or post a photo of the hatch area. I looked on Horizon's website, but their photo of the hatch area does not show where the bulkhead should go.
WSEN is offline Find More Posts by WSEN
Old Aug 06, 2012, 11:30 PM
WSEN is offline
McCarthy, Alaska
Joined Jun 2004
Well I removed the servos and was able to see where the bulkhead went (to the rear) and also found a side stringer lying loose in the bottom. Got it all glued up now and the servos re-installed. I have a question though. When I turn on the transmitter the winch servo moves quite a bit from the un-powered position. Is this normal or do I have a problem with the electronics?
In my airplanes, you disconnect the battery. This boat seems to power down when the transmitter is shut off? The instruction manual leaves much to the imagination for a novice like me. Any help would be appreciated.
Old Aug 07, 2012, 12:04 AM
mrpenguin is offline
Find More Posts by mrpenguin
Australia, TAS, Penguin
Joined Mar 2012
Originally Posted by WSEN View Post
...(quote edited slightly)
.....I have a question though.
1) When I turn on the transmitter the winch servo moves quite a bit from the un-powered position. Is this normal or do I have a problem with the electronics?
2) In my airplanes, you disconnect the battery. This boat seems to power down when the transmitter is shut off?
@WSEN:
1) This is normal - the sailwinch will move to where the TX stick is telling it to be. If it is a drum type winch (I think it is) this could be a number of turns of the drum.
e.g. stick down = sails sheeted in = winch near one end of travel
e.g. stick up = sails sheeted out = winch near other end of travel
(You may need to also adjust winch endpoints depending on your setup)
2) You need to disconnect the boat battery - many boats have a switch - very convenient. If you leave it connected it will flatten the boat battery
mrpenguin is offline Find More Posts by mrpenguin
Old Aug 07, 2012, 01:03 AM
Dimitris76 is offline
Find More Posts by Dimitris76
United States, IN, Carmel
Originally Posted by raptor3d View Post
when i turn on the radio system the rudder works just fine the winch servo just tightens itself up that it pulls the sails down to the deck of the boat an wont release no matter where i put the throttle stick
Yeap, same happened to me the day before yesterday. I took it to Hobbytown USA and the boatguy told me that these sail winch servos are known to be problematic.
A call to Horizon and a new replacement servo is in the mail.
This happened unexpectedly after a couple of months of trouble free use. I sailed casually last week, put it on it's stand in the dining room and when I turned it on again a week later it was spinning constantly on one direction pulling the boom down. It looked like it had a faulty potentiometer.
I opened up the servo sprayed little WD40 and presto - It's working again! I'll keep the new for future replacement...
/Dimitrios
Dimitris76 is offline Find More Posts by Dimitris76
Old Aug 07, 2012, 01:20 AM
Originally Posted by HoverDown3K View Post
I tried hatch tape about a month ago, it peeled the paint off the hatch.. so make note....
Same here... The tape lifts flakes of paint off the hatch. It's bare grayish plastic now.
No problem with the hull's paint though!
/Dimitrios
Old Aug 16, 2012, 11:06 PM
WSEN is offline
McCarthy, Alaska
Joined Jun 2004
Finally maidened my Westward today. My first sailboat venture, and it was fairly successful. The lake was calm, but there was just enough wind to fill the sails and propel the little craft nicely.
Only minor glitch was that the mainsail boom was sticky. When I got home I took the joint apart and polished the surfaces and now it swings smoothly.
I did install a switch in the battery line as taking the batteries out of that holder is no easy task!
It seems the QC problems that HH has had with several of its recent airplanes may be showing up in the boats also. No biggies, but the boat should be ready to sail without removing the servos , gluing the bulkheads, etc.
Old Aug 17, 2012, 01:50 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Congrats on a succesfull maiden. Now let's see what it does with a stonger breeze.
I agree on the QC issues. Let's hope that this will improve. So far QC and after sales support is sets companies like HH apart from cheaper RTR stuff. Slipping on QC brings them closer to their competitors.
As for the battery holder, I would advise getting a soldered battery pack asap. These holders are notorious for contacts corroding, causing control glitches.
Old Aug 17, 2012, 01:30 PM
jzami is offline
Find More Posts by jzami
Behind the curve in Rock Hill
jzami's Avatar
United States, SC, Rock Hill
Joined Aug 2012
re: boat battery. I use a rechargeable battery with a normally closed contact. When I plug in the charger, it opens the circuit during recharge; i.e. feeds juice to the battery only. I keep the pig tail in my pocket and when there's a lull in the activity, I just plug the pig tail into the boat. I use the same technique on my planes.
jzami is offline Find More Posts by jzami
Old Aug 17, 2012, 04:19 PM
WSEN is offline
McCarthy, Alaska
Joined Jun 2004
I assume a 7.4 lipo would be satisfactory to replace the 4aa pack? I have plenty of them from my airplanes.
Old Aug 17, 2012, 04:20 PM
Darin Jordan is offline
Find More Posts by Darin Jordan
Team Horizon Hobby - Surface
Darin Jordan's Avatar
Renton
Joined Sep 2006
I haven't looked at the specs for the RX in this, but going from 4.8V to 7.4 could be an issue... I'll look into it and let you know...
I would think that the servos would have to be the HV servos to make this work...
Darin Jordan is offline Find More Posts by Darin Jordan
Old Aug 17, 2012, 04:24 PM
WSEN is offline
McCarthy, Alaska
Joined Jun 2004
Isn't 4 aa batteries equal to 6v, not 4.8?
(Nice to see Team Horizon Hobby on this thread! Thanks much!)
Old Aug 17, 2012, 04:34 PM
Renton
Joined Sep 2006
Well... technically, 4 BRAND NEW AA batteries would start at 1.5v/cell... but I think you'd find them at 1.4V-1.3V/cell pretty quickly. That said, they'd have higher V than NiMH....
I sent a note to my Spektrum and Pro Boat contacts... I'll get back to you as soon as I hear from them.
I still believe that the Servos wouldn't handle the extra V, which is why they make special HV (High Voltage) servos for this kind of thing.
Old Aug 17, 2012, 04:39 PM
WSEN is offline
McCarthy, Alaska
Joined Jun 2004
Thank you kind sir.
Old Aug 17, 2012, 04:50 PM
Renton
Joined Sep 2006
OK, answer, straight from my good friend, who is one of the Spektrum Engineers:
The rx will handle 2S, the servos won’t. All our receivers except the UMX stuff will take up to 9.6V input.
So, that's what I thought... the RX's are fine up to 9.6Vinput, but you'll burn up the servo.
It's not really cost effective, but if you REALLY wanted to run a 2S Lipo, you could install one of these VRs:
http://www.horizonhobby.com/products...ator-SPMVR5203
Or something similar....
Hope this helps!
Found WTT: My Pro Boat Brushless ESC for your Pro Boat Brushed ESC Diegoboy Boats (FS/W) 12 Dec 23, 2011 09:48 PM
Sold New Pro Boat 1800kv motor and Pro boat 60amp esc tunnelvision Boats (FS/W) 2 May 17, 2011 03:30 PM
Sold Pro Boat 36" Sanibel Sailboat RTR package Brother2 Boats (FS/W) 5 Dec 18, 2010 10:28 PM
Discussion A new Tunnel Hull boat from Pro Boat James K.G. Racing Boats - Electric 1 Jun 16, 2010 04:29 AM
For Sale Pro Boat Sanibel RTR Sailboat mark12 Boats (FS/W) 0 Jun 02, 2009 07:03 PM
