This thread is privately moderated by RCPtero, who may elect to delete unwanted replies.
Old Feb 21, 2012, 06:38 AM
RCPtero is offline
Find More Posts by RCPtero
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Adventuring into FPV
I started working up an FPV setup last summer. This BLOG entry is focused on that FPV setup and where I'm going from there.
RCPtero is offline Find More Posts by RCPtero
Old Feb 21, 2012, 06:43 AM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Made a score yesterday in Raleigh at the CompUSA. Picked up a KWorld Xpert DVD Maker USB 2 interface ($29), which takes standard composite video, L/R audio and pipes it into the computer. I'm going to use my laptop as my ground station recording device.
Also, I picked up a Seiki SE131FS 13 inch 720p TV/Monitor ($79). I'll build a box around it to shade it from the sun and will serve as my ground station display for general viewing. It runs on 12v, comes with a car lighter port adapter as well as a house AC adapter, and only pulls 2 Amps. I figure on my 3S2100 cells, I can run for about an hour per pack. Should be a good use for my aging packs!
All for now. I'll post more for my current setup when I get a chance, and then will do updates as I build out my rig.
Tom
Old Feb 23, 2012, 05:47 AM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
I connected everything together last night and tested the TV and the video capture. It all worked great! Now I need to put it together in some easy to transport and setuo configuration.
Tom
Old Mar 02, 2012, 02:35 PM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
Interesting thread.
What freq are you using for your video? Thanks.
tobermei is offline Find More Posts by tobermei
Old Mar 04, 2012, 08:09 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Originally Posted by tobermei View Post
Interesting thread.
I'm using 900 MHz for my video feed and 2.4 GHz for my RC.
Nothing done on the FPV front this week. Been focused on the Rascal floats and a head and neck transplant for my pterodactyl.
Tom
Old Mar 14, 2012, 12:09 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Score! Picked up a GoPro Hero2 for 15% off!
Old Mar 14, 2012, 05:47 PM
Spadrastic is offline
Find More Posts by Spadrastic
United States, MN, Pequot Lakes
Joined Jun 2010
GoPro Hero2 for 15% off! Where please??????
Spadrastic is offline Find More Posts by Spadrastic
Old Mar 14, 2012, 07:38 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Staying at the Hampton Inn in Myrtle Beach. The room key has a coupon for 15% off any one item at Ron Jon Surf Shop. Was walking through and didn't see much of interest until I was about to leave and noticed a Go Pro display.
So, sadly not one I can pass along.
Old Mar 25, 2012, 11:58 AM
javabeans is offline
Find More Posts by javabeans
Bedford, Mass. USA
Joined Dec 2007
I'm interested in your Ptreodactyl setup. I have just begun testing for FPV using an EasyStar and once I am comfortable with it, will be moving the video to a Pterowerx 52" Pterodactyl for my permanent setup.
My plan is to make the neck turn side to side as a two stage unit for camera pan and the head will tilt up and down for camera tilt. Haven't decided how to mount the camera yet, as I haven't received the Pterodactyl (it's in the mail).
I'll probably do a pull / pull setup for the camera movement and mount the servos in the body
Java
javabeans is offline Find More Posts by javabeans
Old Mar 25, 2012, 01:24 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Good luck with the Ptero FPV. I think it'll be cool, but foresee it being not easy. That is the pterodactyl I'm working on, and it requires two ounces of weight in the head, so that gives you weight to work with. You will need to watch the aerodynamic influence on the flight though.
I have decided my Rascal 110 will make a great FPV platform. The GoPro will mount above the windshield right in front of the wings.
Tom
Old Mar 25, 2012, 01:36 PM
Bedford, Mass. USA
Joined Dec 2007
Ah, yes. I'm going use just a small FPV camera with OSD and hoping to put electronics inside.
Discussion Trying to get back into FPV - couple of questions TheNiceGuy FPV Talk 31 Jul 17, 2011 04:15 PM
Discussion You want to get into FPV? Try this! Alvid98 FPV Talk 0 May 16, 2011 02:54 PM
Discussion Getting into offroad for FPV. Summit or Flux? MaxGen Off-road Cars 6 May 04, 2011 02:05 PM
Discussion Police send a FPV robot into the home of man armed with guns... replayreb FPV Talk 12 Apr 10, 2011 08:45 PM
Discussion Finally getting into FPV, and selecting my first FPV setup! Pitchback FPV Talk 2 Dec 20, 2010 10:12 AM
