Old Feb 20, 2012, 04:56 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Nitrocharged's 25mm EDF Micro BAE Hawk plans now available!
It's finally here! Downloadable pdf plans in .zip format for the 25mm EDF BAE Hawk designed by NitroCharged. This model has a 12" wingspan and can be flown on 2 or 3S. Rxer used is an AR6400 with mixing in a Spectrum DX7 Transmitter to allow taileron control via the rudder and elevator servo's on the board although any micro R/C system can be used. 2mm depron is recommended for the build.
Click here to buy your very own set for only $9.95AUD!
Watch and see what the 12" EDF Micro Hawk looks like doing around 70MPH!
Team30 Micro EDF: 25mm EDF BAE T-45 Hawk! (2 min 11 sec)
What's included in the download? Lots!
The downloadable file contains full sized parts layout and also a full set of ready to print decals to apply to your Micro Hawk!
Helpful construction notes have been included to assist you with your build.
Images of the finished model and decal layout.
On your display stand or out on the field, it's a sharp looking model!
This purchase is for the plans only for the price of $9.95AUD. No parts are offered with the purchase of this item.
The parts can easily be scaled up for a 30mm version or larger so off the shelf parts can be used.
Please post your build experiences, discussion and question's etc here and let the fun begin!
NitroCharged is offline Find More Posts by NitroCharged
Old Feb 20, 2012, 06:50 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Looks GREAT!!!...I picked up a set of plans and the pics/instructions are well written and easy to follow...
If you aren't interested in a 25mm Hawk/T-45 the plans are easily enlarged...Nitro---Well done!!!
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Feb 20, 2012, 08:51 PM
Jack Brewer is offline
Find More Posts by Jack Brewer
United States, IN, Lafayette
Joined Dec 2003
The plans and instructions look great.
Now I need to find a 25mm fan and motor.
Jack
Jack Brewer is offline Find More Posts by Jack Brewer
Old Feb 27, 2012, 12:47 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Here is how I did the tailerons.
  • I bent a piece of wire with 7 down angle at each side of the center, just wider than the fuse body and glued it to the fuse after poking it through the body just under the bottom turtle deck piece in the TLAR position.
  • I then added little aluminium tube tabs with some pre-shrunk heatshrink tubing over the wire on each side.
  • I CA'ed the little aluminium tabs in place to hold the heatshrink in between them - making sure the heatshrink was free to move.
  • I then glued the tailerons onto the heatshrink - being careful not to drip or spread the glue onto the wire (or it will lock up of course).
I hope the images help the description. Yes, that's all that's holding them on while going 70mph!!!
Old Apr 03, 2012, 07:29 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
For those of you interested in a template for the exit pipe, I've attached one for use as a guide. This is to suit a 25mm case.
Old Jun 21, 2012, 10:05 PM
Groovechampion is offline
Find More Posts by Groovechampion
Micro enthusiast
Groovechampion's Avatar
Australia, SA, Adelaide
Joined Aug 2011
Thats a sweet little bird!!
Hi there Nitro,
Met last night at the indoors at ETSA, we were talking micro retracts.
What a great little EDF!!! Im tempted to buy the plans.
Just a few questions: Is it an easy build?
Are the guts you recommend noted in the manual??
Regards,
Nath.
Groovechampion is offline Find More Posts by Groovechampion
Old Jun 22, 2012, 03:23 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Hi Nathan, glad you like it.
It is an easy build being box construction.
I only mention the type of rxer I used.
The power unit still has to be home brew although the cases etc can be purchased from the Team30 Shapeways shop.
Old Jun 24, 2012, 01:14 AM
Micro enthusiast
Joined Aug 2011
Cheers David,
How hard is it to make your own home brew 25mm fan??? Is that also in the instructions?? If not what parts do you recommend for this model?
Also what do you reckon about me doing an ailerons version with elevator and rudder based on using your plans?
Or do you reckon its overkill?
Cheers,
Nath
Old Jun 24, 2012, 02:40 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
It's not that hard to do but no the instructions focus on the model not the power unit as there are many ways to do it.
I can help if you get stuck or need pointers - just PM me.
Old Jun 27, 2012, 12:13 AM
Micro enthusiast
Joined Aug 2011
Cheers will do!
Old Jan 02, 2016, 07:41 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Building Tip
For those that may scratch their heads at how to get a uniform and nice curve to both intake walls while building the model, here's how I do it:
I use the outer piece that's left over from cutting the turtle deck base(fuse top) as a guide for the inside curve - I cut it about 1cm wide and follow the curve, trimming it until it fits against the inner ducting wall.. Then, I glue it with an overhang to another piece of depron to 'float' it above the model so it doesn't become glued to the model itself. Next, I make an outer curve in the same manner.
Once happy with the line-up of the inner guide, I pin it to the mat. Then I align the outer curve and make guide marks on both of them so aligning is easy.
Pre-bend the wall piece slightly to help fit the curve (make an S shape). Run glue on the base of the wall piece just from the front of the wing back to where the wall starts to curve up. Don't worry about the front and back areas yet. Place the wall in position and slide the outer guide against it to make it take shape. Hold it until the glue dries! Repeat on the other side.
Discussion CMPro BAE Hawk now at nitroplanes scatsob Electric Ducted Fan Jet Talk 1 Jan 12, 2012 05:42 PM
Sold 50mm EDF Red Arrows T-45(BAE Hawk) with a 5400kv Wicked/Wemo EDF combo installed -= GYRO =- Aircraft - Electric - Airplanes (FS/W) 0 Aug 13, 2011 10:39 PM
For Sale Still available,E-Flite BAE Hawk w/EDF Motor and Servos. $150.00 btpalc Aircraft - Electric - Jets (FS/W) 1 Jun 19, 2010 08:58 PM
For Sale Still available E-Flite BAe Hawk w/EDF Motor and Servos btpalc Aircraft - Electric - Jets (FS/W) 0 Jun 12, 2010 05:24 PM
