Old May 31, 2012, 04:53 PM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
Originally Posted by .quietguy View Post
I thought the sequence was:
Power up the TX first.
Set power 'on' to the heli.
Throttle stick slowly up, then down.
Light flashes, beep, then fly.
Or do I have it all backwards?
... Lennie .
Here's a link to the English Instruction Manual for the F-45.
http://www.mjxtoys.com/UploadFile/F45EN.pdf
It says on Page 7:
  • Insert the battery plug into the helicopter battery socket located at
    the right side of the helicopter, then, the indicator light of the helicopter
    will keep flashing rapidly, set the helicopter down to a platform.
  • Slide the power switch to “ON” position. To activate the remote
    controller,slowly push up the throttle stick to the top and then push
    it down to the bottom. The remote controller is activated once you hear
    a beep sound.Then, the indicator light flashes rapidly while the remote
    controller is sending out connectional signal.
  • When the whole auto signal connection process is finished, push up the
    throttle stick slowly and the helicopter takes off.
  • User may push either of the control sticks to skip the auto signal
    connection process once the helicopter finished signal connection.
  • Once the transmitter is turned off, the connection procedure must be
    repeated to operate the helicopter.
  • Please pull out the battery plug from the helicopter battery socket.
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old May 31, 2012, 04:55 PM
markkona is offline
Find More Posts by markkona
when is the wind stopping??
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
if it binds with the sequence you use I see no problem anyhow you do it. I have always bound the heli this way and will continue to do so. The tx is the last thing I turn on throttle up and down and it's bound to the heli always with no problems. The V911 tx on rare occasions didn't bind successfully with the first attempt and this happened on both V911 tx's that I currently own so it s not a one time glitch. happy flying folks
markkona is offline Find More Posts by markkona
Old May 31, 2012, 05:04 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Nice video. Are you sure you want to go back to brushed? It won't perform like that.
The way you bind is the way I bind. I always plug in the heli first with all my helis except the Xeida 9958 which has no control circuitry to require the tx be bound.
The process to turn on the tx first and then power up the heli is a safety feature that was used in older radio/ESC systems that did not have good fail safes like most do today, very similar to the Xeida.
Going by the manual method is prefered by the manufacturer.
ps
The other reason to turn on the tx first is when flying with buddies. I have no friends so it is not an issue for me. If you both fly the same heli, it is possible to end up with both helis bound to on tx if the tx is not sending a signal when the heli is power up. Rare, but is does happen as per the 9116 thread.
BThirsk is offline Find More Posts by BThirsk
Old May 31, 2012, 05:11 PM
markkona is offline
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
ps
The other reason to turn on the tx first is when flying with buddies. If you both fly the same heli, it is possible to end up with both helis bound to on tx if the tx is not sending a signal when the heli is power up. Rare, but is does happen as per the 9116 thread.
Don't know really because it is very fast now I think it can go past the 50km/hr mark with this motor and I don't have a big open clear flying area near me there's always a pole or electricity wires in the way!!
Old May 31, 2012, 05:39 PM
TonganSojah is offline
Find More Posts by TonganSojah
Joined Apr 2012
hey guys is there a BNF version of the f45 or is it just RTF?
i would like to buy another one for my brother in law but i don't want another tx i already have 2.
TonganSojah is offline Find More Posts by TonganSojah
Old May 31, 2012, 05:40 PM
.quietguy is offline
Find More Posts by .quietguy
Closed Account
Joined May 2012
Come on fellas, go easy on this old noob...
I read the manual (english version) and I guess I'm a slow learner, I didn't pickup on the "copter on first", then the TX.
But, since I was born dumb, I'll trust all of you experts and do it your way - that is, once I get the bird in my ugly ole paws..
Thanks for the help, guys.
... Lennie
.quietguy is offline Find More Posts by .quietguy
Old May 31, 2012, 05:44 PM
markkona is offline
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
Tonga....no bnf unless you want to buy all the parts from Aliexpress and build up one yourself
Glad to be of help anytime Lennie. cheers
Old May 31, 2012, 08:56 PM
Joined Apr 2012
Haha no thanks I don't want to end up building a boat instead of a helicopter.
Mark what's your next heli going to be?
Old May 31, 2012, 10:29 PM
slothy89 is offline
Find More Posts by slothy89
Head in the clouds
slothy89's Avatar
Australia, VIC, Sebastopol
Joined Apr 2012
From one seller it will cost you $123.50 USD plus shipping to build from parts
Although I just noticed that doesn't include the swash and body frame...
Better off buying a complete Heli and selling the TX
slothy89 is offline Find More Posts by slothy89
Old May 31, 2012, 11:44 PM
Mitch332 is offline
Find More Posts by Mitch332
V911 F45 Super CP
Joined Apr 2012
Has anyone tried putting a scale fuselage on one of these yet?
Mitch332 is offline Find More Posts by Mitch332
Old Jun 01, 2012, 12:03 AM
Heli Mania
PNW
Joined Dec 2010
I noticed tonight that Banggood is starting to get some spare parts for the F-45. The list will probably grow with time.
http://www.banggood.com/buy/MJX%20F4...0-0_page1.html
Old Jun 01, 2012, 02:41 AM
Tumppi T is offline
Find More Posts by Tumppi T
Registered Crasher
Tumppi T's Avatar
Finland, Tuusula
Joined Mar 2012
...and here is also lots of spare parts for the F45
http://www.feala.com/mjx-F645-F45-RC...-F45-parts.htm
Tumppi T is offline Find More Posts by Tumppi T
Old Jun 01, 2012, 06:54 AM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
I have a suggestion that will make your Heli more manageable.
Get some extreme fibre 10degree blades.
These will move you throttle at hover and general flying closer to 50% stick. If you have stock blades, you are probably at 35% stick.
It also increases head speed which increases response and stability against wind.
Old Jun 01, 2012, 07:16 AM
markkona is offline
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
Those and a DD extreme tail motor conversion are next on my agenda but I am buying a spare stock tail motor just in case it suddenly gives up on me as I don't want to be grounded right now coz it's a blast to fly now
Old Jun 01, 2012, 07:20 AM
markkona is offline
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
Too many options to decide right now I'm torn between getting a 500-550 clone or this ;
http://www.ebay.co.uk/itm/ADVANCED-6...item58912c23ba
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
