Old Feb 27, 2012, 02:38 PM
teamdavey is offline
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
"As for my statement it is true the added weight of the plastic blades slows down the response of the FBL unit making it less effective."
My experience is exactly the reverse - I'll take the heavy blades every time.
teamdavey is offline Find More Posts by teamdavey
Old Feb 27, 2012, 03:47 PM
cap231ex is offline
Find More Posts by cap231ex
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
So what E-stab units are you using?
What servos are you using with them?
What is your servo speed?
cap231ex is offline Find More Posts by cap231ex
Old Feb 27, 2012, 08:50 PM
Sunnyvale, CA, USA
Joined Apr 2000
None of which has got much to do with the fact that a rotor that reacts slower to gusts is inherantly easier to stabilize.
I am still interested in your direct experience that lead you to prefer lighter blades.
Clearly for 3D things are different as there rpm is much higher and if the rotor is too slow you can hit blade stall in hard manoeuvers
Old Feb 28, 2012, 05:47 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Originally Posted by cap231ex View Post
Well if you're going to make them 360mm then they need to be about 28mm wide.
i complete the drawing and how about the thickness in the blades grip still 5mm ?and when you make the decision , is it shape straight or swept tip (Apache look?)?? i have one choice only ! so i want make straight !
kin is offline Find More Posts by kin
Old Feb 28, 2012, 11:29 AM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
Yes grip is fine left at 5mm on the grip and I think straight would fit more applications then the swept tip.
Old Feb 28, 2012, 09:38 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Agree !ok go ahead !
Old Mar 01, 2012, 07:55 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Ok ! the new size is 360mmx28mm ,shape style is straight .blades grip 5mm .screw hole 3mm ,airfoil semi-symmetical ,rotation direction -cockwise . Plastic injection .Price -very very very good price ! Coming out 10 March . and the next new products is 430mm x32mm scale narrow carbon blades , and 325mmx24mm carbon blades . and the new come out the mold first piece in the photo is eurocopter looking 600mm gray colour !
Old Mar 01, 2012, 12:03 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
How about some test sets of each?
Old Mar 03, 2012, 02:08 AM
BlackTitanium is offline
Find More Posts by BlackTitanium
3D and Scale RC Heli Pilot
BlackTitanium's Avatar
Monroe, WA
Joined Jan 2007
Sweet! Carbon 430's are just what I need for my BO-105!
BlackTitanium is offline Find More Posts by BlackTitanium
Old Mar 03, 2012, 04:15 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
the first left hand photo is the 430mm !long one !
Old Mar 15, 2012, 07:44 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
some sample here !
Old Mar 16, 2012, 09:02 PM
AMinster is offline
Find More Posts by AMinster
Thumper
Slidell, LA
Joined Jan 2010
Kin,
Are you still planning on doing some 600 counter clockwise for A109 and MD500?
AMinster is offline Find More Posts by AMinster
Old Mar 18, 2012, 09:24 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Originally Posted by AMinster View Post
Kin,
if the blades are semi-symmetical i need carefully to see make it CCW or CW direction , but if the wing airfoil is symmetical .it is no problem , but i have 600mm scale blades is symmetical . so you can let it CCW and CW ! This new come out is symmetical !
Old Mar 18, 2012, 11:40 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
i uploaded the website http://www.smartmodel.com.hk/product...sub_cat_id=303
Old Mar 18, 2012, 02:34 PM
cap231ex is offline
cap231ex's Avatar
Joined Jan 2009
What about CF 700 scale blades , do you plan on making them as well?
And if so about what is the time frame for them?
Question 600mm scale rotor blades from SmartModel Horseman Scale Helicopters 11 Nov 01, 2011 12:46 PM
Discussion Smartmodel TFM-600-4 blades rotor head for 600 size wangzx Scale Helicopters 4 May 05, 2011 01:02 AM
New Product 600/700mm scale rotor blades from SmartModel Hoverup Scale Helicopters 67 Dec 03, 2010 07:49 AM
Discussion Smartmodel 450 scale rotor blades Piracy kin Scale Helicopters 4 Oct 19, 2010 08:47 PM
Discussion Smartmodel scale rotor blades for 450 size ! kin Scale Helicopters 172 Apr 13, 2010 02:17 PM
