Old Feb 21, 2012, 04:56 PM
mazjag is offline
Find More Posts by mazjag
Marietta GA.
Joined Jan 2011
best way to modify engine mount help?
Guys, I`m trying to fit a Saito 100 in my Katana 50 where I had a .82...Here is the problem the 100 has a pretty good bit wider crankcase and won`t fit in between the factory beam mounts.I tried to drill the holes(on the mounts) out to give it some slop, but its not enough..I recognize the best way would be to redrill it and insert new blind nuts but they would right on time of what I have in there for the .82..Whats the best way to get this corrected?? here is a pic...
mazjag is offline Find More Posts by mazjag
Old Feb 21, 2012, 05:01 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Remove the motor mount, then pop the blind nuts out. Fill in the holes with epoxy and a filler such as sawdust or micro balloons. Then after the epoxy cures, mount the engine and mount up to the firewall, mark the new hole locations and drill them. Insert the blind nuts, etc and you are in business again.
I like to save some of the sawdust I collect from sanding balsa and plywood when building a kit up. Then I take some sawdust and mix with the epoxy to make a filler paste to use for things like this. Of course you can get some microballoons to use for the same purpose too.
earlwb is offline Find More Posts by earlwb
Old Feb 21, 2012, 05:36 PM
mazjag is offline
Marietta GA.
Joined Jan 2011
thanks! thats why I asked...Jason
Old Feb 22, 2012, 07:54 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You are welcome. Another source is to get yourself a container, and watch around your area for someone doing some repair or construction work with a tablesaw. They'll usually let you get some of the sawdust left over after they've sawn some boards. Of course they might think you are a bit touched though.
Old Feb 22, 2012, 06:52 PM
GeetarJoe is offline
Find More Posts by GeetarJoe
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
the sawdust method works, but what i do is make sure i have an assortment of small dowels handy. sizes between 3/16 and 1/4 are usually sufficient. when i need to redrill a firewall i just pop the T-nuts out (a soldering iron inside the threaded portion of the nut helps soften the glue) then drill out the hole to fit my dowel. put some epoxy or thick CA on the dowel and the hole, and push it in. when the glue dries, cut it off flush and sand it flat. you can fuel proof it if you need to after that.
the dowel makes the firewall redrillable and it wont cause your bit to creep if you have to drill through one part of your dowelled hole. an added benefit is that one 24" dowel is enough to last you virtually until the end of the universe since youre only using 1/4" at a time.
GeetarJoe is offline Find More Posts by GeetarJoe
Old Feb 22, 2012, 10:23 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Washington
Joined Apr 2009
You might try one of the Dave Brown round mounts if you have the room. You could transfer the firewall blind nut pattern to the new mount and drill it out to match. The one below is a 90 size, but they also have a 120 size.
http://www3.towerhobbies.com/cgi-bin...?&I=LXB880&P=7
tacx is offline Find More Posts by tacx
Old Feb 23, 2012, 09:41 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
I just go down to Home Depot or Loews and buy a dowel the same size as the holes, cut off small pieces and glue them in the old holes. The dowel will last forever and provide many opportunities to be used in the future.
I also go to Harbor Freight or Northern Tool and buy a set of extra long drills. They usually have five in the set and range up to a 1/4 inch in diameter. Makes it nice and easy to redrill holes for throttle rods/cables. Allows one to drill through formers located further back in the fuselage for routing the tubing that carries the throttle rod/cable. And I use the same dowel to glue up that old hole too.
Chip01 is offline Find More Posts by Chip01
Discussion New Orion-best way to mount servos... Doug913 Electric Sailplanes 11 Dec 11, 2011 02:50 PM
Discussion Best glue and best way to glue servos in Wild Bill 3D Foamies 7 May 30, 2011 06:23 PM
Discussion Best way to mount a one piece wing Fly2High Hand Launch 15 Mar 27, 2011 09:57 PM
Discussion Best Way to Modify Easystar Rudder for FPV kyle7119 FPV Talk 15 Dec 10, 2009 04:40 AM
Question Best way to Modify a Servo for 360deg rotation? pezzer2003 DIY Electronics 11 May 28, 2009 12:28 AM
