Old Jan 03, 2013, 08:48 AM
Spain_Betis is offline
Find More Posts by Spain_Betis
Joined Dec 2012
Hello friends. I have a big problem. I thought I had burned the main engine. I purchased two new engines. I have changed but still not working. I've tried different batteries (I have 5) and does not work. Just move the queuing engine. The servos are working properly, makes all movements. What I can do? thank you!
Spain_Betis is offline Find More Posts by Spain_Betis
Old Jan 03, 2013, 09:51 AM
arrowshooter is offline
Find More Posts by arrowshooter
United States, CA, Modesto
Joined Aug 2012
Take off the PCB so you can see the bottom. Look for burned traces like this:
arrowshooter is offline Find More Posts by arrowshooter
Old Jan 03, 2013, 10:15 AM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Originally Posted by Whizgig View Post
This is normal, it is the gyro trying to keep the heli level. All 6ch cp heli's do this and also the tail servo will not return to center as the gyro is controlling it. To set the arm trims correctly turn on the heli and then switch it back off again as soon as the servo's lock into their center positioning.
if I get the chance to try it I'll keep that in mind. It'll be a while until I can get more "stuff".
rexless is offline Find More Posts by rexless
Old Jan 03, 2013, 11:39 AM
Joined Dec 2012
No work well the battery cables. I'll buy another PCB. I have seen that there are two types of PCB. The two well synchronized with the remote? thanks
Old Jan 03, 2013, 11:42 AM
Joined Aug 2012
Sorry, I do not understand "no work well the battery cables". What do you mean?
Old Jan 03, 2013, 11:52 AM
Joined Dec 2012
While the current fails. when I give the throttle, just move the rear engine, two seconds and stops working and the LED flashes the helicopter. The servos work and make all the moves.
Old Jan 03, 2013, 11:57 AM
Joined Dec 2012
The photo is my PBC and want to buy this: http://www.banggood.com/Wholesale-Mj...9-p-46451.html Is it compatible with the remote?
Old Jan 03, 2013, 12:19 PM
Joined Aug 2012
I understand. That is the "old style" PCB you show from Banggood. I do not think it will work with your new controler. Someone else here would know more about new vs. old.
Old Jan 03, 2013, 12:26 PM
Joined Dec 2012
I understand. That is the "old style" PCB you shoe from Banggood. I do not think it will work with your new controler. Someone else here would know more about new vs. old.
Is that I have seen in several places. The PBC old. Does anyone know more about this? thank you!
Old Jan 03, 2013, 01:28 PM
Rollmops67 is offline
Find More Posts by Rollmops67
Eternal beginner
Rollmops67's Avatar
France, Alsace, Strasbourg
Joined Jun 2012
I had a problem with exactly the same symptoms, in fact it was the tail motor wich had a short circuit. (It happened during flight, ouchh).
And each time I pulled up throttle the PCB went in kind of "security mode" with flashing led.
Try to disconnect the tail motor connector from the PCB (the one with a white and a blue wire) and look what happens.
Maybe it could also be the main motor wich has a short-circuit ?
Try to disconnect the main motor connector to see.
Roland
Rollmops67 is offline Find More Posts by Rollmops67
Old Jan 03, 2013, 01:45 PM
Joined Dec 2012
Roland
ok, I'll try to do that. You know if it supports the other PBC, with the remote? thanks
Old Jan 03, 2013, 05:09 PM
Jasonamorris6 is offline
Find More Posts by Jasonamorris6
Joined Dec 2012
Just got my f45 today... Quick question before I test it out, I'm a beginner so with that said, whats a good tx setup for a beginners first fight? (%'s on the tx controls)
Jasonamorris6 is offline Find More Posts by Jasonamorris6
Old Jan 03, 2013, 05:25 PM
rexless is offline
rexless's Avatar
Canada, BC
Joined Apr 2012
Ah fun.... I was out today at -9C and couldn't get the tail to hold. I had to throw the stick hard to the right to maintain a straight heading. Managed to land safely. I just checked it out in the house and it seems ok. Either the tail motor is flaking out (I'm probably 25-30 flights in on this one) or the gyro said "nope, too cold".
Ironically I crashed my big quad for the first time today. Fortunately it was into a snow bank. It's drying out now but I think it's going to be just fine.
Old Jan 03, 2013, 05:52 PM
rpc4 is offline
Find More Posts by rpc4
rpc4's Avatar
United States, VT, Windsor
Joined Apr 2012
I don't risk big helis below freezing my cheap Gyro gives me the NFW below 30F don't know what the Align's would do but it's to risky. Most of my flying has been with V911 indoors or with my mini quads -17F last night here. My big quad is waiting on parts I crashed it in the cold KK2 board spazzed out and bent a motor shaft and did in 3 props and broke frame. But the good thing is the KK2 is still ticking. I see some guys have made little heaters to keep board warm, me I will wait for the thaw,
rpc4 is offline Find More Posts by rpc4
Old Jan 03, 2013, 05:56 PM
rpc4 is offline
rpc4's Avatar
Joined Apr 2012
Feala.com shows pictures of both boards so you can see what you are getting before you buy they also show both transmitters.
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
