Joined Jan 2013
Hi Guys! I just got my new F45 a couple of days ago and I'm completely in love. Coming from an s107g coax heli it's nice to have something I can fly outside. I've had a couple of small crashes but nothing major and most importantly nothing broken...so far. lol I have everything configured right and she flies good and hovers great. My only issue is that I notice the body of the heli leans a little to the right. Is this normal? I thought adjusting the swash plate or something might fix it but I've had no success. Makes it a little more difficult to bank a left turn if the body is leaning to the right. Any help would be greatly appreciated. Love the forum! Bought my f45 after reading a lot of information on here.
Thanks Danny |
Check back posts from fauconnier from the last week or so for details. Cheers Tigg |
The brushless conversion for the tail is more complicated. There is no signal other than directly on the board. Moki managed to locate the signal and soldered directly to to outputs on the board. Otherwise, you need a signal converter and the extreme version does not have the right thresh hold to work properly with our boards voltage output. There was a similar problem with 2 Walkera helis, the MasterCP and the V400D02. They are both flybarless, both use the same motor, and similar RXs, but the outputs to the tail are different requiring different signal converters. I really feel when going to all the trouble to convert the main and tail motor to brushless, a new RX, a 10.00 gyro, and a good TX complete the modification. You can get many programable TX/RX combinations for less than 100.00. The skids I got are from oomodel.com. Any Align compatible skid will do. Just need to drill new 3/16 inch holes to mount the skids over the original pins for mount the stock skids and you need 2 washers to go over the screws on the from skid. The rear has the stabilizer arms going under the skid so washers not required there. |
Joined Dec 2012
Oh oh OH lads I stumbled upon THE ULTIMATE LED NIGHT FLYING MOD, but... nae, lads, i canna tellit... its simply too good to tellit. I might actually post a wee vid if I can get the 1999 era webcam to cooperate. |
Joined Dec 2012
Finally woke up enough to peek outside for a 'wee run'... the bloody wind is outta the north @ 10 mph on the north bld, 200 feet south, the wind is outta the south @ 10 mph... Can you say 'turbulence'. me thinks some indoor time is indicated lol |
Thanks for the info, I'll have a look see. Fin |
Joined Dec 2012
F45 tx antenna mod
I had the F45 (old style) tx apart the other day, seen the 'antenna' is nothing more than a isotropic radiator... So I took the antenna/connector from a wifi wireless computer adapter and modded it. Now I have a detachable antenna thats 5.1 db gain over the isotropic one. Works out to be 1.7 times the prior output. Yes It has the angled ability like the stock one. Radio range'd it out to 2500 feet (762 m) before I grew weary of fighting the ice/snow... and that was with less than 'fresh' tx batteries. Thats range you can fly as far as you dare and be nowhere near the edge, even in worse case developements. well except for 'submarine flights'... LOL
flyin til i b dyin |
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
