United States, HI, Hilo
Joined Oct 2012
Australia, QLD, Brisbane
Joined Aug 2012
Arrowshooter (and Whizgig)-
All my HK bits for the second F45/450 came this morning. Got to pull the last original f45 apart, to build it too... .On the other hand, have over 50 flights on the 450mod now. Flown every day (on principle), through some pretty heavy wind (with 21knots actually logged on one occasion). Can't honestly say it was all fun, but never felt the heli itself was in danger at any time. Feel we're on the right track, here. Going for the 6chan Rx/Tx build next, progress report later. Edit... Turnigy 2211 came too, it seems. Might try an upgrade of the 1811 BL tail first. Had to revert to brushed, the 1811 simply didn't have the grunt for the job. |
Joined Oct 2012
Joined Aug 2012
Do you really have to move on from the f45? It really is the cream of the crop, and I've found second hand helis very difficult to sell at other than ridiculous prices, except to friends (or family) who know you and your product. However, the best marketplace over here ime seems to be mall noticeboards - buyers are local, and can see you fly it. Second best is local free newspapers. Wish you luck, but sorry to see you go... Cheers John PS Is the SP228 THAT bad? |
The Netherlands, ZH, Rotterdam
Joined Aug 2012
Rocking solved? 2
Hi Guys
A while back I did some test with a rubber band, see: http://www.rcgroups.com/forums/showp...postcount=4320 I ordered a new servo to replace the servo with too much play, installed it a few days back, the testflights without the rubber band went smooth, but not as smooth as I hoped, some minor rocking was back, I noticed that there was still some play on the swash plate, though I decided to dampen the movement on the other side, the anti rotation arm this time. I used a very thin rubber band with just enough tension to dampen the movement of the swash plate a bit. Bingo, at least for my setup, rock solid ![]() Regards |
One of my F45 had also this rocking when I opened throttle, but now that I mounted the Extreme blades intended for the Esky HoneyBee FP, this rocking has almost disapeared. Don't ask me why, I have no clue... Roland |
YIIIIIPPPEEEEEEE!!!!!!!!!
Came home from night shift, got the head down for a few hours and woke up just over an hour ago to find The Wife had taken delivery of my F645 .Battery in the heli is charged, first replacement too. Rain is off for the first time in 3 days, wind isn't too high, and the 2nd 2000 mAh battery is on the charger right now. Give it another hour maximum and I'll be down at the meadow making the neighbourhood unsafe ![]() Even though I've had my V911s for about 2 months now, still a bit nervous as I don't have a feel for the F645 yet, and don't have any spare parts in case I SHOULD break anything. Maybe just have to spend the charging time ordering #2 in case anything goes wrong
United States, CA, Modesto
Joined Aug 2012
Was raining most of yesterday here, but when it let up I broke my own rule of not flying the big bird in the backyard. End result, broken main blade, landing skid and antirotation bracket after tangling with a power wire. Now I am grounded until I get new skids, make a new bracket (need to do anyway for new bird) and widdle down some more Hnoey Bee Blades. Oh well. |
Greetings Pilots,
When using the EH200 and a 11.1v battery the Honey Bee FP helicopter blades are definitely a huge improvement over stock. You do have to drill out the holes and shave off enough of the outer circle so the blades have free travel. To shave the excess material I use an axe file set down on the workbench and draw the blade along it while slowly rotating to get a nice smooth curve. With an aggressive file it only takes a few swipes and a couple touch-up passes to ensure it's rounded enough. That rubber band stuff is very interesting! |
Joined Oct 2012
The 228 flies really well, but I'm so spoiled by the sturdiness of the F45 that I get disappointed when really minor "accidents" break something on it. It's become a challenge to keep it going without putting too much money in it. On the other hand, I think about making an aluminum frame etc, etc., but then I should just get a F46 and be done with it! Maybe I'll keep one F45 for nostalgia ( ) and sell the other F45. Anybody interested in a good deal?
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
