Old Jan 14, 2003, 09:47 PM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
el bandito construction & flying thread
view of the fuse. it comes in 4 pieces. aft end is off here
gregg f is offline Find More Posts by gregg f
Old Jan 14, 2003, 09:49 PM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
cockpit view. yellow housing is for the main wing joiner.
Latest blog entry: Electra
Old Jan 14, 2003, 09:50 PM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
intake view
Old Jan 14, 2003, 09:52 PM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
outlet view (the blow end)
Old Jan 14, 2003, 09:53 PM
Joined Sep 2002
About time you started a building thread.
Thanks Gregg, this will be a great one.
Steve
U812 is offline Find More Posts by U812
Old Jan 14, 2003, 09:55 PM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
main fuse joint. for fan access etc. 5 tapered screws hold it together. on the bottom you can see the countersunk hole so the screw mounts flush with the fuse........gregg
Old Jan 14, 2003, 11:47 PM
Col.Hooligan Air Force
uncljoe's Avatar
Phoenix,Arizona
Joined Jul 2001
Gregg
That Schubi looks goos tucked in there, are the intakes installed or are they part of the 4 part fuselage . expect to see at least one posting of photos per day.....Kidding....
Semper Fi
Joe
Maybe I'll pick up one of these Rockets
uncljoe is offline Find More Posts by uncljoe
Old Jan 15, 2003, 08:58 AM
Flying Welder Pilot
Plane Crazy's Avatar
Reno, Nevada
Joined Jan 2001
Looks So clean...So what color scheme are you going to go with? HI VIS?
I guess that wing must be pretty thin too on that thoroughbred, after seeing the special wheels Ralf had to make up for the El Bandito.
Gordon
Plane Crazy is offline Find More Posts by Plane Crazy
Old Jan 15, 2003, 09:05 AM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Joe: the intakes are installed seperately. they are preformed and install easily.
Gordon: red/white is high vis for me.root thickness is 22-3mm at the high point........gregg
Old Jan 20, 2003, 09:42 AM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
a few more pic's
frt fan former with schubi
Old Jan 20, 2003, 09:43 AM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
rear fan former in aft fuse
Old Jan 20, 2003, 09:44 AM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
rear fuse connectors
Old Jan 20, 2003, 09:45 AM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
vertical fin & rudder assy
Old Jan 20, 2003, 10:10 AM
norway
Joined Jul 2002
Great thread Gregg
Let me come with a small advice,In the aft fuse where the elevator servos are to be installed ,the fuse is very thin and a bit flexy ,i had some flutter on the first flight and traced it to the flexing elev servos.I stiffened it with a carbon mat and the problem dissapeared.What to you plan for covering the wings?
The leading edge is made of very light balsa and i suggest
you saturate it with cyano to harden it.I got some dents in them
and had to repair it,but then again i landed in hard snow.
otherwise its perfect,you will enjoy it very much .what will power it?
Terje S
terjes is offline Find More Posts by terjes
Old Jan 20, 2003, 10:21 AM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Originally posted by terjes
Great thread Gregg
Terje S
Terje: thanks for the advice!
i planned on glassing the wing/stab/fin. with the built in hinges, i'm not sure about how to do this on the upper surfaces.
hacker b50-16L for power.............gregg
El Bandito Chris True Electric Ducted Fan Jet Talk 202 Dec 23, 2003 05:45 PM
El.Bandito RG ralf dvorak Electric Ducted Fan Jet Talk 23 Jan 18, 2003 12:01 PM
RD-Jets finally in english, too. El.Bandito etc. ralf dvorak Electric Ducted Fan Jet Talk 5 Jun 24, 2002 09:50 PM
El Bandito (ralph Dvorák) Anyone Flying It? CESARNOGUEIRA Electric Ducted Fan Jet Talk 11 Mar 17, 2002 08:28 PM
finally available: "El.Bandito" is here! ralf dvorak Electric Ducted Fan Jet Talk 19 Dec 13, 2001 06:04 PM
