Old Jan 31, 2003, 12:31 PM
uncljoe is offline
Find More Posts by uncljoe
Col.Hooligan Air Force
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
KOOL
Gregg
That's a real Big Guy Toy ,You'll be right at home with the turbines @ Arizona Jets
if main doors are they attached to the strut ?
Semper Fi
uncljoe is offline Find More Posts by uncljoe
Old Jan 31, 2003, 01:50 PM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Nose Gear Door
Joe Mine will have a nose gear door on the plane. I do believe that the picture shows a gear door. I think that your correct. Mine will just close up when the gear come up.
Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Jan 31, 2003, 04:27 PM
ralf dvorak is offline
Find More Posts by ralf dvorak
Tear down the WALL!
ralf dvorak's Avatar
southern Germany
Joined Oct 1998
Of course it has a door!
Joe
Hi all, of course it has (2) a nose gear door, and it closes as the gear comes up. As seen on the pics and read in the instruction gregg has only in german, but is translated into english at the meantime...just finished...
hey, I'm having a break next week, skiing, ha! 2ft of fresh snow!, sorry but I need it, first holiday in two years! afterwards the first 3 kits will be shipped, Gordon, Doc and Jim. the follow ups about two weeks later, late Feb.
cheers, RD
thanks for the compliment
ralf dvorak is offline Find More Posts by ralf dvorak
Old Jan 31, 2003, 04:50 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
El Bandito
I will be in that Follow up Ralf. At least I hope so.
Have a great trip.
Joe
Old Jan 31, 2003, 05:13 PM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Yes. have a great trip Ralf.
Meanwhile, Gregg will keep us all glued to our screens
Gregg. Did you say the side-hinged noseleg door has its own servo? If it does, how will you sequence it with the noseleg?
Keep them photos coming
Gordon
Gordon is offline Find More Posts by Gordon
Old Jan 31, 2003, 05:23 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Gordon
Gordon: one photo shows a micro switch. i'll post some more tonight along with motor run up #'s..............gregg
gregg f is offline Find More Posts by gregg f
Old Feb 01, 2003, 12:30 PM
Tear down the WALL!
southern Germany
Joined Oct 1998
nosegear door ops
FYI: The rear nosegear door is hinged sideways, and is operated by a microservo which is paralleled to the retract valve servo and switched trough a microswitch, which closes the + line of the door servo when the nose strut is UP and locked. THEN the door servo closes the door.
If you select gear DN the microswitch is still closed as the air pressure needs some moments to deplete through the valve and and additional throttle, but the servo is quicker and has already opened the door when the gear comes DN.
In turn this means that the rear door stays open when the gear is down, as the front door does which is linked mechanically to the strut and acts as an airbrake, too. To secure positive lock DN there is an additional downlock spring linked to the gear mechanics externally.
Supplied in the kit for this are: door hinges (standard for the rear door, custom made for the front) door bolts, screws for fixing servos, steering wires and squeezing rings. Manual and pics.
Cheers, RD
Old Feb 01, 2003, 12:34 PM
Tear down the WALL!
southern Germany
Joined Oct 1998
Re: El Bandito
Have a great trip.
Joe
You are, be assured.
I'm in the workshop now, be back later.
cheers, RD
Old Feb 01, 2003, 03:33 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
first motor run up today, in the fuse w/ outlet installed.
b50-16l
hacker/master 77
20xhr2600's
hoc reading was 1050w @ 44a
settling to 1kw after 20seconds. hmm maybe 20 cells will be enough
..........gregg
Old Feb 01, 2003, 03:35 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
here's 2 more pic's from the cd.
Old Feb 01, 2003, 03:36 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
pic 2
Old Feb 01, 2003, 03:46 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Sorry Gregg
Sorry Gregg but I will have to copy your motor, ESC and battery arrangement for my Bandito. I just need to wait for the 2600's to come back into stock and then I will be set. Oh there is the one little thing I forgot? I need to build the plane first, oh well I will be behind ya Gregg. Keep those pictures coming.
Joe
Old Feb 01, 2003, 04:01 PM
uncljoe is offline
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
Gregg
FWIW .. I would use the Sullivan Skylite wheels they are the lights/ hardest wheels out there .. I use them on all my larger planes,they work.will hold up
the plane will need it 6 pounds ...
Semper Fi
Joe
Old Feb 01, 2003, 04:08 PM
U812 is offline
Find More Posts by U812
Joined Sep 2002
Good results Gregg, your all ready to go!
Steve
U812 is offline Find More Posts by U812
Old Feb 01, 2003, 05:06 PM
hoser is offline
Find More Posts by hoser
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
Gregg I'm charging 20 2400's for my hacker 16l which is going in my F-18.
that is the power package I plant to transplant into the Bandito after I save some money after Florida jets.
Love to hear how it performs on the El.
I'm at 6.8 pounds weight in mine !!!
I should have thrust readings shortly. thanks for this thread, nice work gregg. I'm with uncljoe i use the Skylite on all my big edfs, i think it helps reduce galloping also.
hoser is offline Find More Posts by hoser
El Bandito Chris True Electric Ducted Fan Jet Talk 202 Dec 23, 2003 05:45 PM
El.Bandito RG ralf dvorak Electric Ducted Fan Jet Talk 23 Jan 18, 2003 12:01 PM
RD-Jets finally in english, too. El.Bandito etc. ralf dvorak Electric Ducted Fan Jet Talk 5 Jun 24, 2002 09:50 PM
El Bandito (ralph Dvorák) Anyone Flying It? CESARNOGUEIRA Electric Ducted Fan Jet Talk 11 Mar 17, 2002 08:28 PM
finally available: "El.Bandito" is here! ralf dvorak Electric Ducted Fan Jet Talk 19 Dec 13, 2001 06:04 PM
