United States, MI, Vassar
Joined Jan 2006
Florio Yankee Twister fun fly and other designs by florio.
It has been a pleasure to see this kit made available again by Dan Fedorko at greatflyerrc@yahoo.com. or http://greatflyerrc.com is his web site.
This is one of the few planes that started the funfly craze back in the early 90's. I flew and built them and found they were able to fly low and slow, do extreme aerobatics off the ground and was great on ski's. It is a pod and boom design and V-Tail configuration. It is not designed for high speed flights so a 10-3, 10-4 or 11-3,11-4 pitch prop is used. Because of the huge ailerons and wing cord it could flutter at high speeds, if you load the airframe in manuevers it can be at full throttle. They are powered by a 25-40 2 stroke and a 48 ish 4 stroke also is impressive. The build is straight forward and a beautiful plane is produced. I elected to make a electric version with a exceed rocket motor 3020-1000 kv and a 2200 3s lipo. It's comparable to a glow in performance I did modify the nose slightly to hold the battery and a firewall mount. With a computor radio you can enable delta mix for the tail. This enables rudder /elevator control. This allows you to do some super fast direction changes and other rudder controls manuevers. I use elevator/flap mix and delta mix together. Can also program spoilers for stopped descents for spot landings. This plane can be stopped in a headwind and hovered. It flies in wind and will increase your pilot skills. This is a perfect plane to do touch and goes in front of you and close flying It's a blast Do yourself a favor and contact Dan and order the coolest plane designed. Any questions I can answer on the build or flying. or contact Dan who has taken on a great challenge for the greatness of this sport to keep it alive for us who enjoy building and flying. He has taken over the Florio Line of planes and is selling the kits and willing to help in any way to make each kit a success. |
Joined Jan 2006
For all of the florio planes contact Dan. His new website is up and it's http://greatflyerrc.com His kits are topnotch. His service is immediate and help is always around if you need it. I'm familiar with the stuntwagon and Yankee Twister planes and can help if needed.
Hi Mark,
looks like you did a great job on the planes. I know you finished the Yankee Twister and have been flying it and you must be close to getting the Stunt Wagon done. It sure didn't take you long to build them. Thanks for the great compliments on the kits, I really appreciate that. The web site is http://greatflyerrc.com/ and still is under construction but there is enough info on it to get started. The weather has been so nice the last few nights that I finally shut off the saws and did a little flying. I took my electric Nifty 50 and the new Flyer Jr. electric out for a test flight. The Flyer Jr. was another one of John Florio's designs. It's a Flyer .25 with a E-flite .15 out runner and a 2200 mAh lipo in it .Like all of John and Jim's designs,,,it flys great. Now I gotta find a way to kit this one too. I'll have to get some photo's of it too ya. Hope the weather is nice this weekend, gotta get the Twister and Stunt Wagon out. Talk to ya later, Dan |
Joined Jan 2006
Fixed website link for Dan at http://greatflyerrc.com
Joined Jan 2006
Florio Stuntwagon build
Another great kit from Dan at http://greatflyerrc.com.
Built to plans and no modifications added or needed. The wing is glued to the fuselage and radio is inside the bottom part of the wing that the mid section remains unsheeted. It is light but very strong to take abuse from flying. I have powered mine with a .46 which is a little over the recommended. With throttle management and a 11-3 prop should be able to perform any manuever with ease. It has a split tail meaning to control rods are used into one. I used 2 wheel collers and some copper wire wrap and silver solder to join. 2 aileron servos are used and enables elevator/ flap mix, camber, or whatever else your radio can do. It balances a little nose heavy with the .46, after test flight might add a little weight to the tail. The wire gear will take anything. That is two pieces wraped and soldered also, super strong design. It's a unique look and I have seen these fly back in 1993. Very smooth, precise, but open it up and it will dazzel the sky. This is also a perfect canidate for electric conversion. you can make it both by making a plate to attach to the hardwood motor mounts and use the engine screw holes to the plate. I used a micro servo for the throttle and that can be disconnected or removed. The tank compartment will hold the batteries and esc. A little time and effort on your part to make the switch, but can be done. I hope you enjoy the pics as much as I have building it. |
| Thread Tools | |
| Video Grace Family Fun Fly - Indoor flying fun! | Jim_Marconnet | Electric Heli Talk | 0 | Oct 17, 2011 03:40 AM |
| Video RCAA Comox Valley Float Fly Fun Fly | bwoollia | Electric Plane Talk | 0 | Sep 27, 2011 06:16 PM |
| Discussion Fun fun fly planes... | Evan D | 3D / Fun Fly Fuel Planes | 2 | May 26, 2011 08:54 AM |
| Off Site Florio Flyer Yankee Twister on E-bay | TJK | Aircraft - Fuel - Airplanes (FS/W) | 0 | Aug 29, 2007 05:35 AM |
| B-H Twister( Precedent Fun Fly look-a-like) | Chippie | Sport Planes | 0 | Apr 25, 2005 02:47 PM |
