This thread is privately moderated by sid.huang, who may elect to delete unwanted replies.
Old Feb 20, 2012, 07:13 AM
sid.huang is offline
Find More Posts by sid.huang
Chinglish-funny
Joined Mar 2011
Build Log
Rangelink Revision History
4/8 CH RX:
V2.40
1. sensitivity improve.
https://onedrive.live.com/redir?resi...t=folder%2chex
rv v2-v2.20.hex is for 8/4ch rx;
1. sbus will output fs state when rx fs actived.
2.improve power dissipation, down to 55mA;
r6.zip, include the v2.11 fw for rangelink tx,
-with some changes:
tx fw v2.11 with follow channges
- pause/continue the headtracker when short pressing the tx button.
- active / de-active the override settings when press down and hold the tx button until the beep up.
short press : less 0.8s
ON/OFF the override settings: ~0.8s - BEEP
FS settings: ~4s - TX LED off
-----------------------rangelink tx-------------------------
Firmware:
v1.03 First Customer Release.
v1.26
1.fixed interference with vrx 1.2GHZ system.
2.support futaba radio 12ch ppm mode (only at teacher mode).
{Only tested with 12FG}
v1.27 add new feature link quality indicator / rf rssi indicator selectable (on rssi pin)
v1.28
1. Pan /Tilt will be map to ch8/ch9 ,for 8ch RC radio.
-----------------------rangelink rx-------------------------
Firmware:
v1.06 First Customer Release.
v1.23
1.change rssi(packet rate) to rf rssi. range (0-3.2V)
2.reduce the fs setting request(3-6s).
Hardware:
New batch<after 2012-03> change the internal buffer, improve the driving circuit capacity. and improve the internal RC filter, because some OSD input very low impedance,like eagletree OSD PRO less 5Kohm. and some OSD input not include filter (HW filter or digital filter), so it will make the rssi unstabitily.
v1.24 add new feature link quality indicator / rf rssi indicator selectable. (rssi pin)
v1.25
1. output some info over the uart port, just like link status, rssi ect.
if you need more info about uart protocol ,just email to us.
// UART CFG: 9600bps 8+N+1
// <<tx ascii
// STX + 'm' + packetRate + mixInfo + Vrssi + checkSum + ETX
// 1 +1 +2 +2 +2 +2 +1 (11bytes)
// mixInfo<2:0> = g_extra3bits (reserved).
// <3> = FS status.
// <4> = reserved(for testing).
// <5> = FS enter setting status.
// <7:6> = reserved
// Vrssi = 3.2/256 * RSSI.
// checkSum >
//unsigned char CheckSum (unsigned char tab[],unsigned char length)
// unsigned char sum = 0;
// unsigned char i;
// for(i=0; i<length; i++)
// sum += tab[i];
// sum = ~sum + 1;
// return sum;
Note: if you wanna to upgrade,please upgrade both(tx & rx) to the newest version.<for tx v1.27/rx v1.24>
New feature link quality indicator / rf rssi indicator selectable:
make rangelink tx enter advanced binding mode, first beep end:
the two ways switch
high power mode ==> link quality indicator
low power mode ==> rf rssi indicator
v2.10
1. TX PPM channels can be override by ht ppm signal input.
2. Make Tx works with new diversity rx;
***************just upload the JFPV V1.20 , this version include the Spectrum anaylzer beta function. ******************
Note: if you dont have the v2 rx, so no need to do fw upgrading.
thanks
Sid
sid.huang is offline Find More Posts by sid.huang
Old Mar 12, 2012, 11:24 PM
Chinglish-funny
Joined Mar 2011
RC filter for OSD analog input: (new batch no need)
http://www.rcgroups.com/forums/showp...&postcount=871
about futaba radio 12ch ppm support:
http://www.rcgroups.com/forums/showthread.php?t=1611696
Just support 12ch teacher mode.
"When in the 12ch teacher mode the ppm pulse is normal but variable repeat time."
futaba radio when works at 12ch teacher mode,it needs a student ppm signal input, so if you have a x1000 headtracker, you can make a cable as attach file shows, it will make rl works...
Other Ideas:
http://www.rcgroups.com/forums/showt...2#post21042405
Old Nov 30, 2013, 05:03 PM
mike_papas is offline
Find More Posts by mike_papas
Joined Nov 2013
I want to buy the rangelink set for 185$. Please tell me what else will I need to make it run with a futaba 14sg and a phantom FX-61 (cables, antennas, jacks etc)
I also have the boscam goggles connected with my futaba
4pin plug (goggles) -->6pin plug (futaba)
Please advice how to connect the rangelink with the futaba as well the boscam goggles.
Thanks in adv.
PS
will I need a USB2TTL and what is it?
will I need a radio stand?
mike_papas is offline Find More Posts by mike_papas
Old Jun 30, 2015, 01:34 AM
frankmokaya is offline
Find More Posts by frankmokaya
United States, CA, Mountain View
Joined Jun 2012
Hi Sid. Could you please upload the firmware for V1.24(rx). I need to flash this frimware to my receiver. the links on the website dont work.
Frank
frankmokaya is offline Find More Posts by frankmokaya
New Product RangeLink UHF Long Range system DavorVZ FPV Equipment 5661 Feb 07, 2016 04:33 PM
For Sale RangeLink (brand new) Dzozi-POL FPV Equipment (FS/W) 2 Jan 04, 2012 03:55 AM
Discussion looking for a Beta-Tester Raphael Slope 20 Mar 16, 2011 06:11 AM
Castle what did you change w/ FW 1.14 Beta???? MichaelT1960 Castle Creations 9 Jun 02, 2005 05:48 PM
