Old Feb 21, 2012, 04:43 PM
sweatybetty is offline
Find More Posts by sweatybetty
sweatybetty's Avatar
United States, OR, Roseburg
Joined Jan 2012
landing a tail dragger
i have clearview and realflight and have been fine landing a front wheel plane like a skylane. for some reason i cannot land a piper cub. ive tried more throttle, less throttle, more and less elevator. any advice?
thanks all
sb
sweatybetty is offline Find More Posts by sweatybetty
Old Feb 21, 2012, 05:39 PM
ErcoupeEd is offline
Find More Posts by ErcoupeEd
ErcoupeEd's Avatar
United States, IN, Grabill
Joined May 2004
Sounds like you are trying to flare on landing which doesn't work with a tail dragger
Learning to land on all 3 wheels at the same time takes practice.
On a tail dragger, land with the airplane horizontal, tail still up off the ground, then gently pull back the power and let the tail settle in.
Just keep practicing!
Keep jusst a little power on, when the mains touch, pull back the power and let the tail settle and come down
ErcoupeEd is offline Find More Posts by ErcoupeEd
Old Feb 21, 2012, 08:17 PM
Joined Jan 2012
ill give it a try. thank you!
Old Feb 22, 2012, 11:22 AM
mwilson914 is offline
Find More Posts by mwilson914
Joined Sep 2008
Do you go by clownpounder in Realflight multiplayer? Just curious.
mwilson914 is offline Find More Posts by mwilson914
Old Feb 24, 2012, 03:36 PM
Joined Jan 2012
no, thats not me
Old Feb 24, 2012, 03:58 PM
jeffpn is offline
Find More Posts by jeffpn
Joined Mar 2011
RF Multiplayer. Bah!!
jeffpn is offline Find More Posts by jeffpn
Old Feb 29, 2012, 02:11 PM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
Actually yes you can do a 3-pointer with a taildragger. But, it takes practice.
The trick is to slow your model in stages with reducing the throttle as you come around for your first leg of your approach, do this while you lightly increase the elevator up-trim so that it's slowly descending with it's nose slightly high. Do this is slow increments. As you approach the end of the runway on your final, pull the throttle all the way to idle slowly as you cross the end of the runway and let it settle while gently pulling in more up-elevator.
It will take some close observation but the model must lose some airspeed and start to descend a bit with it's nose still slightly up. When you get about a foot off the ground, then pull in a bit more up elevator and let it settle. It may not fully settle on all 3 wheels, but if it doesn't stall, and drop like a rock you know you can pull in more next time
Practice this with gentle flying, big wing area models at first.
Looooeeee! is offline Find More Posts by Looooeeee!
Discussion Fixed tail wheel or movable on tail dragger tyra Fuel Plane Talk 11 Aug 26, 2011 03:33 PM
Best landing gear type for Easy Star -- trike or tail dragger? JohnSoPA Foamies (Kits) 11 Aug 07, 2008 10:15 PM
Help! Best landing technique for tail dragger? rcgroupie Electric Plane Talk 16 Sep 07, 2006 01:56 PM
Discussion Warbird tail dragger landing technique Curtis Miller Beginner Training Area (Aircraft-Electric) 11 Mar 22, 2006 03:39 PM
