Old Feb 12, 2013, 10:41 AM
Zarrick is offline
Find More Posts by Zarrick
THE TRUTH IS OUT THERE
Zarrick's Avatar
Slovakia, Veľké Kapušany
Joined Nov 2012
baddb1 thanks for your answer! But sadly, its somehow not working. But I just find out that when I normally pair the Tx with PCB (right now after pairing the throttle is at 0%) and power on the ESS after that, everything is working well. So all what I need is a switch on the ESCs power cord and turn on the ESC after binding the heli, not at once with powering on the PCB.
Zarrick is offline Find More Posts by Zarrick
Old Feb 12, 2013, 10:44 AM
kpinnc is offline
Find More Posts by kpinnc
Goooo!!!! Get to da choppa!!!!
United States, NC, Albemarle
Joined Jan 2013
I'm sorry arrowshooter, I read what I wanted to and confused myself. I'm still working on the terminology curve... I want a shaft or belt driven tail, and yes I'm going brushless...
kpinnc is offline Find More Posts by kpinnc
Old Feb 12, 2013, 10:54 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
That is the way it is supposed to work after you have set up your throttle end points for the first time.
Bind, make sure throttle is at 0%, then power up the ESC.
Your set to go.
BThirsk is offline Find More Posts by BThirsk
Old Feb 12, 2013, 10:57 AM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Dirty snow
I found this cool spot yesterday where there were piles of dirty snow piled up on a field. It made me want to shoot some flying video skimming just above the ground and then punching the throttle just enough to clear the tops. The scale was a bit off as the helicopter was bigger than some of the peaks but I think there were some good passes. It would have been even better if the peaks were 10x bigger. Anyway, it was fun times and I figure I should share it with ya.
F45 over the snow & gravel peaks (11 min 51 sec)
rexless is offline Find More Posts by rexless
Old Feb 12, 2013, 10:59 AM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
Gothchya. In order to have a shaft or belt driven tail you will need to incorporate a receiver that has a rudder servo port. In my F45/450 conversions I used the Walkera 2437V from the V200D01 that also includes a 3-sxis gyro.
arrowshooter is offline Find More Posts by arrowshooter
Old Feb 12, 2013, 11:16 AM
kpinnc is offline
Joined Jan 2013
Thanks. That's kinda what I was thinking. Thought the tail motor will be the "weak link" in the F45 if I EVER get my EH200 in, I think I'll save the belt-driven tail for another project.
I keep a couple spare tail motors on hand anyway...
Thanks again!
Old Feb 12, 2013, 11:24 AM
fauconnier is offline
Find More Posts by fauconnier
Flying a Falcon or a 3D plane.
fauconnier's Avatar
Canada, QC, Rimouski
Joined Jul 2012
Did someone tried the combination, stock frame, BL main, stock tail, non-stock 4 ch. PCB + transmitter ? Does the new F45 fly well enough, exempted of the cyclic return, to do upright fancy figures ?
fauconnier is offline Find More Posts by fauconnier
Old Feb 12, 2013, 12:37 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
It would make no sense to change to a different Radio system and still use the stock tail. You would need a brushed ESC to run it.
It would be better to go brushless direct drive tail. A brushless may be slower as reported, but it has the power to run direct drive, so even though a little slower, it will still be faster than the gear reduction brushed motor as I has to turn only 1/4 of the speed of the brushed motor to produce the same output.
Old Feb 12, 2013, 12:51 PM
kpinnc is offline
Joined Jan 2013
Is there such a thing as a dual ESC, or do you just have to put two of them on a heli if running full BL?
Old Feb 12, 2013, 01:03 PM
Joined Aug 2012
You would need to run two ESC's.
Old Feb 12, 2013, 01:18 PM
Joined Aug 2012
I agree. You will not find a system that will handle a BL main with any type of tail motor without additional modification. You can look at some of the things these guys are doing to get an idea. http://www.rtf-heli.com/index.html
Old Feb 12, 2013, 02:04 PM
baddb1 is offline
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Originally Posted by Balr14 View Post
It was common to do a direct drive tail conversion on the HBFP. But, even though that heli is the same size, it had far less weight. So, I don't know if that would work. You might try reducing main rotor torque by trimming the blades down a little. That would require a lot of trial and error.
I wonder if the HB blades will work any better? I have had a set on order for a little while now, they should be here any day now....
baddb1 is offline Find More Posts by baddb1
Old Feb 12, 2013, 02:12 PM
Joined Aug 2012
http://youtu.be/WEnRHrBh7tI
That's pretty cool. Looks like you are flying over mountains.
Old Feb 12, 2013, 02:14 PM
rexless is offline
rexless's Avatar
Canada, BC
Joined Apr 2012
I use the Extreme for HBFP blades and it does help but I do get some twisting from an under-compensating rudder if I punch the throttle too hard. It also gets rid of that problem where the stock blades flap at higher-than stock RPM but I am running 3S for the main motor.
I've gotten used to it so I know to expect it if I punch the throttle in a panic. Most often I just move the throttle up in a smooth motion until I get the speed I'm looking for and it works fine.
Old Feb 12, 2013, 02:37 PM
Zarrick is offline
Zarrick's Avatar
Joined Nov 2012
Your set to go.
Thats great! Can't wait to receive my second order from HK with pinions and charger, it should arrive this week.
Anyway, does this little switches (you know, standard metal/plastic switch as are they used in DIY amplifiers) have something like "electrical standards"? I mean that one can be used only at max. 2A, other one at 5A etc. As the switch goes at the ESCs power wire and its max is 18-20A
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
