Joined Dec 2012
and yes i think the heatsinks do help, i published rate of rise results a page or 50 back (even after 11 min flight-time my main motor temp was only 111 degrees f with a r.o.r. of some 7.75 degrees per min) Made my heatsinks outta alum kitty food cans (and saved some 17+ dollars shipping )
You can heatsink the Fets with flat heatsinks as I have done and yes solder the motor wire to the PCB the plug is useless, in fact I am amazed that the plug doesn't melt with the heat from the wire. I also run heatsinks on the motors and I replace the wire to the tail motor with solid core wire as well, maybe thats why mine is still running the original motors. |
Joined Dec 2012
Yea, that main motor plug would barely do the tail motor... and the tail motor plug is good for perhaps .5 - 1 amp for any time. I forgot to post I changed the micro wires going to the tail motor too.
I am pretty sure that a thermo probe would show a gastly amount of hot spots on a 'stock' setup |
Joined Dec 2012
Now I am wondering if the crap aftermarket 2200 ma battery was responsible for the FET's untimely death, as it died pretty much the very same day I discovered the battery's failure. And yes, i had a tin-can heatsink on it too.(could tell it had been rather hot, it was purple and mostly unsoldered itself) I dont recall much on the main FET dying.
My motors get warm but not hot that you would burn yourself with, and I think my batteries last longer with the setup I have but I'm not 100% sure on that as I haven't timed a flight for a long time. I do this with all of my heli's even my micro's. |
Joined Dec 2012
It has to do with circular mils/amp. In the motor rewinding world we used 750 circ mils/amp. Mind you this is continous duty rating. Often times I would rewind with smaller wire, using more of them 'in hand' with the same results.(I liked to add a few c/m, making my rewinds better) Stranded wire reduces 'skin effect' (where the electrons mostly move on the skin of the conductor) which I believe is only really valid with high frequency AC. (is why BL ESC wires are stranded)
I pulled MILES of cable/wire in my time. |
Joined Dec 2012
and while we at it... take a close look at the solder connections associated with the high current circuits (Battery-Main motor-Tail motor). If them solder connections look greyish or appear to have crystals/bumps within, they are NOT good solder connections. A good connection is always bright with no appearance of bumps/crystals/ect. The '45 board is loaded with poor solder connections. If the rx/decoder sections work, dont bother them much... The motor circuit connections will rejoice with good sound solder connections... (and so will you
Aliexpress BL conversion
Well all good so far and it handles like a dream . Here is the link just make sure you have a v2 although there is a v1 as well http://www.aliexpress.com/snapshot/210962347.html
Uploaded some pics of it but excuse the tape on the battery holder as waiting for a new battery tray and I am experimenting with higher amp batteries |
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
