Old Jan 20, 2003, 10:41 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Nice Gregg!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jan 20, 2003, 11:00 AM
terjes is offline
Find More Posts by terjes
norway
Joined Jul 2002
Gregg
I also glassed mine,i finished the wings (With paint an all) and then took a scalpel
and carefully cut(several times to remove material)into the surface
to get an fine line and then flexed the moving surface back and forth until it was quite loose,but be very careful not to cut into the hinge mat.It`s my first attemt on doing this , im shure there is an better way to to it ,but im satisfied with the result.
Enclosed a pic of it,pleas dont look at the mess in the background
Terje
terjes is offline Find More Posts by terjes
Old Jan 20, 2003, 11:06 AM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
thanks! that helps
gregg f is offline Find More Posts by gregg f
Old Jan 20, 2003, 02:55 PM
ralf dvorak is offline
Find More Posts by ralf dvorak
Tear down the WALL!
ralf dvorak's Avatar
southern Germany
Joined Oct 1998
RTFI ;)
Originally posted by gregg f
Terje: thanks for the advice!
i planned on glassing the wing/stab/fin. with the built in hinges, i'm not sure about how to do this on the upper surfaces.
hacker b50-16L for power.............gregg
Hi all,
terjes advice is ok, but you have to be very careful!
I suggest (also in the instructions) to cut the line first and then score with the back of a cutter and then continue with a triangular needle file only.
ref. LEs: I used a 2mm carbon rod instead of balsa and filler along the whole LE.
Phew, nearly finished the RG instructions in german, more pics than in the main manual, compared.
Into english will be completed by the end of the week.
Cheers and thanks to all, THE list has grown to 7.
Ralf
www.rd-jets.de
ralf dvorak is offline Find More Posts by ralf dvorak
Old Jan 20, 2003, 05:22 PM
U812 is offline
Find More Posts by U812
Joined Sep 2002
Ralf,
I was just over at Gregg's looking at your handy work. All I can say is Wow, this is the best glass work and tooling I've ever seen. First rate! As hard as I looked I never found a flaw. I can only hope to do as well some day. If I had the funds right now, I'd be sending them to you. Soon.
Steve
U812 is offline Find More Posts by U812
Old Jan 20, 2003, 05:34 PM
Tear down the WALL!
southern Germany
Joined Oct 1998
No flaws!???
Originally posted by U812
Ralf,
Steve
Hi steve, if you say there are none, then there are none naah, honestly, I'd improve some things on the next model, even productionfriendlynesswise...
Thank you very much,
RD
Old Jan 20, 2003, 06:10 PM
U812 is offline
Joined Sep 2002
No, thank you for the inspiration!
I'm growing tired of doing foam and wood jets these days. Having plenty of moulding experience in the film biz I'm sure I can adapt to epoxy glass procedure.
My next project will be for glass once I figure out what bird. I want to do something simple for my first one so I'll better better prepared for that 104 down the road. Seeing your work really gets me going.
Steve
Old Jan 23, 2003, 08:39 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
some more
vertical fin support
Old Jan 23, 2003, 08:42 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
aft top view
Old Jan 23, 2003, 08:44 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
aft side view. if you look closely you'll see the locking screw for the vertical fin.
Old Jan 25, 2003, 02:50 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
wing layout.
getting it ready for the spring airs(still waiting). for those who are getting the new design wing, you won't need to do this!
Old Jan 25, 2003, 04:59 PM
Tear down the WALL!
southern Germany
Joined Oct 1998
Hi all, sorry, but you will have to do this, too. But it will be easier because there is no spar in the way and the cable tubes are installed.
gregg, wait with gluing until you have your spring airs and the new CD-ROM, it should be in the US by now.
cheers, RD
www.rd-jets.de
Old Jan 26, 2003, 03:13 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
waiting for spring airs to arrive, to continue on the wing. made up a 20xhr2600 pack for her.
Old Jan 26, 2003, 03:18 PM
U812 is offline
Joined Sep 2002
Looking serious Gregg. Keep going.
Steve
Old Jan 26, 2003, 03:46 PM
uncljoe is offline
Find More Posts by uncljoe
Col.Hooligan Air Force
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
LEAD WEIGHT
gregg
with the gold color of the pack I hope the Brick weights a lot less than it looks
Semper Fi
Joe
Hope your Spring Airs arrive this week
uncljoe is offline Find More Posts by uncljoe
El Bandito Chris True Electric Ducted Fan Jet Talk 202 Dec 23, 2003 05:45 PM
El.Bandito RG ralf dvorak Electric Ducted Fan Jet Talk 23 Jan 18, 2003 12:01 PM
RD-Jets finally in english, too. El.Bandito etc. ralf dvorak Electric Ducted Fan Jet Talk 5 Jun 24, 2002 09:50 PM
El Bandito (ralph Dvorák) Anyone Flying It? CESARNOGUEIRA Electric Ducted Fan Jet Talk 11 Mar 17, 2002 08:28 PM
finally available: "El.Bandito" is here! ralf dvorak Electric Ducted Fan Jet Talk 19 Dec 13, 2001 06:04 PM
