Old Feb 20, 2012, 09:42 PM
CnadianFF is offline
Find More Posts by CnadianFF
Canada, BC, Kamloops
Joined Sep 2011
Ailerons flaps don't line up on Radian Pro???
Just put together my Radian Pro and on my Right wind when the pushrods and clevis's are set correct the two don't line up. Has anyone else had this? Does it really badly effect flight? Will the foam bend if I bend the surfaces the other way over night? Or should I take it back to the hobby store and get a wing. Just such a pain in the
CnadianFF is offline Find More Posts by CnadianFF
Old Feb 20, 2012, 11:10 PM
slopemeno is offline
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
How much of a difference are we talking? 1mm- 2mm?
slopemeno is offline Find More Posts by slopemeno
Old Feb 20, 2012, 11:13 PM
Joined Sep 2011
5mm.
Old Feb 21, 2012, 02:42 AM
this space for rent
slopemeno's Avatar
Joined Jan 2003
So this isn't a case of a line-up/set-up/programming issue, this is a warp, right? I'd take it back.
Old Feb 22, 2012, 06:05 AM
Sir Dumb Thumb is offline
Find More Posts by Sir Dumb Thumb
Old Prop Buster
Sir Dumb Thumb's Avatar
United States, CA, Grass Valley
Joined Dec 2009
You can bend the foam if you heat it with hot water like from a tea kettle and hold it over the steam to heat and straighten. Don't use a heat gun, don't ask how I know this. Can you use the sub trim on your radio to get them even? I have to to do this with my radio all the time as transportation seems to warp the RP wings slightly.
Sir Dumb Thumb is offline Find More Posts by Sir Dumb Thumb
Old Feb 22, 2012, 03:03 PM
Crash Prone is offline
Find More Posts by Crash Prone
Crash Prone's Avatar
United States, WA, Port Orchard
Joined Feb 2011
If it's warp you're talking about in an aileron or flap, try taping both ends of the control surface flush and leaving it over night. Some have had success with that.
Crash Prone is offline Find More Posts by Crash Prone
Discussion Why don't more planes have counterbalancers on the ailerons? stgdz Electric Plane Talk 19 Oct 07, 2011 08:43 PM
Discussion Activate flaps on Futaba 10C.? When you got the ailerons in paraell.? Voguna Electric Plane Talk 4 May 03, 2011 02:03 PM
Discussion Ailerons + Flaps = Flaperons on DX8 & Radian Pro s1l3ntb0b Radios 11 Mar 17, 2011 10:14 PM
Discussion Ailerons dont go up in butterfly / flaps in Multiplex Royal Pro Monhty Radios 6 Jul 17, 2010 12:15 PM
Razor motor holes don't line up to EPS300 GB 10Thumbs Power Systems 56 Jun 27, 2003 01:02 AM
