Old Jan 08, 2013, 03:49 PM
hawaiichopper is offline
Find More Posts by hawaiichopper
United States, OR, Portland
Joined Oct 2012
Originally Posted by R.C. Man View Post
here is what I think he means tig
take off the blades first.
tell me if ya can see what i mean and I sent you a message too
Frank
Yep! Frank is right on. I left the blades on as I had a lot of room and I could then see any influence from the blades also.
hawaiichopper is offline Find More Posts by hawaiichopper
Old Jan 08, 2013, 04:13 PM
R.C. Man is offline
Find More Posts by R.C. Man
Frank
Germany, BW, Heubach
Joined Dec 2012
Ok Tigg,
To replace main bearings,
Remove the rotorhead, swashplate and the ring on top of the top bearing,
Remove the screw on the main gear, and the mainshaft should come right out.
pull the bearing out , top bearing comes up and the bottom 1 down,
I think they are 10 x 5 x 6-7 lagern (bearings)
R.C. Man is offline Find More Posts by R.C. Man
Old Jan 08, 2013, 04:15 PM
tiggertoo1962 is offline
Find More Posts by tiggertoo1962
Scotsman in Germany
tiggertoo1962's Avatar
Germany, BY, Schwabach
Joined Oct 2012
Thanks a lot guys, got the idea now.
@ Frank
before I go building a scaffold I'll have a look at the top bearing angle if someone can tell me how to get into it . If that doesn't do it I'll see what I have lying around to rig something up.
Let me see:
wood - check
wire - check
100 mm screws - check
right-angled brackets - check
2 bags of concrete - hmmm, all used up... looks like I'm off to the DIY store tomorrow
Fin
tiggertoo1962 is offline Find More Posts by tiggertoo1962
Old Jan 08, 2013, 04:18 PM
R.C. Man is offline
Frank
Joined Dec 2012
Take the rotorhead off and the ring, and wala, the bearing is lookin at ya.
Old Jan 08, 2013, 04:20 PM
Scotsman in Germany
Joined Oct 2012
I'm on it first thing in the morning. The Wife will just have to wait for her coffee if she gets up too early
Cheers again guys
Fin
Old Jan 08, 2013, 04:26 PM
R.C. Man is offline
Frank
Joined Dec 2012
Hey Tigg,
I always let mine make the coffee,OLD SCHOOL dude I guesse
Old Jan 08, 2013, 04:40 PM
Scotsman in Germany
Joined Oct 2012
Hey Tigg,
I can't sleep that long man...
Old Jan 08, 2013, 04:45 PM
R.C. Man is offline
Frank
Joined Dec 2012
LOL
If ya need any help, I live like an hour from ya, maybe we can have a dogfight with our birds, outfit them with paintball guns and blast away,
That would be like 10000000 youtube hits in a week.
I fly at the old fussball field here all by myself 60 meters from my house, loads of room to manouver and crash.
And nobody laughs at ya when your alone.
Frank
Old Jan 08, 2013, 04:50 PM
R.C. Man is offline
Frank
Joined Dec 2012
Oh the bearings are 10 X6 X3
Old Jan 08, 2013, 05:18 PM
Scotsman in Germany
Joined Oct 2012
LOL
Frank
Just turned 50 myself last year. Jeez, I wish they'd invented Li-Po batteries when I was a kid
I'm crap with electronics, but if you could figure a way to use the camera button to control a couple of paintball guns, wouldn't THAT be a gas
A call to any of you electronic geniuses out there???
Old Jan 08, 2013, 05:32 PM
R.C. Man is offline
Frank
Joined Dec 2012
Well as old as we are we still play with toys... man, we aint that old now are we.
as to the paint ball guns on the camera connecter,
I read like 5 volts with button on and 0 volts in off,
Have to check when system is on a load to make sure.
Maybe tomarrow after work.
lol flyin and shootin each other, man our birds would look like the Berlin wall after 15 mins.
Old Jan 08, 2013, 05:55 PM
Hurricane6 is offline
Find More Posts by Hurricane6
Joined Jan 2013
Thanks guys.
I will take down the tail rotor assembly and the gearbox.
I'll check for looseness or a crack or debris in the drive.
Safe flying folks.
Hurricane6 is offline Find More Posts by Hurricane6
Old Jan 08, 2013, 06:52 PM
Whizgig is offline
Find More Posts by Whizgig
Eugene
Whizgig's Avatar
Australia, VIC, Delacombe
Joined Oct 2006
Thanks for that Eugene. What exactly are the "blade pins"? All I can see are
- a screw which holds it onto the main shaft, which I managed to tighten about 1/4 turn.
- the pin which goes through the main shaft and connects the blade holders, which I think is the one. This flew out and nearly lodged in my forehead yesterday when I tried checking the flybar without the blades on (I know not to do THAT again ). It was still perfectly straight and is now back where it should be.
Yes this is the part and the pins are the ones that hold on the blade holders, what do you mean when you said it flew out and nearly hit you do you mean the the pins or the whole unit as the plastic pins are molded with this part as a unit and the pins don't come off unless they are broken.
Whizgig is offline Find More Posts by Whizgig
Old Jan 08, 2013, 07:55 PM
Jasonamorris6 is offline
Find More Posts by Jasonamorris6
Joined Dec 2012
So I want to get a case together for parts,tools and tx...maybe even for the heli... Only have a f45 and the h911 along with some smaller 3ch heli's... I tried to search the forum but can't find much...what are people using? Post your pics if you have any good ideas for a case...
-J
Jasonamorris6 is offline Find More Posts by Jasonamorris6
Old Jan 08, 2013, 08:19 PM
Whizgig is offline
Eugene
Whizgig's Avatar
Joined Oct 2006
-J
Any standard 250 size heli case.
Like this one:
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
