Old Jan 09, 2013, 11:09 AM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Originally Posted by ITS ME DAVID View Post
I have a hero rc h911 will this heli be the next step to take I'm looking at flying a bigger fp 4ch heli.
There are plenty of next steps. This was mine and I can't get enough of it
Originally Posted by sergiopov View Post
Friends, I want to buy a heli MJX. Which is better: f45 or F46?
Sorry, don't have an F46 (don't know of many who do) but IMHO you can't go wrong with the F45.
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Jan 09, 2013, 12:37 PM
hawaiichopper is offline
Find More Posts by hawaiichopper
United States, OR, Portland
Joined Oct 2012
Originally Posted by BobTopofTheWorld View Post
Both my main and tail gears seem awfully tight on the f45, perhaps they get better after a wee break-in run... still seems like the gearsets should turn as easy as a v911 (it is currently on the carport roof ) Reminder to self: RUNNING LIGHTS
Yes I checked the rear when I ran the LED wire, a micro amount of play would be nice this is so tight it makes a clicky sound when you move the tail blade...
You will feel racheting in both gear sets. This is normal. They will not be "free wheeling" like the V911. I have a little smaller Solo Pro 228 that has the same feel. My little choppers are all "free wheeling".
hawaiichopper is offline Find More Posts by hawaiichopper
Old Jan 09, 2013, 12:45 PM
Joined Oct 2012
Originally Posted by Rollmops67 View Post
Hello !
i'm not sure if it's a good idea with the wire above the rotor head.
i have two F45s, and both have some wobble when seeing from the top of the rotorhead, albeit my shafts are straight and no bent.
I think there is some imprecision in the molding of the rotorhead.
To see if the shaft is bent, the best would be to remove the whole rotorhead and blades (one screw and two links) and to place the tip of the wire above the shaft.
Regards, Roland
No problem if all is stationary. Have done it several times. Just have to be careful. Or remove the head as you suggest - but that takes the blades out of the rotation equation. Or take everything apart and roll the smooth shafts on glass. Or just fly it until something breaks and then replace it!
Old Jan 09, 2013, 12:57 PM
Joined Oct 2012
If you have a field to fly in (with not too many trees), go for the F45. If you have a good size yard, go with F46 size. Waiting on F46 delivery. IMHO, stay away from Solo Pro 228 heli. Flies good but breaks too easy. F45 is one sturdy bird. Still got one for sale.
Old Jan 09, 2013, 01:34 PM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
The Next F45/450
Gunna be fun!
arrowshooter is offline Find More Posts by arrowshooter
Old Jan 09, 2013, 03:29 PM
OldOz is offline
Find More Posts by OldOz
John
Australia, QLD, Brisbane
Joined Aug 2012
Arrowshooter -
First flight of F45/450 No. 2 today. Using the Xtreme/Turnigy tail BL conversion on this one first.
Went pretty well till the wind got up - unfortunately, just doesn't seem to have the wind authority of the brushed tail (yet, anyway). Finished up 100yards away in a horse paddock, last 50ft straight down. Found by a couple of the horse guys, who kindly passed it over the fence.
And NO damage! - well, bent flybar. Did the sensible thing(?) and continued on through 3 battery packs, nothing overheating at the end.
Extended the tail a bit (to full 450), might have shifted the CG too far back perhaps.
Bit worried about the weight of the HK full metal tail for belt drive - might see how you go on that idea (think you said you were going to try that first) while I try other BL tail variants.
Nice canopy, you've got there!
Cheers
John.
PS - What's this luxury of a HANDLE on your 450 box? We HK guys carry them in our teeth, like men lol.
OldOz is offline Find More Posts by OldOz
Old Jan 09, 2013, 04:51 PM
ITS ME DAVID is offline
Find More Posts by ITS ME DAVID
ITS ME DAVID's Avatar
Joined Apr 2011
I guess ill make it mine also
ITS ME DAVID is offline Find More Posts by ITS ME DAVID
Old Jan 09, 2013, 04:53 PM
R.C. Man is offline
Find More Posts by R.C. Man
Frank
Germany, BW, Heubach
Joined Dec 2012
Hi yall, Was out in the garage again, made a heli C.G. balancer, works pirty good in my eyes.
Good to see how your Bird is hangen' lol (and checkin main shaft wobble)
Flew today in the dark night and (oops) which way is front, allmost landed on the neighbors house, smacked the edge of the roof, and down she was.
Broke the loops on the rotor shaft and did a quick fix.
So I'm back in the air
Yall keep a flyin, and keep the skids down before landin.
Frank
R.C. Man is offline Find More Posts by R.C. Man
Old Jan 09, 2013, 05:37 PM
Joined Aug 2012
Originally Posted by OldOz View Post
Arrowshooter -
Cheers
John.
OldOz -
Glad you got her up and running.
My thoughts about the brushless tail are to try a 10,000kv inrunner in place of the stock brushed motor. These motors are 12mm in diameter and appear that they will bolt right on. I have no idea what RPM the stock motor turns, but I fugure it has to be pretty close. I found an outfit that is in Germany that can make a 0.4 mod pinion.
Old Jan 09, 2013, 05:39 PM
sergiopov is offline
Find More Posts by sergiopov
Joined Jun 2011
Thank you, friends.
sergiopov is offline Find More Posts by sergiopov
Old Jan 09, 2013, 05:57 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Arrowshooter -
Cheers
John.
Just a suggestion, but have a look at the V400D02 thread. The V400 had a brushed tail motor with gear reduction and many of the guys converted to brushless tail. They used the stock tail rotor, which is similar in size to the MJX, only direct drive as I have mine. Most seem very happy with the result and the tail holds well. Many of these guys are flying 3D and have head speeds well over 3000 rpm.
BThirsk is offline Find More Posts by BThirsk
Old Jan 09, 2013, 06:03 PM
Joined Oct 2012
Arrowshooter -
Cheers
John.
Would you be so kind as to forward some of your energy this direction? I think it's a good day for me if I get a canopy modded to fit where it wasn't intended! Am too cheap to pay $16 US for a real Solo Pro 228 canopy so I modded one from a F037 (double horse "clone" or whatever) to fit. Actually looks good and it's low enough to avoid FB strikes. $2.99. Difference pays for new main gear (actually two, I'm a pessimist).
Old Jan 09, 2013, 06:13 PM
Joined Oct 2012
Waiting for a MJX F47 to arrive and thinking about a F46 (or v912). Will review and post elsewhere on rcgroups. Will be interesting to compare to F45, though obviously smaller. I think the Solo Pro 228 may self destruct the rate it's going!
Old Jan 09, 2013, 06:17 PM
Joined Aug 2012
Good point. RTF-Heli was/is pushing a direct drive conversion for this very reason. Is there a prop/adapter that will work with the current F45 tail motor?
Old Jan 09, 2013, 06:48 PM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
I have quite a few flights on my Solo Pro 228p. My elevator link is extended for more fff and the canopy is lowered to eliminate flybar strikes, which for me was the main cause of crashes. I fly it with the J6pro.
I fly mostly over grass and rarely break anything except the odd tail shaft gear and landing strut. The 228 has very precise control at low speeds and can fly very fast, but it's high-speed handling characteristics and fragility of certain parts, make this NOT a learning heli.
The F45 is a better novice heli but the 228 flys in a smaller area, which is what I need. But you definitley have to be more careful with it.
regards . . . g
gordonzo is offline Find More Posts by gordonzo
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
