Old Feb 20, 2012, 11:09 AM
Joined May 2011
ICON ballance point
I'm doing a recon on an original Icon. Since I am changing over to my 10G system I will need to re-ballance the airplane. Does anyone have the ballance point from the leading adge of the wing ?..Thanks. D C Morrison
D C Morrison is offline Find More Posts by D C Morrison
Old Feb 20, 2012, 12:34 PM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I posted that info several weeks ago in another thread, maybe search for it? I don't remember the specific forum where I answered.
My planes are in Winter storage or I'd go measure one for you.
tkallev is offline Find More Posts by tkallev
Old Feb 20, 2012, 12:49 PM
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
CG is approximately 4 9/16 inches back from leading edge of the wing at the fuselage ... towhook is just slightly ahead of that. With the airplane assembled, the plane should balance there. Add one tube of ballast ... if the CG doesn't change, you're right on. If not, adjust the empty balance point until adding a tube of ballast results in no CG change.
All of my Icons are balanced this way and they rock! They do not pull out of a "dive test" by themselves ... it just keeps going
Hope this helps.
tk
Old Feb 20, 2012, 04:24 PM
Joined May 2011
tk
Thanks for the info. Cody from Skip Miller also sent a reply. He says he has a friend that is using 115-116 back. Thanks to both of you for the reply
Careful! Hyperion ballance tab lesson learned the hard way supermo26 Batteries and Chargers 5 Oct 11, 2011 11:48 AM
Discussion Home made CG and ballance board hog2soar Sailplane Talk 3 Jun 09, 2011 07:37 PM
Discussion 2 versions of same chg'r. Niether Ballance cdninoh Batteries and Chargers 5 Jun 07, 2011 08:38 AM
Discussion boar ballance point? Joe2003 Sailplane Talk 2 Aug 24, 2009 11:40 AM
Alert telemaster ballance point Joe2003 Electric Plane Talk 3 Jul 19, 2007 02:18 PM
