Espritmodel.com Heli Air
Old Feb 21, 2012, 07:38 PM
DL8698's Avatar
Singapore
Joined Mar 2008
Cheap Glow Plug Igniter by Lazy B
Ref the above at http://www.rcgroups.com/forums/showt...ry#post2947786
The circuit diagram in post #7 looks simple enough for even me to handle. However, I know very little about solid state devices, and I am wondering about the voltages quoted in post #5, (3.05 v for the lithium-ion battery). I assume I can use a single lipo cell from a junked 3s pack, but it has more like 4+ v per cell when fully charged.
Does that make the output 4.2-1.8=2.4v which is too much for the glow plug. Should I put a variable resistor (somewhere?). I can get the LM388 here, cheap, and it has an adjustable output of 1.2-33v.
Or should I put a fixed resistor somewhere, to simplify and make sure the output is fixed, not inadvertently bumped too high. But then as the battery volts drop, the output would also drop, I think, to below what is needed for glow plug power.
DL8698 is offline Find More Posts by DL8698
Old Feb 21, 2012, 11:00 PM
Stuart
UK, Cardiff
Joined Dec 2008
Well when you realise a Lithium Ion battery is 3.6v nominal, you do wonder if the rest of the info is good.
srnet is online now Find More Posts by srnet
Old Feb 22, 2012, 07:23 AM
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
Much easier to simply use a single Sub-C size Ni-Cad or Ni-MH cell. Less weight, no need for resistors or anything else, and they can be found now rated at ~2000mAh for just a couple of dollars. Just my opinion.......
Are you trying to rig a glow driver for starting your plane, or an on-board glow driver to keep the plug hot?
dmccormick001 is offline Find More Posts by dmccormick001
Old Feb 22, 2012, 02:33 PM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
+1,
A glow ignitor using a sub "C" Nicd cell is the embodiment of K.I.S.S
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Feb 22, 2012, 07:35 PM
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Using resistors, diodes or a linear regulator you will be wasting over half of the power from a lipo when using it for a glow driver. Using some form of PWM is really the only good way if you want to use a lipo to drive a glow plug. If not then go with NICAD or NIMH like the others said.
jeffs555 is offline Find More Posts by jeffs555
Old Feb 23, 2012, 06:52 PM
DL8698's Avatar
Singapore
Joined Mar 2008
I have found some old, nameless, brandless, AA nimh 1800 mah cells in my box of old batteries which can light the fire just fine, so I dont think I will bother with anything more complicated.
Old Feb 24, 2012, 07:56 AM
Dave the Rave
Joined Jun 2007
I was recently reminded of the importance of the K.I.S.S. principle at our field. A friend had a brand-new plane, a Hangar 9 Katana with an OS 1.20 4-stroke on it, very nice, but my buddy was having some trouble with it, sometimes when he turned it on it came on OK, other times it didn't. He asked me to look at it, and I discovered that some of the other guys in our club had convinced him he needed to go with an A123 pack, why I don't know because he never flys his planes that much or that often in the same day, but he followed their "advice". Of course, the 2-cell A123 pack required a voltage regulator, and they also convinced him to use redundant switches, etc. The wiring in this plane looked like the space shuttle, and we didn't know if the problem was a switch, the battery pack, the regulator, or what. In trying to troubleshoot the problem, I suggested he go back to the basics, and offered him a fully charged Ni-Mh pack I had in my flight box to start eliminating possible problems. He refused, I guess that was too old-fashioned for him, and he continued to mess with his system. Later that day he flew the plane with the system he had still in it, and on the maiden flight it made 1/2 a lap around the field, stopped responding to the transmitter, and went in wide open in a shallow dive. The debris field was 100 feet long.
We eventually found out that the regulator was the problem. But this particular plane didn't need all that extra weight or complicated stuff. All he needed was a good battery pack and blue skies. Too bad.
Old Feb 27, 2012, 10:54 AM
pilotpete2's Avatar
Joined Jun 2004
"Of course, the 2-cell A123 pack required a voltage regulator"
Not if the servos are rated for 5 cell Nimh operation
Pete
Old Feb 27, 2012, 12:38 PM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
+1 for Dave ...
regulators are most of time too weak to handle the servos peak current draw, and/or are not able to dissipate enough heat ... some measures I recently made have shown peak currents really are impressive, and with the use of " ordinary" wiring, often cause receivers resets ...
I give you a link to the " voltspy " device : purpose is to measure voltage @ receiver plugs, and catches the minimum reached voltage ...
http://www.modelisme.com/forum/1845101-post46.html
the last software version also gives flight time before dangerous voltage reached ... ( upon request ! )
Surprises guaranteed !!!
Alain
Acetronics is offline Find More Posts by Acetronics
Old Feb 29, 2012, 12:25 AM
DL8698's Avatar
Singapore
Joined Mar 2008
Originally Posted by Acetronics;20874132
I give you a link to the " voltspy " device : purpose is to measure voltage [B
@ receiver plugs[/B], and catches the minimum reached voltage ...
Alain
Surprised me, that's for sure! That links to a site in le francaise. Moi non parlai francaise! or something like that!!
Old Feb 29, 2012, 01:26 AM
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
Cheapest.
I did delete to content.
It was't topic related, sorry.
Taurus Flyer is online now Find More Posts by Taurus Flyer
Old Feb 29, 2012, 04:59 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi,
I went to Singapore some years ago ... but still do not speak Chinese or Malay ...
Seriously ... I'm French ... this explains that ...
If you need some details, do not hesitate to ask for ... I'll answer you in English
Alain
PS; Even Frenchies can deal with model electronics ...
Old Feb 29, 2012, 05:54 AM
DL8698's Avatar
Singapore
Joined Mar 2008
Originally Posted by Acetronics View Post
Hi,
Alain
No offence meant. I did try to learn french (optional subject), long, long ago in school, but gave up after a couple of months. Very hard language to learn! Male and female for everything! And the pronounciation was very hard to master.
Old Feb 29, 2012, 09:27 AM
Dave the Rave
Joined Jun 2007
French 'aint hard to learn, all ya gotta do is add a "voo" to the end of everything.
Old Feb 29, 2012, 10:47 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Dave
That's too simple to be fine ... let's see :
if I add voo to "Dave" ... for example ... I get Davooo.
And here, Davoooo is the gentle name for Dave - the - gay ...
TRUE !!!
Alain
For Sale Rc os max 40 nitro engine master airscrew prop fuel tank & glow plug igniter t.korb Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 22, 2012 12:46 PM
Discussion What type of glow plug igniter? wakslob Beginner Training Area (Fuel) 14 Nov 19, 2011 06:01 PM
Wanted glow plug igniter charger kartooo Aircraft - General - Miscellaneous (FS/W) 3 Oct 21, 2011 12:11 PM
Whoops! Glow Plug Igniter Fried my Glow Plug! bruintriton Beginner Training Area (Fuel) 21 Jul 10, 2010 10:04 PM
Cheap Glow Plug Igniter lazy-b DIY Electronics 10 May 10, 2005 03:16 AM
