Old Jan 20, 2013, 02:27 AM
OldOz is offline
Find More Posts by OldOz
John
Australia, QLD, Brisbane
Joined Aug 2012
(deleted)
OldOz is offline Find More Posts by OldOz
Old Jan 20, 2013, 02:45 AM
asanovrus is online now
Find More Posts by asanovrus
asanovrus's Avatar
Ukraine, Crimea, Bakhchysarai
Joined Mar 2012
Originally Posted by fauconnier View Post
I have one of each. There is no significant difference. The protocol is not the same, you can't use the transmitter with the other heli. Right now, you will get the best price at Aliexpress, $83 U.S. for the new model, with the small package, a safer way to ship.
This http://www.topstoys.com/new-free-shi...em-p-3532.html (bottom of the page) says that version 2 has gyro lying down while on version 1 it stand up. Is that worth doing incompatible versions?
asanovrus is online now Find More Posts by asanovrus
Old Jan 20, 2013, 03:00 AM
OldOz is offline
John
Joined Aug 2012
What I find interesting is why on earth the BL upgrade kit described should need two versions, irrespective of Version 2 Rx and gyro changes? - as above, old and tired. Maybe someone can enlighten me. .
Old Jan 20, 2013, 03:54 AM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
twitchy servos
Hi guys
Big Bird II arrived yesterday just before I had to go to work. Only had enough time to find out that the charger doesn't work (email sent straight away) and that the heli made a "tsst, tsst, tsst" sound when running on the bench. Thought it might have been flybar strikes caused by slop in the blades, so I shimmed them without any noticable improvement. My thoughts then turned to unbalanced blades maybe having the same effect (strikes) but since I don't yet have fine scales I couldn't check it. Made a vid for analysis below. As can be seen, the flybar looks to be balanced and not hitting the blades.
"tsst, tsst, tsst" noise (0 min 40 sec)
Had a closer look this morning and discovered that the aile and elev servos have their own minds, and start twitching when the battery is plugged in. Happens even before binding with the TX. The noise I heard is obviously the servos twitching when the motor is running.
twitchy servos (0 min 17 sec)
Is there an easy fix for this or do I need to send the heli back as a duffer?
Sorry about the vid quality... took it on my #808 so couldn't see what I was filming
Cheers
Fin
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Jan 20, 2013, 04:04 AM
Flyor is offline
Find More Posts by Flyor
The Netherlands, ZH, Rotterdam
Joined Aug 2012
You said that heli is ok, but what was the camera?
Camera is ok too, rinsed with clean water, dried with compressed air.
The camera is a 808#16 key chain cam with the B lens.
There is a whole active newsgroup for this camera.
http://www.rcgroups.com/forums/showthread.php?t=1777846
Regards
Flyor is offline Find More Posts by Flyor
Old Jan 20, 2013, 04:08 AM
asanovrus's Avatar
Joined Mar 2012
I notice MJX doing weird things with their products. x200 has incompatible radio with all others(f45, x100, f47). WL radios are all compatible, even camera quad v959 can fly with all others (v911,v912,v929,v939,v949) expect you can't turn on the camera. If I didn't order 2 of f45 and didn't need camera on big heli I would move to WL v912 which is almost the same (a bit smaller) but no brushless and other upgrades available so far. All my other helis will be certainly WL
Old Jan 20, 2013, 04:14 AM
asanovrus's Avatar
Joined Mar 2012
Regards
I'm amazed how camera and videos could survive after visiting underwater world for some time. Keep on experimenting What next? flying over open fire?
Old Jan 20, 2013, 04:20 AM
Flyor is offline
Joined Aug 2012
Originally Posted by arrowshooter View Post
.... You/We are truly an amazing group. (no crying now)
Steve
It is an amazing group, but you still have a partly F45/450 so don't be a stranger
Thanks for the list, I'm tempted to go there also... maybe one day
Regards
Old Jan 20, 2013, 04:49 AM
Flyor is offline
Joined Aug 2012
That's strange, maybe the swash plate can't move freely, does it also happen when you disconnect the servos from the swash plate?
Regards
Old Jan 20, 2013, 04:50 AM
OldOz is offline
John
Joined Aug 2012
Regards
Or the 'basic' 450 U/G
- http://www.hobbyking.com/hobbyking/s...dProduct=14571 (frame)
- http://www.hobbyking.com/hobbyking/s...dProduct=11884 (motor)
- http://www.hobbyking.com/hobbyking/s...dProduct=15259 (pinion)
- http://www.hobbyking.com/hobbyking/s...idProduct=4312 (ESC)
- http://www.hobbyking.com/hobbyking/s...dProduct=14665 (battery)
Gives you a BL with a difference: can lift 250g+ payload, and do 45+ kph. Plus - you still have a 'F45', and will qualify for this thread and Arrowshooters new one!
Actually, the whole shebang above is only about 40 bucks dearer than the 'full upgrade kit' a few posts back.
You know you want to, Flyor!
Cheers
John.
Old Jan 20, 2013, 04:58 AM
nolivy is offline
Find More Posts by nolivy
Joined Dec 2012
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Hi, its me again, I am having trouble deciding what batteries to go as an upgrade, does the above link will work on f45 as well?
Can anyone give me a link on what is the best battery for the f45. Having troubles finding them here in the forum.....lots of info though but it makes me more confused....lol.
nolivy is offline Find More Posts by nolivy
Old Jan 20, 2013, 05:09 AM
OldOz is offline
John
Joined Aug 2012
This (from memory) is the best for stock f45
http://www.hobbyking.com/hobbyking/s...dProduct=23820
Will require some minor mods to battery holder, but fits well otherwise and has right connectors.
Scotsman in Germany
Joined Oct 2012
Regards
Just tried it again. Doesn't twitch any more, but now I have a constant buzzing when I plug the battery in - as though the servo it trying to do something - and have no aile reaction at all to the sticks. Elev servo seems to be OK now, but I think the bird's going back. Something stinks
nolivy is offline
Joined Dec 2012
Cheers
John.
Hmm, this caught me alot..... care to share a tutorial how to do this on the f45 please? Thanks.
R.C. Man is offline
Find More Posts by R.C. Man
Frank
Germany, BW, Heubach
Joined Dec 2012
Hi guys
http://www.youtube.com/watch?v=QPvD9...ature=youtu.be
http://www.youtube.com/watch?v=eeG0t...ature=youtu.be
Cheers
Fin
Wow Fin,
You got a problem child there,
Try moving the servo wires around, I had a problem something like that after rebuilding my 45 completely
my tail was moving on its own, and I just moved the wire routing, and was all ok again, maybe getting a frequence from the electronics on pcb.
Frank
R.C. Man is offline Find More Posts by R.C. Man
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
