Brazil, MT, Juara
Joined Oct 2012
The Gyro, I use it for? I apologize for the questions, but I am very beginner! The Gyro know it serves to control, but what advantages? If there are any, I use! and D And how should I adjust? Remove the others? |
United States, CA, Modesto
Joined Aug 2012
http://www.ebay.com/itm/XTREME-Brush...item1e74dccd22 Got no idea what that gyro would be be used for on the F45. I think you would need a whole new Rx and all. |
Joined Nov 2012
You need one of these to plug between current tail motor spot and ESC. Do a search here and you will find the hookup.
http://www.ebay.com/itm/XTREME-Brush...item1e74dccd22 I did not order any signal convertor.what is it for? |
Australia, QLD, Brisbane
Joined Aug 2012
Whizgig -
Sorry, missed your question a couple of pages back. The 'custom' skids on my MJX/450 are just HK standard 450, but with a Clark Rubber closed cell pipe lagging coat. Essential, as with anything HK, you take your chances! - their stock skids you could snap between two fingers: on the other hand, their 450 rotor head (from http://www.hobbyking.com/hobbyking/s...arehouse_.html) is imo far superior - particularly for a learner - to the all plastic unit that came with my Align 450 RTF. The tail even more so. Been using the built up kit in preference to the Align, so I know where I'd rather they kept spending their R&D! - can always finish off with Align skids, shafts, main gear, and other odds and ends. Regards Vladicopter - The first step in the BL tail conversion is to transform the brushed motor drive signal to a format suitable for an ESC. That's why you need the converter. Another link, showing the setup - http://www.xtreme-production.com/xtr...mart&Itemid=31 If you're using a separate RX/Gyro/servo or ESC (as you seem to be) you have no need of it. If not, hope this helps. |
Joined Aug 2012
Joined Oct 2012
Its a bit off topic, but I'm not getting a useful answer in the simulator forum, so here goes....
Is a 4 channel simulator OK for learning 6 channel CP heli? Will I be able to set throttle and pitch curves? (I do not mind using the keyboard for throttle hold/idle up). I will use Heli Sim RC or Clearview with it, not FMS. |
Woohoo, picked up my new F645 from UPS today, present from my daughter but she had missed UPS delivery Tuesday, they were about to send it back, glad I caught it before. Switched the servo arms, made blade shims, and mechanically trimmed the swash till I had a hands off hover in my family room. Now if these blasted winds will die down, figures as it had been calm all week, maybe it will calm down toward dusk.
Joined Nov 2012
Hey everyone,... been having lots of fun flying my F45 until about an hour ago. Thanks to my pea-brained cousin, who is about as smart as a tick! He plugged the bat wire into the open socket on the board. I heard him say "Whoa!" and when I turned around,... I saw the smoke. I jumped up and yanked the wire and blew away some of the stinky smoke, then tried plugging it in the batt port on the side,... nothing. No usual twitch,... nothing. And I showed him where to plug the battery wire in on the side, maybe 3 or 4 times, but I guess his tick DNA is more dominant than I thought.
Anyway,... you guys think I'm looking at replacing a fried board? I suspect I am, but wanna be sure. I know there's the new version, but how do I know if I'm looking at a replacement old or new board. If I remember right, I think I read that the new boards have the open slot (yep, the slot where my Nobel Laureate cousin plugged the battery into) next to where the servos are plugged in. Is this right? And the older boards don't have this open slot? Thanks for the help. BTW, the shims worked well on the blade grips. Thanks for that advice WarHorse! |
"BTW, the shims worked well on the blade grips. Thanks for that advice WarHorse!"
Glad to hear it worked out for you ![]() On the other hand sorry about the cousin, I have a rule of thumb for all my "toys" and that is , you can play with them when ya lay the cash on the table. Sounds like the PCB got fried... sorry
Joined Nov 2012
Hey congrats tracker1955 on your new bird bro! Enjoy! |
I noticed Vladicopter was buying a bunch of heat shrink tubing. I had found this kit on Ebay and love it.
http://www.ebay.ca/itm/160-Pcs-Pro-K...#ht_583wt_1122 Quote:
I'm looking at my newest F45 and I'm not sure I'm following. What open socket are you referring to? And now for all you Heli video fans, here's the latest instalment. I call it Home Run Helicopter as I'm flying around in a baseball diamond. I tried slowing the video down at the highest altitude as I very slowly spun the helicopter around to do a panorama. The camera, unfortunately, didn't like the slow rotation and picked up some jello. I might have to check the tension on the zip ties!
Joined Aug 2012
Arrowshooter -
My MJX 450 mod. Made a mistake on my original post, so will correct that here (and answer your questions at the same time). The gear train, driveshaft is all HK 450 up to the rotor head. Problem is, the 450 shaft is 5mm - actually thinner than our stock F45's. Hence the need for the 6mm (F45) to 5mm (450) shaft adaptor. You have to make a sleeve (mine was from a cannibalised F39 coax outer shaft, drilled out) about 4cm long. Again, the 450 boom is a larger diameter than the F45. I found trimming off the last 5cm or so of the stock f45 boom (with rotor assembly), and packing the slight difference with tape gave a very firm fit inside the 450 boom. As the stock tail is only a temporary fix for me, pending arrival of my BL tail bits (or a successful 450 belt drive tail conversion) I didn't worry too much about the details. But the stock tail really has no trouble keeping up with the much more powerful (than EH200) ADH300XL main: which does surprise me. Though I do suspect the stock tail motor will wear out faster than normal in this usage. The PCB is still stock F45, so not really off topic. However the ADH300XL is a great motor. So powerful, in fact, that the modded heli is not only able to lift its own 600g weight, but also to handle fairly normally with an extra 100g (battery) strapped underneath - all on a 2s 2200 Turnigy! |
| Thread Tools | |
| Discussion UAV systems Single Rotor vs Multi Rotor | iskoos | UAV - Unmanned Aerial Vehicles | 2 | Jan 06, 2012 10:51 PM |
| Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax | LMF5000 | Electric Heli Talk | 7 | Apr 26, 2011 08:33 AM |
| Question Upgrading from Co-Axial to FP Single Rotor | Judo JoNny | Electric Heli Talk | 57 | Sep 20, 2010 12:10 PM |
| Discussion Best FP single rotor 4 CH Heli? | helinewbie617 | Micro Helis | 76 | Oct 31, 2009 07:16 PM |
| For Sale will trade my orbiter coaxial for a fp or cp single rotor heli | micro heli | Aircraft - Electric - Helis (FS/W) | 3 | Sep 05, 2007 01:36 PM |
