This thread is privately moderated by rchook, who may elect to delete unwanted replies.
Old Feb 20, 2012, 04:40 PM
rchook is offline
Find More Posts by rchook
Trader Rating: 1
BRANCHBURG, N.J.
Joined Jul 2009
Trader Rating: 1
Sold
TailHook plane restrainer
Having a problem restraining your plane when starting the engine for a flight?
WE HAVE THE SOLUTION - The TAIL-HOOK
PRICE -$35.00 + S&H
TAIL-HOOK it’s like a friend's hands holding your plane.
The TAIL-HOOK grasps the stabilizer in two special soft foam padded 18 inch arms which are secured to the ground with a 12 inch long x 3/8 round spike.
The Tail-Hook's is an advanced design to HOLD and RESTRAIN accessory for RC flyers.
It is easy to operate and complete detailed instructions are included with each order.
MADE IN the USA since 2002, Tail-Hook is constructed from high quality steel and heavy 1/16thick wall aluminum tubing.
The standard TAIL-HOOK is 18 inches long and will hold most planes. If the distance from the leading edge of the stabilizer to the end of rudder is more than 18 inches on your LARGER plane... you will need a custom made Tail-Hook.
To avoid problems, I need to know THIS about your big plane : HOW MANY INCHES from .. the LEADING EDGE OF STAB to the END OF RUDDER ?
*** If it measures more then 18 - you'll need a custom made TAIL-HOOK with longer hook arms ( see photo #5 below)
Check our buyers opinions and ratings regarding this product(in SELLER DETAILS box clickRatings).
Do not hesitate to contact us if you have any questions or need a custom made TAIL-HOOK (In Seller Details click on Ask Seller a Question).
Operation
1. Push the hold down spike, at the back of the TAIL-HOOK , into the ground by pressing on the steel crossbar. If the ground is very hard where you will be using the TAIL-HOOK ,you may need the optional FREE SPIKE MODEL, which allows the spike to be driven into the ground with a hammer.
2. Test that the TAIL-HOOK is secure by pulling forward on the hooks. It should not move, If it does reposition the spike.
3. Slide the tail of the plane between the arms of the TAIL-HOOK, and engage the hooks over the stabilizer.
4. Before starting the engine gently pull the plane forward to be sure that the hooks are engaged on the stabilizer.
5. Start your engine and do you preflight checks.
6. When you are ready to take off , walk over to the tail of the plane and grasp the tail of the plane, pull the plane backward until the hooks disengage from the stabilizer. The hooks will fall to the ground allowing the stabilizer to pass over them as the plane moves forward.
7. When its time to go home pull the spike up by grasping the crossbar only To avoid damage : DO NOT PULL BY THE ALUMINUM ARMS .
Options:
For very hard ground we recommend the FREE SPIKE model which can be driven into the ground with a hammer at an additional cost of $5.00. (see photo #3).
BUY WITH CONFIDENCE - return ... if not satisfied- contact us by e-mail. REFUND policy applies to returns within 10 days of our shipment date, and only to ---- CLEAN and UNDAMAGED unit.
rchook is offline Find More Posts by rchook
For Sale TailHook plane restrainer rchook Aircraft - General - Miscellaneous (FS/W) 4 Jul 26, 2014 05:33 PM
Discussion Travelling by plane with a plane....? chris jones Electric Plane Talk 12 Aug 02, 2011 04:47 PM
Wanted Hydro Plane or Float Plane nhale Aircraft - Electric - Airplanes (FS/W) 2 May 10, 2011 07:36 PM
Discussion Video of real plane crashing into a hovering RC plane cardinal43 Giant Scale Airplanes 2 May 02, 2011 12:04 AM
Discussion What plane for new plane flyer, familiar with helicopter DennizMT Beginner Training Area (Aircraft-Electric) 25 Apr 04, 2011 09:07 PM
