Old Feb 22, 2012, 05:55 AM
United States, LA, Baton Rouge
Joined Feb 2011
Seagull Yak-54 .90-1.20 update
Update
I made my first flight today and it went very well. I outfitted the plane w/ a CRRC 26cc engine, and HXT 12k servos (~210 ounce torque @ 6 volts). I am currently running a 16x6 prop which will be changed to either a 16x8 or 17x6 once the engine breaks in as it needs more vertical. The video attached shows a couple of clips from my third flight of the day. First a take off and climb out, then on to a low fly-by climb and into a semi flat spin. I say semi because I set the plane up a little nose heavy for the initial setup and I don't have full throw on my elevator so I couldn't get it to flatten out. This plane lands great and is very stable, i actually got it to hover at half throttle fairly well for me. The CG setup was done at the wingtip and came out at the line where the sheeting on the wing transitions into the unsheeted area.
Seagull Yak-54 CRRC 26cc Maiden Day (1 min 3 sec)
vmcdonald is offline Find More Posts by vmcdonald
Old Feb 22, 2012, 03:17 PM
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
killer!
let us know on the final prop choice. probably do good with an apc 16*8, 16.5*5w, 17*6 or a 17*6n maybe even a 17*8n.
email XOAR and ask them what propeller they would recommend. they have tons of props they dont list on their website.
Toysrme is offline Find More Posts by Toysrme
Old Feb 22, 2012, 07:24 PM
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
Do you fly at red stick?
GeetarJoe is offline Find More Posts by GeetarJoe
Old Feb 22, 2012, 10:12 PM
Keller, TX
Joined Aug 2005
16X6 is a bit small for your engine. I fly this plane on a 17X6 prop which gives good performance and lets me slow down easily for landing. 17X8 gives more speed, but I like the 6" pitch better for this plane.
You are probably going over 9K with your prop and your engine is probably happiest turning in the 8K to 9K range. Also, with gas engines, a "break in" prop is not required, fly it with your flight prop while it gets run in.
It's a nice plane, I'm sure you will enjoy it.
RCFVR is offline Find More Posts by RCFVR
Old Feb 27, 2012, 11:01 AM
Joined Feb 2011
No, I'm over near Erwinville at the Baton Rouge Radio Control Club field. Where do you fly?
Old Feb 27, 2012, 11:56 AM
Who Dat!
GeetarJoe's Avatar
Joined Sep 2011
I fly at the spillway club. You should come check us out. Are you going to the fun fly in thibadeaux?
Old Feb 27, 2012, 12:53 PM
Joined Feb 2011
I may have to do that, when is the Thibodeaux fun fly?
Old Feb 27, 2012, 06:28 PM
Who Dat!
GeetarJoe's Avatar
Joined Sep 2011
June 9. so far there's gonna be a bunch of us there. several big scale fliers too. i think one of our guys is bringing his 47% Yak so should be a nice show. i hope you can make it out and bring some buddies. of course you are also always welcome to drop by and fly with us.
For Sale Aeroworks .90 to 1.20 Yak 54 Parts samolocik Aircraft - Fuel - Airplanes (FS/W) 4 Jul 27, 2012 07:15 PM
Discussion Seagull Yak-54 .90-1.20 vmcdonald Fuel Plane Talk 9 Feb 08, 2012 06:06 AM
Sold Aero Works Yak 54 .90-1.20 NIB tab2ib Aircraft - Fuel - Airplanes (FS/W) 2 Jul 20, 2011 04:52 PM
Sold Aero Works Yak 54 .90-1.20 NIB tab2ib Aircraft - Electric - Airplanes (FS/W) 2 Jul 19, 2011 08:40 PM
Discussion Seagull Yak 54 .90 size w/evo 1.20 nx RCGill Fuel Plane Talk 6 Nov 08, 2010 06:09 PM
