Old Jun 20, 2012, 02:18 PM
woolf_66 is offline
Find More Posts by woolf_66
woolf_66's Avatar
Deutschland
Joined Jun 2005
Hi Kin,
Any news about the 810mm Huey blades?
Wolfgang
woolf_66 is offline Find More Posts by woolf_66
Old Jun 20, 2012, 02:53 PM
cap231ex is online now
Find More Posts by cap231ex
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
Thank you .
cap231ex is online now Find More Posts by cap231ex
Old Jun 20, 2012, 11:41 PM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Originally Posted by cap231ex View Post
Thank you .
Sorry for the late sent you ! but hope you can enjoy the blades !
kin is offline Find More Posts by kin
Old Jun 20, 2012, 11:43 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Originally Posted by woolf_66 View Post
Hi Kin,
Wolfgang
The blades we need do some enough quantity to choice the balance match , so let me sent you late sorry ! but it packing now and you can get it next week !
Old Jul 01, 2012, 10:31 AM
SidewaysLS4 is offline
Find More Posts by SidewaysLS4
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
I received a set of 360mm scale blades from Kin to test out...so here's some initial testing
The test subject is a grossly overweight 450 AH64 from Wing Wing with lots of custom mods...tipping the scales at about 4.1lb. flying weight. I previously had some standard '360mm' CF blades on the heli.
To start, these scale blades are a true 360mm hole-tip size. When you are trying for the biggest possible rotor disk, they really come though. Out of the package, the set of 5 came with weights of 41.48 41.54 41.55 41.55 and 41.57 grams. No balancing needed here .
At scale type speeds (1900 headspeed on my model), the extra weight of the blades are well in the safe range...about 75 lb of force with the scale blades vs. the 50 lb of force with my previous 29.3 gr CF blades. Considering that pod/boom helis running this size CF blade around a typical 2700 rpm have the force at over 100 lbs...should be just fine.
So I did a back to back comparison of lifting power and general forward flight using the old and new blades. One thing that immediately stood out was the very noticable increase of max pitch lift. With 13* of max pitch on my model, I noticed a very welcome pop. Before the lift was rather soft and weakish...these new blades have some good bite and made the heli rather 'peppy' whacking full collective. A very welcome effect on this flying brick.
General forward flight indoors and windless showed no wierdness, and I think the asymetrical airfoil provided for less actual pitch (my calibrated thumb felt a bit lower on the stick range, lol).
I ran my eagletree to get some amp draw readings to make sure these blades didnt start sucking down the juice like some of my 'scale blade' experiences. Let's just say these are pretty good...no difference of any significance in standard flight. On full collective they provide much more lift...with a increase of amp draw as well. One can expect that. I should note that I am running an undersized 22x15mm motor on this heli, and the motor is stalling at max pitch conditions so that is why there is such a headspeed drop in the log charts. This particular motor really sucked on a MiniProtos in pod/boom form due to the lower numerical gearing of that heli...you can imagine how well it is doing with a porky 4 bladed scaler . I do plan on getting a real 22x21 motor for it soon, and ditching the CC governor for a Vbar/Hobbywing setup in the future. Should help out in the maintaining headspeed department.
Anyway, getting back to the review...I plan on seeing how flight manners are outside in wind and will post about that when the time comes. I am also thinking I might be able to knock back the headspeed a little bit also for better efficiency as the asymetrical airfoil seems to work on these scale blades .
So far...I like 'em!
More later...in the meantime some pics and chart:
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Jul 01, 2012, 11:16 PM
Redjestird Youser
Joined Jan 2009
Not much wind today, but it made it outside. I gotta say, I like these blades, so I'm keeping them on the heli.
The only downside of these blades is that they renewed my interest in this heli and made me order up a new power setup I've been thinking of for a while
Well, here's some flying around with the blades...
apache 360mm scale blades (2 min 41 sec)
Old Jul 02, 2012, 12:34 AM
robins22 is offline
Find More Posts by robins22
Joined Oct 2007
Sideways, somehow I lost the overall view about the smartmodel blades range.
Are these still plastic or composite blades?
Thanx, Rinaldo
robins22 is offline Find More Posts by robins22
Old Jul 02, 2012, 12:40 AM
Redjestird Youser
Joined Jan 2009
The 360's are plastic...but I believe that anything bigger than that is CF? Kin?
Old Jul 02, 2012, 02:52 PM
JamesBC is offline
Find More Posts by JamesBC
Canada, BC, Abbotsford
Joined Nov 2010
SidewaysLS4
Are these the blades you tried out?
SM 4536-4 Scale rotor blades 450-480 360mm
I had bought a set from Kim last year of scale blades but they where much shorter than the add said. I tried to contact Kim and Smart Models with no reply from either.
thanks for a reply
Jim
JamesBC is offline Find More Posts by JamesBC
Old Jul 02, 2012, 06:50 PM
Redjestird Youser
Joined Jan 2009
I dont know, I think so. These blades are asymetrical, have an arrow molded on the top and are 360mm from the hole to the tip. SM in the past had some other 450 sized scale blades also, but those were shorter and I believe symetrical IIRC
Old Jul 03, 2012, 11:07 AM
JamesBC is offline
Joined Nov 2010
Thanks for the reply.
I guess I will not order any, have one set of Scale Blades from them that are to short to work, even though they advertised them as being longer.
Old Jul 04, 2012, 10:58 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Dear James BC !
First 1000 time sorry the missing reply ! I think many friend here know i just 6 hours sleep a day since 2009 till today . still very less sleep . full time in the products line and crazy to develope the models . Some time missing the massage is my big problem . and memeory also very bad ! it is true ! So please e mail me and sent you a free set 4piece to testing ! just let me a e mail sent you the blades this week ! just let me the shipping is ok .
Old Jul 04, 2012, 11:01 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Sidway ! Have you interesting the 650mm scale carbon blades , i will sent you a set 4 piece set . you will get it next week !
Old Jul 04, 2012, 04:28 PM
teamdavey is online now
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
I just checked the website for the 650 mm blades. Is the weight a typo??
teamdavey is online now Find More Posts by teamdavey
Old Jul 04, 2012, 04:55 PM
Redjestird Youser
Joined Jan 2009
Well, I do have a .60 LongRanger with a stretched T550 inside of it. It does have 713's on it now...but scale-wise 650mm is more like the 1:1 version if you compare photos of the real thing to the model. So yes, I would be interested
Question 600mm scale rotor blades from SmartModel Horseman Scale Helicopters 11 Nov 01, 2011 01:46 PM
Discussion Smartmodel TFM-600-4 blades rotor head for 600 size wangzx Scale Helicopters 4 May 05, 2011 02:02 AM
New Product 600/700mm scale rotor blades from SmartModel Hoverup Scale Helicopters 67 Dec 03, 2010 08:49 AM
Discussion Smartmodel 450 scale rotor blades Piracy kin Scale Helicopters 4 Oct 19, 2010 09:47 PM
Discussion Smartmodel scale rotor blades for 450 size ! kin Scale Helicopters 172 Apr 13, 2010 03:17 PM
