Old Mar 22, 2012, 12:22 AM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
I have been working with Ben at Shantou MS Toys to put together an English parts list for the F45. I spent a lot of time using online translations until the parts names made sense for both of us (kind of). Here is the finished product.
Using this should ensure we are getting the correct parts. Although there are other places that now have some parts, Ben has all MJX parts at fair prices and I have ordered from him many times.
gordonzo is offline Find More Posts by gordonzo
Old Mar 22, 2012, 12:45 AM
Whizgig is offline
Find More Posts by Whizgig
Eugene
Whizgig's Avatar
Australia, VIC, Delacombe
Joined Oct 2006
Well done thanks for that.
Whizgig is offline Find More Posts by Whizgig
Old Mar 22, 2012, 06:11 AM
Gorduza is offline
Find More Posts by Gorduza
New to hobby
Gorduza's Avatar
Czech Republic, Central Bohemia, Tınec nad Labem
Joined Mar 2012
That is very helpful gordonzo, also first place where I've seen all spare parts available. I kind of hoped that there will be tail motors sold separately, but my wishes were not answered.
Something tells me, I am going to be very happy this weekend.
Gorduza is offline Find More Posts by Gorduza
Old Mar 22, 2012, 12:11 PM
gordonzo is offline
gordonzo's Avatar
Joined Jan 2011
For some unknown reason, the tail assembly comes as a complete bolt-on unit with everything. But at lease it is quite inexpensive for the sum of those parts. If you buy from Ben frequently he will give you some really good prices.
Old Mar 23, 2012, 06:37 AM
Whizgig is offline
Eugene
Whizgig's Avatar
Joined Oct 2006
Most of them are doing this now and it makes it better to install a new tail unit rather than a new motor and cheaper as well.
Old Mar 24, 2012, 09:07 PM
Whizgig is offline
Eugene
Whizgig's Avatar
Joined Oct 2006
Well my MJX-F45 has just landed at Melbourne airport and is now going through customs and should be in my greedy little hands on Monday or Tuesday.
I will then put it up against the DH range of helis and give you all my thoughts and findings on both of them.
Old Mar 25, 2012, 03:56 AM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
looking forward to it mate
sammyc is offline Find More Posts by sammyc
Old Mar 25, 2012, 10:28 AM
freezywilly is offline
Find More Posts by freezywilly
Joined Jan 2012
A comment on the Mjx-f45 transmitter
While the manual is good the transmitter has a gotcha.
It allows 4 modes 1 thru 4 however the mode 2 and 4 have a reversal
Mode 4 works as mode 2 with throttle and rudder on left stick
elevator and aileron on the right. Mode two reverses the rudder and aileron.
Download the manual as the book for the transmitter is of no value.
freezywilly is offline Find More Posts by freezywilly
Old Mar 25, 2012, 03:14 PM
Gorduza is offline
New to hobby
Gorduza's Avatar
Joined Mar 2012
I got mine this friday! Been out of town, so I wasn't able to fly it much yet (took it out for a minute or two. First impression is how huge this heli is! Second thought was... this bird needs a lot of place... as you mentioned gordonzo. Field will suite it well. Tomorrow shall be my flying day. For now, I am just going to try hovering in the hall I have next to my apartment. More thoughts later...
Old Mar 25, 2012, 05:59 PM
gordonzo is offline
gordonzo's Avatar
Joined Jan 2011
I know their numbering system can be confusing but that is MJX's own mod numbering system, short for model 1, 2, 3, or 4, not mode.
Before you take it out to a larger area, set the fwd elevator to 100% and bump the throttle mid-point up to 65%.
Old Mar 26, 2012, 03:24 AM
Gorduza is offline
New to hobby
Gorduza's Avatar
Joined Mar 2012
So I've been flying inside for a while and got it hovering pretty well. Don't know how much to trim, because it seems that it is hovering well. The moves heli had may be due to wind in the room. What I think is not because of the wind, is turning around its axis (rudder?) but that may be due to low battery, need to try few more times. I have AILE 50% ELEV 50% RUDD 40% THRO 45% (I don't hit my 2,5m ceiling and have stick in the middle position). The motor could use some heatsink.
Thanks for info gordonzo, I will set it accordingly to your set up and I shall see. Have you trimmed your heli in any way?
After all I have both my hands made of "idiot". I broke the little "wing" on the tail boom while lifting my heli from the ground. It cracked a little, because I am stupid. Now I need some glue, but not sure what type of plastic is it? Can you recommend some type of glue that should do it?
EDIT: I believe breaking is learning, so I broke the red nob siting on the main shaft... the rest is OK, just the little nob fell off. I cut the power (was at 30cm in the air) than it hit the wall and fell on the nob. Do you think that it is possible to fly without it, or does it have any special reason to be there?
I am going to order some spare parts from the link gordonzo posted. What other spare parts would you recomend buying?
main shaft (the plastic head) 2x
landing skids 1x
swashplate 1x
blade holders 2x
links for flybar (pair) 1x
Old Mar 26, 2012, 06:36 AM
markkona is online now
Find More Posts by markkona
when is the wind stopping??
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
Jesus christ I have read your last post Gorduza and nearly choked with laughing!! Man where do you find such sayings?! I believe breaking is learning!! I don't think you need to glue the one in the first pic but the round knob in the second pic might have been used to keep something in place so check before flying without fixing it first!
markkona is online now Find More Posts by markkona
Old Mar 26, 2012, 07:35 AM
Gorduza is offline
New to hobby
Gorduza's Avatar
Joined Mar 2012
So I checked that the knob does not do anything, only covers the shaft from the top and has aesthetical purpose. The knob wasn't attached to anything, nor he was blocking the flybar from going too high. There was about 1mm space between the flybar and the knob. Even ehen I pushed it, it didn't touch. Therefore I tried to fly gently and no problem at all.
Please someone comfirm my list of spare parts, I don't want to buy something I will not need.
Breaking is learning. You can say this about almost everything.
Old Mar 26, 2012, 07:37 AM
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
I would definitely get spare blades of I were you and maybe spare blades for the tail motor as well!! You never know
Old Mar 26, 2012, 07:49 AM
Gorduza is offline
New to hobby
Gorduza's Avatar
Joined Mar 2012
The heli came with a pair of main blades and one tail blade. I don't really plan on breaking the blades because from what I've seen on this video (time 0:20), those blades are touhg and flexible. Although I see the blades to bend upwards a little, while flying that may be because they are so flexible.
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
