Old Feb 19, 2012, 04:38 AM
Joined Jun 2011
Radar antenna rotator.
Hi,
Has anyone dabbled with continuous rotation servos for rotating radar antenna? I can do slow movement (up to about 180 degrees) with a standard servo and a small micro but from what I'm reading the continuous servos are forward reverse control only and have little speed adjustment. Any ideas?
Cheers,
David
KiwiDavid is offline Find More Posts by KiwiDavid
Old Feb 19, 2012, 06:20 AM
Zen09's Avatar
Romania, Galati, Galati
Joined Jun 2010
Remove the potentiometer and the mechanical travel limitator and you've got an unlimited rotation servo. You can adjust the speed (in both directions) from very low (3-6rpm) to as high as the servo can(30-100rpm).
Zen09 is offline Find More Posts by Zen09
Old Feb 19, 2012, 10:37 PM
Joined Jun 2011
Hi Zen09,
Thanks for the reply.
I was aware of the changes required -
Swap the potentiometer for two equal resistors of the approx same value (2.2K?)
Remove any mechanical restrictions to allow 360 rotation.
For the speed control are you varying the servo pulse width or the motor supply?
I was of the understanding that changing the pulse width to achieve speed change was somewhat erratic and that all the change would take place in the 100uS about the central stop position.
Cheers,
David
Old Feb 20, 2012, 03:57 AM
Zen09's Avatar
Joined Jun 2010
By varying the servo pulse width you adjust the speed of the motor, the servo is like a two way brushed ESC, with a feedback potentiometer so that it knows where to stop.
I don't know exactly what precision can you expect on the high side, but at low speed it's pretty precise.
Old Feb 20, 2012, 10:09 PM
Joined Jun 2011
Hi Zen09,
Thanks for getting back. I guess I will just have to try modifying a servo and write some test code to try it.
If it works out OK I have some friends in the warship group who will be pleased to learn of a method to rotate their radar dishes at the correct rpm.
Cheers,
David
Discussion A Really Small Rotator ... flattermann RC Kites 5 Mar 20, 2012 01:13 PM
Discussion Handheld Radar vs. Onboard Radar vs. Pitot Tubes: Time to Discuss Aerogance Dynamic Soaring 78 Feb 13, 2012 01:36 PM
For Sale Stalker Pro Cordless Radar DS Radar Bart Vaio Aircraft - Sailplanes (FS/W) 0 Nov 12, 2006 04:49 PM
New Product Hot Wheels Radar Digital Radar Gun Bilbobaker Power Systems 18 Oct 29, 2006 04:56 PM
FS:Radar Guns - Prospeed™ CR-1K Radar Gun speedster Aircraft - Sailplanes (FS/W) 6 Jan 18, 2005 03:07 PM
