Play with your gun. Spray out some samples. Play with different amounts of solvent to paint ratios.
Most paints say that they can be reduced 25%. That's a 1-3 solvent to paint mixture. I've never had any luck with that. I always seem to add extra solvent. Once, for a clear coat, I sprayed Minwax Polyurethane without reducing it. That poly was the perfect viscosity for spraying. Each paint can (will) be different. I like to thin mine to the consistency of milk. |
I had everything against me. New gun, paint I've never sprayed before and bad lighting
The smart thing to do like you said was to spray a test panel. Like I said, live and learn ![]() Ken EDIT; Now that I think about it..... The last two times I sprayed paint I followed the MFG's recommendations for thinning the paint. Both times I got the same finish, like the paint is to "dry". I remember in the past I had always added a bit more thinner than the MFG recommends and had a good experience. So from now on I'll "take a little paint with my thinner please"
Photos of the completed plane, except for mounting the radio gear. Descriptions to follow. It's off to work...
Ken
I've had good results using 4 parts Rustoleum, 1 part automotive enamel reducer, and 1/2 part Evercoat D.O.I. sprayed through an old Sata Minijet with a 0.8mm tip, 25 psi at the the gun. Henry |
Joined Jan 2009
Painting
Just to let you know what I"m up to. Just finished spraying the T-38 (Control line stunt) not scale. Used Rusto with hardner, gloss white and flat black. Mixed the paint 4:1 with hardner and thinned as neeed for the weather conditions and tip size. Paint flowed beatiful with no orange peel. After I put the white on let it sit for two (2) days and broke it open on the nose and sprayed the flat black. Again it flowed nice. I going to spray the canopy today and the red and blue on Tuesday and Wedneday. The only thing I don't like about Rusto is the wait time and sanding between colors. Slow, Slow Slow. After I finish this one I'll be going back to Auto Air for the speed. If your painting only one or two colors Rusto is the way to go. Anyhow back to the shop. Rick |
Joined Jan 2009
Update: canopy painted, I'll airbrush with light blue to make it look like glass and inside the spade I airbrush a ghost cowboy. Again I used rusto gloss black and alumium with hardner and acetone for quick drying. The alumium sprayed really nice thru a .08 tip. thinned about 25%.
More to come. Oops! forgot the attachments. Rick |
I tried a little experiment on the cowl under the spinner. I had to do a bit of sanding after buying an aluminum spinner. I was out of red spray bomb paint. I took the cowl with me to Hobby Lobby (the craft store) and picked out the cheapest craft paint they had that matched close enough. I think it was 99 cents for a 4 oz bottle of acrylic something or other. I hand brushed where needed and a day later hand brushed on the automotive urethane. It's still looking good and there was no reaction between the two paints. I may have found my new painting method.
Ken |
Joined Jan 2009
T-38
Update: Got the airbrush out, I'm not a pro, and played with Rusto in it. I used the hardner and really thinned the paint for the airbrush. I sprayed the black first, let it sit 45 minutes then taped it off for the squares. Next came the silver and let it dry overnite. I used 1/4 dots for the screws. After laying down the dots. Walmart product, office supplies I airbrushed around the dots. Let that dry and removed the dots 45 minutes later. I then airbrushed the screw slots.
Tomorrow I'll do the rips and tares. It will be interesting to see if it's fuel proof. If not I'll clear the whole plane. Rick |
| Thread Tools | |
| Discussion Epoxy Clear Coat Over Waterborne Paint | alexhaben | Composites Fabrication | 2 | Aug 22, 2010 08:57 PM |
| Discussion Fuel resistant clear coat over Acrylic lacquer? | Curare | Painting and Finishing Tips | 5 | Jul 11, 2010 08:42 PM |
| Question Clear coat over low gloss paint | nick_75au | Dock Talk | 6 | Aug 01, 2009 12:51 PM |
| Discussion Oil based or Lacquer based paint..can I put Latex based over? | richg99 | Painting and Finishing Tips | 1 | Apr 15, 2009 11:38 AM |
| Question What kind of clear coat over top flite lustrekote spray paint? | rmeflyerkid | The Builders Workshop | 1 | Jul 04, 2006 02:49 AM |
