Old Feb 21, 2012, 08:47 PM
jduvall is offline
Find More Posts by jduvall
Registered Rebuilder
United States, MD, Potomac
Joined Feb 2004
Question
Turnigy 9x w/ er9x and NiMH
I've flashed my 9x to er9x firmware. I use eneloops in all my other transmitters and was planning to use them in this transmitter as well. Should I be making some type of modification to the battery holder to reduce the number of cells? If the transmitter is happy on a 2s lxx, wouldn't the full tray of 8 NiMH be high on the voltage and cause some extra heat on the voltage regulator circuit?
The easiest mod I can think of would be to cut a dowel to the size of a battery and put a metal plate on each end connected by wire so everything fits in an unmodified battery holder.
Maybe I'm over thinking this.
Thanks.
jduvall is offline Find More Posts by jduvall
Old Feb 21, 2012, 10:06 PM
ttabbal is offline
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
I've run mine for about an hour then put my finger on the regulator and it wasn't real hot. I run on a 3s lipo. Lowering the input voltage will push the heat down, but I think concern over it is overblown. It was designed to use 8xAA (12v).
ttabbal is offline Find More Posts by ttabbal
Old Feb 22, 2012, 09:58 AM
erazz is offline
Find More Posts by erazz
erazz's Avatar
United States, NJ
Joined Jun 2004
Not really worth your trouble. We did a calculation a while back showing that the power dissipation is so low that the regulator only rises by 10-15 deg C in a really worst case scenario. It won't conk out with 8 NIMH batteries.
That being said, the holder is, to put it mildly, a piece of XXXX. I think that a substantial chunk of problems with this radio have to do with the holder. Just seems too flimsy to trust.
There are $9 LiFE batteries out there just begging to be put on a radio. Better to charge and lasts much longer. Why mess around with enelopes?
erazz is offline Find More Posts by erazz
Old Feb 22, 2012, 11:49 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Just get this, it's a PERFECT fit and I haven't had any issues with it.
http://www.hobbyking.com/hobbyking/s...dProduct=17955
However, you need one of those 4-button chargers to charge LiFe batteries. (Such as iMax B6)
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 22, 2012, 08:00 PM
jduvall is offline
Joined Feb 2004
Guys,
thanks for the input. some things to think about.
Sold Turnigy 9X w/ NimH Batteries and 4 receivers Whoaty55 Aircraft - General - Radio Equipment (FS/W) 5 Nov 03, 2011 09:57 AM
Discussion Why I like the Turnigy 9X w/ ER9X firmware fregon45 Radios 13 Oct 06, 2011 09:31 PM
Discussion Turnigy 9x + Frsky + er9x JasonR54 Radios 3 Jul 05, 2011 12:16 AM
Help! How can use switch Turnigy 9X(FW. ER9x) in Simulator NiceOh Simulators 3 May 21, 2011 11:51 AM
Sold ER9x Eurgle 9x tx w/Frsky ACCST and 4rx panzerdivision Aircraft - General - Radio Equipment (FS/W) 1 Mar 31, 2011 09:09 AM
